Non charging battery
I have a pavillion laptop that doesn't charge it's battery. i've replaced the battery, the cords and the port, but it still won't charge. someone said to check the motherboard but i don't know what to look for.
  • Niels Boehme May 11, 2010
    Does the laptop run on the power adapter?
    Usually, on the motherboard, you would check the solder connections on the receptacle that you plug the adapter in.
    (It may require extensive disassembly to check this.)
    There may also be a fuse for the battery, which if blown may prevent charging.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Dearest trinity esper, if *********** boards bad where the power hook up is best place to go to is
www.http://comprehensivecomputing.net they will fix any outlet or power prombelms for $99.00 dollars thier web site promises to get it fixed in 2 -3 days with in the time you send it ..It cost about
$12.00 to send it regular post ... I hope this helps lala linda
Posted on Jun 13, 2008
  • 114 Answers
Your motherboard might be bad, cause, the power to charge the battery, goes through the mobo, to the battery, so your mobo is probably bad. I do agree with nilrem, you might have worn off the solder.
Posted on Jun 10, 2008
Hp pavillion zv6233nr
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Rechargeable batteries will fail if stored in a discharged state for long periods.
May 05, 2013 | HP Pavilion Computers & Internet
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
T will indicate charging but it won't charge actor
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 23, 2012 | HP Compaq nc6400 Notebook
Hi I have a Toshiba laptop model no.psl2xu-ookoof and it doesn't charge anymore so what do I do
If the laptop works only off the Power Cord and the battery is not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let the latop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in and remove the power cord. If it won't boot or shuts down then the battery is dead and needs to be replaced if the power cord is ok.
Mar 26, 2012 | Toshiba Computers & Internet
My Asus Eee PC 1001PXD battery won't charge. The charges light is on but nothing happens and now the battery is completely dead and I cannot get my notebook on
Your problem is far more than the battery. Your problem is the power cord. Laptops for the most part will work off the power cord even if the battery is dead or even if the battery is not in the laptop. Your power cord charges your battery and if it is bad it will not charge it. You've been working off your battery even though you might have had the power cord plugged in, but if it's bad and not charging the battery, the battery drains and then you can't get the laptop to power on at all. Go purchase a ac adapter and power cord that is designed for your system. Don't buy one that some of the big box stores sell that has a an interchangeable plug at the end designed to fit just about any laptop. Those will eventually burn *********** board out.
Mar 20, 2012 | ASUS Computers & Internet
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
Won't come on after charging in usb hub
Depending on how long you've had the player, the batteries may need replacing.
I have seen a problem where the computer would not recognize the player and would not charge it, however.
First, I recommend trying to charge it directly from the computer USB port (not the hub) if possible. If that doesn't help, try reinstalling the software for the player to see if the computer will then recognize it and allow charging.
If neither of these fix the problem, it's probably time to replace the batteries.
Jul 13, 2011 | MyMusix PD-6070 MP3 Player
My phone won't charge and is about to die. When I put it on the charge is says "Unable to charge. Non supported battery." I've tried using the air in a can stuff on the ports but that...
You may have a hardware problem. It's very common for the charging port in a cell phone to become damaged somehow, which can cause this error. Other possibilities is a damaged battery or damaged power cord. Your best bet is to bring the phone to your carrier's nearest store and have them check it out for you. If it's the battery or the cord, a simple replacement is cheap and quick, but if there's a problem with the phone itself, you'll need to get a new one.
Jun 10, 2011 | Samsung Glyde SCH-u940 Cellular Phone
The charging indicator light no longer comes on when the laptop is plugged in. Just replaced the battery. Also tried a different power cord.
Possibly a failed or damaged charging port (does it feel loose)? After that, charger may not be chucking out the voltage (19.5 volts)? Test with multimeter set to DV volts, with one probe on the inside of the plug ant the other on the outside.
Does the charger LED light blink when connected (sign that power is not making a circuit)
If the above fail to work, then the problem is with the connector on the mobo, this may just be a Charger port needing replacing (wired or soldered version), or the charging circuit of the motherboard gone
Feb 10, 2011 | HP Pavillion DV6227 Notebook
Computers & Internet Logo
205 people viewed this question
David Payne
David Payne
