Question about Samsung SGH-ZV40 Cellular Phone
Navigation keys act like menu access/confirm key
While my wife was trying to work out how she could stop the key press noise (wish she had looked for hte answer here first) she has apparently altered something that has disabled the navigation keys and made them act just liek the central menu access/confirm key. Navigation is now only possible by pressing keypad numbers - assuming the option required is available by a keypad number.
Any ideas?
  • 1,800 Answers
Get to the security options and set factory defaults the code is 00000000 eight zeros
rate me
Posted on Aug 16, 2008
Unlock code or hard reset for a samsung SPH-M270.
From the Main screen, press the
MENU/OK Key
TOOLS + SETTINGS
Settings
Reset/Delete
2.
Enter the Lock Code at the prompt. The
default lock code is the last four digits of
the telephone number assigned to your
phone. The first time you access this
setting, you'll be prompted to change the
Lock Code.
3.
Use the
Navigation Key
to highlight
Reset Phone
, then press the
MENU/OK
Key
4.
At the prompt, confirm the reset by
pressing
RESET
Aug 18, 2017 | Samsung Cell Phones
I forgot my password on my projector how to reset a password for dell 1201mp projector manually without using a remote control
  1. Access the projector with the administrator password. In case you never set or do not know this password, use the default administrator password 1234 or the 6-digit password which is provided on the Security Card, shipped with the projector.
  2. Once you access the projector menu, press the menu button. Press ? twice to go to the Management menu.
  3. Navigate to Security, and press ? to open the Security menu. If you are prompted for the administrator password, enter the password again.
  4. Navigate to User Password. Press ? to set a new password using the numeric keys on the remote control. Press Menu to confirm.
  5. You can select when the user will be prompted for the password: only when the power cable has been reconnected, or each time the projector is powered on. Press Menu to confirm.
http://delltechnicalsupportfromtechbuddies.blogspot.in/
May 29, 2017 | Dell Office Equipment & Supplies
Why won't the number 1,0 and space bar button work?
Have you tried a battery pull...... restart by removing the battery while your device is Powered On , try it and see if you're able to access your keyboard . you can try factory default to reset phone ...When you restore the factory default settings, all personal settings are reset. Follow these instructions to restore the factory default settings.
All phone data will be deleted. Data on your SIM isn't deleted.
1. Find "Security Wipe"
  • Press the Menu key twice.
  • Scroll to Options and press the Navigation key.
  • Scroll to Security and press the Navigation key.
  • Scroll to Security Wipe and press the Navigation key.
2. Restore factory default settings
  • Highlight Emails, Contacts, etc., User Installed Applications or Media Cardand press the Navigation key.
  • When the box next to the menu item is ticked (V), the selected data will be deleted.
  • Highlight the field at the bottom of the display and key in blackberry
  • Scroll to Wipe and press the Navigation key to restore the factory default settings.
  • Follow the instructions on the display to set up your phone and prepare it for use.
May 13, 2014 | RIM Blackberry Curve 9320 Smartphone -...
How to reset samsung s w299
1 Find "Reset settings"
  • Press the Navigation key to access the main menu.
  • Scroll to Settings and press the Navigation key.
  • Scroll to Reset settings and press the Navigation key.
2 info.png Restore the factory default settings
  • Tick the required settings by pressing the Navigation key.
  • When the box next to a menu item is ticked (V), the setting will be reset.
  • Press Reset.
  • Press the Navigation key to confirm.
  • Key in the phone lock code and press the Navigation key.
  • If it is the first time you use the phone lock code:
  • Key in the phone lock code again and press the Navigation key.
  • The selected settings are reset.
3 Exit
  • Press Disconnect to return to stand-by mode.
Jun 25, 2011 | Cell Phones
Samsung c3050 phone white screen
Different Samsung phones has different methods to reset to factory default settings, today I will give you the tricks about how to reset Samsung C3050. If there is something wrong with your Samsung C3050 and make your handset slowly, the best method is to reset it.<
p>
While restore your device to factory default settings will delete all the data you saved before, and then your cellphone will be quicker than before. So you should transfer the useful information to the memory card or computer, then when you finish resetting Samsung C3050, you can transfer them back. So back up first.
-Press the Navigation key to access the main menu.
-Scroll to Settings and press the Navigation key.
-Scroll to Reset settings and press the Navigation key.
-The first time you use the phone lock code, key in a code of your own choice.
-Tick the required settings by pressing the Navigation key.
-When the box next to a menu item is ticked (V), the setting will be reset.
-Press Reset.
-Press the Navigation key to confirm.
-Key in the phone lock code and press the Navigation key.
Note: if it is the first time you use the phone lock code, key in the phone lock code again and press the Navigation key.
-The selected settings are reset.
-Press Disconnect to return to stand-by mode.
Please take note: if reset is not the best solution, I would strongly suggest to contact your manufacturer.
May 13, 2011 | Cell Phones
Black ink seems to be clogged even after putting in a new cartridge.
Try thi:
Cleaning the Print Head
  1. Press the Ink, Ink/Reports, Ink Management/Reports or Ink Management key.
  2. Use the up or down navigation key to select CLEANING.
  3. Press Menu/Set to confirm your choice.
  4. Use the up or down navigation key to select the color that is not printing
    -OR-
    Select ALL if more than one color is not printing.
  5. Press Menu/Set to confirm you choice.
  6. The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time.
  7. Test by printing the "Print Quality Check Sheet":
    2. Use the up or down navigation key to select TEST PRINT.
    4. Use the up or down navigation key to select PRINT QUALITY.
    5. Press Menu/Set to confirm your choice. Press the Color(Colour) Start key to print the Test Sheet.
If one or more of the ink colors is still missing from the printed page, repeat the print head cleaning steps listed above up to 4 more times. After each cleaning, print the Print Quality Check Sheet to see if there is any improvement.
Jan 17, 2011 | Brother MFC-5840CN All-In-One InkJet...
How can you record an incoming call
To create a voice memo follow the steps below:
  1. While in standby mode, press the left soft key for Menu
  2. Select My Stuff
  3. Highlight Audio, using the navigation keys
  4. Press the left soft key for Options
  5. Select Record Audio (2)
  6. Press the center navigation key to begin recording
  7. Press the left soft key to Stop recording
  8. The audio recording is automatically saved
To Access My Recorded Voice Notes On SGH-a707? To review a voice memo follow the steps below:
  2. Select My Stuff
  3. Select Audio
  4. Highlight the desired voice memo, using the navigation keys
  5. Press the left soft key for Options
  6. Select Play (1) to review the voice memo
Apr 03, 2010 | Samsung SYNC SGH-A707 Cellular Phone
HOW DO I SET IT BACK TO ENGLISH LANGUAGE? ITS STUCK ON SPANISH.
Setting the front panel language
  1. Press the Menu button four times. When the Maintenance setting appears in the display, press Enter.
  2. Press the Right Arrow key four times and press Enter.
  3. The available languages will flash on the display, but they can also be accessed with the navigation keys. Select the desired language by pressing the Black or Color Start Copy button.
  4. Confirm the selection by pressing Black or Color Start Copy button again or press Cancel to try again.
  5. Press the navigation (ARROW) keys until the correct country appears in the display. Press Black or Color Start Copy button.
  6. Press Black or Color Start Copy button again to confirm the selection or Cancel to try again.
Dec 15, 2009 | HP PSC 750 All-In-One InkJet Printer
Print in light
1. Check TONER SAVE setting. If this setting is programmed "ON", all
printed documents will be light.
a. Press MENU/SET, 1 (General Setup), then 6 (Toner Save).
b. Press the top or bottom navigation key (keys located above and below
the MENU/SET key) until the display reads "Toner Save: OFF".
c. Press MENU/SET.
d. Press STOP/EXIT.
2. Check the PRINT DENSITY setting. This setting allows you to adjust
the print density from light to dark.
a. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 6 (Print Density).
b. Press the up navigation key (key above MENU/SET) to make print
darkeror the down navigation key (key below MENU/SET) to make print
lighter.
c. Press MENU/SET.
d. Press STOP/EXIT.
Oct 15, 2008 | Brother IntelliFAX 2800 Laser Fax
Fax machine
It is more likely that there is a setting or error... are you receiving any error msges or alerts when you try to fax out?
Just in case here are the steps to turn off fax memory
  1. Follow these directions to turn off the fax memory.
  2. Press Menu/Set.
  3. Press the up or down navigation key until Fax appears and press Menu/Set.
  4. Press the up or down navigation key until Remote Fax Opt appears and press Menu/Set.
  5. Press the up or down navigation key until Fwd/Page/Store or Forward/Store appears and press Menu/Set.
  6. Use the up or down navigation key to select Fax Storage (or Off if you wish to disable Fax Storage). Press Menu/Set to confirm your choice.
  7. Press Stop/Exit to exit the menu.
May 06, 2008 | Brother IntelliFax-2820 Laser Fax
Samsung SGH-ZV40 Cellular Phone Logo
95 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
