Question about Refrigerators
Fridge bosh Dear Sir, i have abosh frdge freezer and it seems that the fridge compartiment it's notas cold as it should be.I turn the thermostat at 5 and no change. cananybody give me an advice? Many thanks, Oana
  • 828 Answers
Look to the freezer for your problem. If you have frost buildup on the back wall inside the freezer section your defrost system is not working.
Posted on Jun 09, 2008
I have a westinghouse frdge freezer bj 385 motor constantly running with the door close motor stops intermidently open door motor stops recently moved fridge
Hi Peter, It it's not freezing the fridge up then it needs regassing but it it's freezing the fridge up then could be the thermostat, Good luck mate..... CHEERS..
Apr 04, 2016 | Westinghouse Refrigerators
The freezer works but not frdge
What is the model number of the unit?
Nov 09, 2012 | Refrigerators
Freezer is cold, but cold air is not circulating in refrigerator
Check freezer fan is working.If ice formed over freezer fan by working. It's a common problem due to irregular defrosting. Keep freezer setting temp at 5 degree. And check defrost timer, thermostat,heater are working properly.
Turn timer with small tip screw driver to shut off fridge. If not shut off, replace timer. Turn counter clockwise defrost thermostat. If fridge not shuts off replace defrost thermostat.Check heater by join the 2 wires in the defrost thermostat. And after 1 minute, unplug power and keep your arm on heater. If it's warm heater is o.k. Otherwise, replace heater.
Once heater starts work at regular interval controlled by thermostat and timer, defrost will be good and effective cooling will also be in fridge compartment.
Jan 24, 2011 | Amana ABB2524DE Bottom Freezer...
Hi all My fridge freezer seems to have a problem.
increase the thermostat to a more cooler one, ideally at -5 F
Jan 02, 2011 | Freezers
Fridge not making usual humming sound
I had a same problem, However the fan in the freezer seems stop and the freezer compartment is melting. Its a double door LG with 270 ltrs.
Mar 11, 2010 | LG LRTBC1825T Top Freezer Refrigerator
My GE fridge won't stay cold. The freezer up top seems to be cold.
How to check parts
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 07, 2009 | Refrigerators
My frdge will not stay cold. the freezer does
yes the fan is running. i cleaned the coils under the fridge and the fan.i just turn the fridge back on
Oct 16, 2008 | Frigidaire Refrigerators
Whirlpool Refrigerator or freezer Doesnot cool
I have a similar top freezer and during the summer
I have had a problem where the frdge part does not get cold. The two holes coming from the bottom of the freezer to the fridge are blocked
with ice. I took the back part off the freezer
got rid of a clump of ice. I also used a hair dryer
in the fridge section to melt the ice in the holes.
Dec 11, 2007 | Whirlpool ET1FHTXM Top Freezer...
Hot point Fridge/ freezer
All the cooling is in the freezer and the control in the fridge side only controls a damper to let in cold air as needed. To do what you want you have to replace the thermostat to a lower temp rated unit
Nov 22, 2007 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
