Hp cd writer cd12d
Need to update drivers
a: drive error
  • louisewaye Jun 30, 2008
    My disk drive will not recognize having a blank disk. When I try to record to the disk, I get the following: "No disk in disk drive" "Insert disk in disk drive." There is a disk in the disk drive. Why will the drive not recognize this?
  • Anonymous Aug 25, 2008
    daro
  • 19,396 Answers
Hp cd writer does not require drivers on windows unless it is Windows 98/ME or earlier version.
a: drive error, it is an error with floppy, or floppy settings, not cd.
If floppy is present then floppy drive is probably faulty and in need of replacement.
You can bypass the problem accessing to bios setting. Usually you have to press a key on startup to start bios settings.
Once you access settings you have to change the error prompt setting. The computer will start the same but you won't be able to use the floppy.
Posted on Jun 08, 2008
I have an HP DVD+R/RW 16x10x32x4x2.4x8x Drive and i am trying to find the drivers for it to see if it works on my computer. I have tried typing up the Product Number and HP Part Number on the HP website,...
DVD-RW 16X HP DVD Writer 740b Drive Firmware Update ftp://ftp.hp.com/pub/softlib/software7/COL16063/pv-42566-1/sp26595.exe
you must be logged in as the computers administrator to install this update
or
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07165&cc=us&dlc=en&lc=en
Update your HP desktop computer to have the latest software and drivers available. HP provides many software and driver updates free of charge
hope this will help you
  • You must be logged on as an administrator to install this update.
  • HP DVD Writer 740b drive.
  • Blank floppy diskette, recordable CD (CD-R), or USB Thumb Drive.
  • Released: s.gif 2006-08-23 Version: s.gif HI24 Compatibility: s.gif Microsoft Windows XP
    Aug 21, 2011 | HP/5.25 16x10x32x4x2.4X8x IDE Carbon...
    Hp dvd writer dvd200i
    since you have not stated what the problem with your dvd writer is i will have to guess
    Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
    If this does not fix the problem you might try
    Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
    Close all open programs
    Click on Start, Run, and type regedit and press Enter
    Click on the plus signs (+) next to the following folders
    HKEY_LOCAL_MACHINE
    SYSTEM
    CurrentControlSet
    Control
    Class
    {4D36E965-E325-11CE-BFC1-08002BE10318}
    This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
    Upper Filters
    Lower Filters
    Upper Filters.bak
    Lower Filters.bak
    If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
    After deleting the keys, close the registry editor
    Reboot your computer
    Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
    you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
    you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
    if your computer came with a motherboard disk the drivers could be on it
    click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
    hope this helps
    Jun 17, 2011 | HP DVD Writer Dvd200i (AA622A) DVD+RW...
    I got a hp cd-writer cd12 series multiread cd-r/rw on a really messed up windows millenium edition computer yet it reads as cd-rom only drive i'm tryin to no success and will keep tryin to fix that so i...
    make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
    your drivers may have been corrupted or you might have a virus run your antivrus program
    you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
    you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
    control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
    or
    you could run the check disk utility
    click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive
    Dec 26, 2010 | HP CD-Writer Cd4re CD-RW Burner
    When i want to burn dvd on samsung dvd writer, it ejects the disc and when i insert data disc into the drive, it shows no disc. so, what is the problem?
    try using a different type/brand of cd/dvdrw you might have a bad batch of cd/dvdrw or test all leads that attach to your dvdrw any faulty lead will result in computer error or control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
    hope this helps
    Oct 19, 2010 | Samsung SpeedPlus DVD-Writer 20x, Black ...
    My HP DVD1040r writer that came with my Dell dimnension B110 won't burn CD or DVD's. I did a fresh install of XP Pro SP3. I need the installation setup Cd that came with the drive, but I don't have it. HP...
    hi.. click on my computer.. properties.. hardware.. device manager.. select CD/DVD Rom.. (it would be in a Yellow Exclamation Mark).. doubleclick on it.. then select the option that says.. Driver Details.. and then Update Driver.. try to select options detect the driver online.. it will automatically detect the driver and try to search for it online..
    or use the Product number of ur HP comp.. i.e., the one ending with #ABA.. go to www.support.hp.com.. and enter the numbers before the # sign.. and search for Drivers CD/DVD Rom..
    May 04, 2010 | HP LightScribe dvd640i (DVD640I)...
    MY HP 840i dvd-rw can read CD but can't read DVD
    if you have cd writer and dvd rom then change your cd drive with cd/dvd writer because in the case of cd writer and dvd rom it gives error but sometimes the dvd play also but computer freeze from sometime and when we copy data then give us error messages i give you suggest to buy new cd/dvd writer
    Jun 29, 2009 | HP Computers & Internet
    HP DVD 1040i
    I would email or call hp support and ask about this as there should be a firmware update of some description.
    Also re install latest chipset drivers and maybe adaptec aspi drivers ?
    Apr 17, 2009 | HP DVD1040i 20x Super Multiformat Dvd...
    Hp cd-writer Not Working
    Depending on what HP computer/cd-writer it is the type of disc you are using may not be supported.
    Older cd-writers often had a specific type they could write to, CD -r / CD +r.
    You should try to find out what kind of discs are supported by your cd-writer. This CAN be located in text on the front of the cd-writer.
    Dec 19, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
    Computers & Internet Logo
    363 people viewed this question
    David Payne
    David Payne
