Question about Hitachi 42PD7800 42 in. HD-Ready Plasma Television
No power The Plasma TV was working fine last night. We turned it off normal and this morning did not have power at all. I try different outlets but no solution. Any idea what is the problem?
  • 1 more comment
  • Abbyel2001 Jun 10, 2008
    The make and model is Hitachi 42PD7800. I checked the fuse and the power board but neither one is the problem. Is no voltage reading at all in the TV. It is power on the wall outlet but that is all.
  • ael_2 Aug 17, 2008
    Hi, My 42PD7800 Plasma experienced a power surge when the mains plug was bumped causing intermittant circuit from the mains supply. The unit was on at the time. I have checked the 6.3amp fuse which is blown but replacing the fuse did not rectify the fault. I can see no obvious issues with the Power Filter board.
    Hope you can help.
  • ldgreenan Apr 27, 2009
    my problem is no power at all at the plasma, when you switch the power on you can hear the surge, then nothing, no stand by light no nothing!
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 92 Answers
First off I did not see make or model. When plasmas die you have failure in either the power supply of the sustain boards. Do you have any voltage readings from va or vs ?
Craig www.classtorations.com
Posted on Jun 09, 2008
  • 579 Answers
Check fuse on powerboard. Look for bulged capacitors on power board. Might have a screw in fuse access on the rear panel.
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My set is plugged into a cable box. the tv will not turn on either manually or with the remote.
Plug the power cord directly into a wall power outlet, and make sure that the standby light is lit (turn it on/off manually to see if anything changes). If there isn't any light, then it's most likely broken.
If the TV works again, being plugged into the power outlet in the wall, then the problem is with the cable box (i bet you figured that out too).
Jul 06, 2014 | Envision L32W761 32 in. LCD TV
Sylvania 6632LG won't turn on.
The power supply may have gone out, that is the first place to look, look for blown fuse, burnt parts, bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 13, 2009 | Sylvania 6632LG 32 in. LCD HDTV
LG 32LP1D TV no power
Check the fuse on the power board. If ok change the power board.
Nov 01, 2009 | Televison & Video
Lost electrical power at 2 outlets. No TV power
wires could be crossed or burnt out
Jun 14, 2009 | Televison & Video
Tv wont turn on worked fine last night
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
May 30, 2009 | Spectroniq PLTV3250 32 in. LCD TV
No power no led's
check there is a problem with SMPS and fuse/power socket problem thank u
May 24, 2009 | Spectroniq PLTV3250 32 in. LCD TV
Trinitron KV-36FS13
The problem is in the standby power section. Check the fuse, R607, or burnt IC601, fuse R612 and VD relay 601 should show open. Its possible it could be the high voltage area of the power supply. You can try unplugging the set and cable and let it sit 4 to 6 hours. This is a hard reset. If it still doesn't turn on after the hard reset and the fuses and relays are fine, and you don't smell anything or see anything burnt. Then you'll need to call a TV repair man. They normal start around $150-$200 to fix the set. I hope this helps.
Jul 10, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Hitachi 42PD7800 42 in. HD-Ready Plasma Television Logo
331 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
