Question about Sewing Machines
Singer overlocker my singer overlocker model number 14y554d isn't working properly. I recently rethreaded it for the first time and now it is sewing ok but the threads aren't making a chain stitch when there's no material in it.
  • Anonymous Mar 27, 2014
    Do you have instructions for threading Singer overlocker model no 14T554S
  • Sewing Machines Master
  • 1,388 Answers
Most likely is the left looper thread is trapping the needle threads.
Remove the threads and start over in this sequence....
Left looper - right looper - left needle - right needle.
If you thread the needles before the lower looper, the needle thread wrapped over the looper will be under the looper thread and will never be free to form a stitch, so the threading sequence is critical.
Posted on Jun 08, 2008
I've rethreaded my 634d overlocker, and now it wont sew properly, its bunching up the threading behind the needle?please can someone help
Most often, the problem exists in the threading process. Try removing all the threads from the machine and rethread from beginning to end in the order specified. Any deviation with one of the threads may cause the machine to not stitch properly.
Nov 16, 2017 | Sewing Machines
How to thread a Empisal overlocker.. model 760C
Perhaps the manual would help:
Empisal Overlocker 760C Empisal Sewing Machines
On most machines, it is important to ALWAYS raise the presser foot when threading the machine (although the instruction manual says to raise the presser foot only to pull the thread tail under it). Be sure to give the thread an extra little tug when going through the tension disk to seat it properly. Be sure to thread in the order as specified (Upper looper, Lower looper, Right needle, Left Needle). If the machine messes up, it is usually a best policy to remove all the thread and rethread from the beginning. Threading out of order will almost guarantee failure!!!
Jul 20, 2016 | Sewing Machines
When threading machine, thread won't stay in place at step 4, so when I move thread to step 5, thread comes away. Only bought mchine in March.
When threading the upper thread, be sure to always raise the presser foot. This releases the tension disk and allows the thread to seat properly.
Here's a video that may be helpful:
Singer Fashion Maker 1409
May 15, 2016 | Singer 1409 Promise Sewing Machine
Overlocker is not sewing. How can I thread the lower looper without it breaking?
Thread breakage is usually an indication that the machine is not threaded correctly or the tension is set too tight.
As a reminder, if a thread breaks, save yourself some (lots!) frustration and rethread every thread From The Beginning. Rethreading only the broken thread will usually just lead to it breaking again. Sergers are finicky and must be threaded in the correct order. Also, Always raise the presser foot while threading. Your thread breakage is occurring with the lower looper. Be sure that you are threading every guide and give it a little tug going through the tension disk. Usually, the last step is to drape the lower looper thread over the top of the upper looper before it is pulled back and under the presser foot. Be sure to initially set the tension at the midway point between the high & low numbers.
My serger is still not working properly trhread still breaking lower and...
Apr 07, 2016 | Sewing Machines
My lower looper thread keeps breaking. I rethread it, checked the tension and yet it still breaks.
Please re thread machine from scratch threading upper looper first then lower looper then needles also be sure needles are in with the flat back to the back of machine sequence of threading is imperative
Feb 24, 2015 | Euro-Pro Sewing Machines
Thread breaking at loupers on overlock machine singer
If it's the lower looper thread breaking, the cure is to unthread the eye of the needle(s), rethread the lower looper, then rethread the needles. Sergers have very specific internal crossings that are easiest to do if the various parts are threaded in a particular order. Typically, you thread the upper looper, then lower looper, then the needles. If you try to deviate from that without knowing exactly what you're doing, it tends not to work well.
In general, most serger troubles, especially for beginners, trace to minor misthreadings. It's easier, in my opinion, to rethread the entire machine from scratch than look for the minor error that's catching you up. And you learn the threading pattern well as a special bonus. <g>
If it's not cureable by rethreading a couple of times from scratch, the next thing to do is put in new needles, right way around, and rethread again.
Feb 08, 2014 | Singer Sewing Machines
Problem with an overlocker that does not overlock
You may need to rethread all the threads because most sergers need to be threaded in the right sequence. I looks like this one has to be threaded starting at the right and progressing left.
Jan 20, 2014 | Janome Sewing Machines
Sewing machine stopped making the stich
Unthread the needles, rethread the loopers properly, then rethread the needles. Make sure that all four threads are pulled securely into the tensions and retry.
The loopers must always be threaded before the needles or it will not chain.
Jul 19, 2009 | Yamata FY14U4AD
Thread wont overlock
When the thread breaks too often, try these, that goes for all sewing machines
1. Replace the needles,
2. Loosen slightly the tension of the needle threads.
3. The top threads are to thin,
4.The sewing (rotary) hook or looper, has burs,
5. Wrong threading
May 21, 2008 | Husqvarna Viking 1
Sewing Machines Logo
237 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
