Hello I have kyocera 1620 copier. It prints blank. Does it habe code problem. What do you think what might be its problem. No any toner or drum problem it has.
    Scholar:
  • 53 Answers
Blank copies?All sorts of things can cause that, for instance...
Drive to drum broken but paper is being pushed through, same with developer system.Does the machine have "corotron wires" (the wire that charges the drum, then transfers the toner image to the paper?) Check these wires are intact.Is high voltage being applied to these wires? Is there a paper clip stuck in the transfer corotron- it HAS happened-it shorts out the HV so there's no transfer current...
even a piece of paper can find its way between the drum and corotron and the copy paper can slide through and not be printed on! Not sure what you mean by"no any toner or drum it has"?
Does the exposure lamp come on...usually has a fault code if this fails, so unlikely
So...the problem is almost certainly related to drum /toner /development/high voltage areas
Posted on Jun 08, 2008
Hello how do I fix A-4200 problem on my copier Kyocera KM-1620?
C4200 CODE IS FOR A LASER UNIT PROBLEM, IF IT WONT
RESET BY TURNING IT OFF AND ON THE LASER UNIT NEEDS
TO BE REPLACED. EXPENSIVE PART FOR A COPIER THAT OLD.
May 21, 2015 | Kyocera Mita KM-1620 Toner Black...
How do I clear A-4200 on a Kyocera copier KM 2016
A C4200 IS A BAD LASER UNIT , EXPENSIVE REPAIR FOR A COPIER THAT OLD.
May 21, 2015 | Kyocera Mita Drum Cleaning Blade Km 1620...
What make the buttons of my Kyocera Mita KM 1620 stop working
the buttons stop working because the internal pressing are crash and you should replace it or join it by welding. but first of all you may blow the panel it could be some dust.
Sep 18, 2014 | Kyocera Mita KM1620 Black Toner Cartridge...
ALL KYOCERA MITA 1620 ERROR CODES
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Kyocera-Mita&model=KM1620
May 21, 2014 | Kyocera Mita Drum Cleaning Blade Km 1620...
Error E31 Kyocera KM 1620
this is an error code for slow warm up you should pull the fuser out and check the thermistors and condition of the rollers. sometimes the thermistors get caked in toner so they cant read the temps correct. if you take the unit apart you should be able to detect the toner build up. a soft clothe and some WD40 may be able to clean it off but be ccareful as too rough may clip ther resistor off.
Jul 12, 2010 | Kyocera Copystar CS-1620 Black and White...
Kyocera KM-1620 as a printer??
Yes, it can be connected as a printer -- see this page where you can download the print drivers:
http://usa.copystar.com/americas/jsp/Kyocera/download_center.jsp?pid=11917&pcat=10564&rcid=10009&rscid=10007#bottom
However, it may need an optional interface attached. Check the back of the machine to see if there is a USB port (the squarish one). If there is nowhere to plug in the USB cable, you may need to buy the printer interface option.
Jul 07, 2010 | Kyocera Copystar CS-1620 Black and White...
How many copies should a copier produce before changing a drum
I bought a km1620 copier. but copied only A4 size paper. No longer paper can not print except A4 paper. how can I change copying system. And how can I count copy. pls. mail me.
mizan
Jun 12, 2009 | Kyocera Copystar CS-1620 Black and White...
Kyocera fs-1920 printer fault
if the machine is starting up and you just replaced the toner cartridge make sure it is seated properly also did you shake the cartridge slightly before fitting sometimes the cartridge can compact the toner and it doesnt agitate to the dev unit properly. check also if the dev unit has been reset properly and the lever set in place..
Apr 27, 2009 | Kyocera Copystar CS-1620 Black and White...
Copystar/Kyocera 1620 error code: "C-6" and "400" (cylces back & forth once a seond)
so, just enter 10871087, press start, after enter 163, press start. thats all.
Feb 04, 2008 | Copystar CS-1650 All-In-One Laser Printer
Print on black line
You have to remoe the toner cartridge, then the developer section (one screw) then the drum unit (one screw also) Make sure you have the left side door open when removing drum unit.
Please don't forget to rate your answers please.
Dec 20, 2007 | Kyocera Copystar CS-1620 Black and White...
94 people viewed this question
k24674
jasbo
jasbo
