Question about Canon NP 6085 Copier
CANON 6085 PROBLEMS
HI, THIS IS MOHAMMAD NASIR I AM ENGINEER OF PHOTOPIER REPAIRING I AM FACING THE PROBLEM DRAWER 2ND WHEN WE CLOSED AND AFTER REACHING ON THE CENSOR IT'S CAME DOWN AND OPENED I DON'T HAVE SERVICE MANUAL FOR THAT PLEASE HELP ME ABOUT THAT
  • Canon Expert
  • 1,326 Answers
Was it working before the problem? Did the user have a paer jam? You may have a jammed pice of paper in the paper feed unit
Posted on Jun 12, 2008
    Scholar:
  • 92 Answers
1)try to remove the drawer by opening to max then lift upward .
2)take a touch lite ,after removing the drawer shine at the inner part
3)look for any fragment of paper stuck inside
4)remove it
5)good luck ,pls rate me thanks!!!!!
Posted on Sep 21, 2009
    Sergeant:
  • 199 Answers
Did you know some time this type problem occuring when IInd tray open switch is faulty (not released) so tray not fix. When you push some time this switch its work.
Posted on Sep 11, 2009
CANON 6085 PROBLEMS e214
error code E214 6085 machine problem solve pls
Apr 04, 2012 | Canon NP 6085 Copier
Error 012 in canon 6085
hi dear uyou have problem in the drum drive motor not in the feeder motor, coz E012 After the drum motor drive signal has been generated, clock pulses are not generated within 2 sec thays mean yours drum motor is not moving may be the faulty motor or may be the power supply for the motor.
thanks
May 16, 2010 | Canon imageRUNNER C3220 Color Copier
DVD drawer won't open. It whirs and tries to open but then after a few minutes, gives an error message. I'm wondering if one of the kids put a 2nd DVD in the tray and closed it. Is there a manual release?
There normally is a manual release hole you can open with a straitened paper clip, but you will have to open the unit, remove the drive.
Looking at the drive from the front facing the tray, the release hole is normally 1/4 from the right side.
Feb 28, 2010 | Televison & Video
I have canon 6085 very bad print and code error e012
Hello sir; Looks like the drum motor have problem, open back cover find out drum motor and look around have any gear broke if everything fine then replace motor that is necessary.
Jun 13, 2009 | Canon NP 6085 Copier
My photopier is loked
probably it can be reset,the procedure as follow;
1,power on
2, press follow by sequence;
"clear", "interupt", "0","interupt"
3,enter 14 press print
4, press "clear" to end this reset
5, good luck
Dec 13, 2008 | Sharp AR-160 Copier
Freezer door wont stay closed.
If you can pull the freezer drawer out, check to see if there is anything on the floor of the freezer. You can also try reinstalling the drawer. When you take the drawer out make sure that the spring loaded door catches on the sides are facing towards you. That is if it has any.
Dec 02, 2008 | LG LRFC25750 Refrigerator French Door
Canon printer error 073
The transfer drawer connector or the transfer frame drawer connector is not connected as the front door is closed.
Nov 04, 2008 | Canon imageCLASS 1100 Laser Printer
Hi & Thanks
Hello Mohammad Mans.
Only one solution is there get your cell formatted or flashed.
This will solve your problem.
Sep 01, 2008 | Samsung SGH-e315
CANON 6085 PROBLEMS
No image usually in developer charge area. drum may not be going around, charge coronas (wires) broke, etc. Does it have enough toner. I have seen no image because toner was not installed. Run dark copy and see if you can see anything...
Aug 01, 2008 | Canon NP 6085 Copier
Canon NP 6085 Copier Logo
250 people viewed this question
old marine
old marine
