Question about Samsung Televison & Video
Choppy picture on my Samsung LNT5271F - Samsung Televison & Video
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 92 Answers
Could be cable or sat problem. If not you will need to take to servicer.
Craig www.clastorations.com
Posted on Jun 08, 2008
Choppy video play back
if the picture is choppy, the head must be tested , first you try to clean it with a cleaner cassette several times, if picture is not getting clear the head maybe faulty, change it.
Nov 06, 2015 | JVC 32x Optical Zoom MiniDV Camcorder
I have a Samsung LNT5271F Television and the screen is black. I have sound but no video. I can't even see the menu or volume button, nothing is showing up on the screen. HELP! :S
If the tv has more than one input, you should try switching to the other one. If it has another output(s), you should try the other output(s).
Oct 11, 2013 | Samsung LN-T5271F 52 in. LCD Television
Where I can get capacitors CM852 & CM853; 2200ufd 25volts from ? I have issue with power cycling (Samsung model LNT5271f )
These should be available from most electronics shops e.g. maplin, or on-line e.g. e-bay. Just search for 2200uF 25V capacitor.
Feb 24, 2011 | Samsung LN-T5271F 52 in. LCD Television
Picture on Samsung lcd LNT5271F is blurred sometimes lines color distortion double images then goes away and will come back. Part of the screen will go completely lines then come back. Starting to happen...
Had this exact problem diagnosed by a local repair shop as a bad LCD panel. According to the technician there's a loose ribbon cable on the panel and it would cost as much to replace/repair as a new TV.
May 12, 2010 | Samsung LN-T5271F 52 in. LCD Television
Picture on Samsung LCD LNT5271F is blurred sometimes, lines, color distortion, double images, then goes away and will come back.
Try reseating the LVDS cable.It runs from the main signal board to the T-con board at the top of the panel.
Dec 01, 2009 | Samsung LN-T5271F 52 in. LCD Television
Samsung model LNT5271f excessive relay cycling before full power
Howdy,
Yes, it is very easy to repair. Solder iron wattage should be at least 300 w.
The PSB is the center Board (towards left) after you remove the back off the TV. Remove the shield that covers the Boards and remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Good Luck, big IRISH.
Sep 28, 2009 | Samsung LN-T5271F 52 in. LCD Television
I have a Samsung LN-4061F with a TiVo HI Def DVR. When viewing HD programming the picture becomes choppy during action scenes. For example, during sporting events when the picture pans with the action,...
If your using a set top cable or satelite box then it is an issue with your HD service. Call them . They may need to swap out the box and check the signal. If you have no box then you may wana boost or/and filter your signal. You can purchase a signal amplifier online or at any radio shack or best buy. You may want to ask SAMSUNG if there is a firm ware upgrade for your TV.
Mar 29, 2008 | Televison & Video
Problem with 1080p via hdmi?
are you hooking up a 1080p source..if not then the set will not display the best picture in 1080p mode..
May 07, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
Televison & Video Logo
107 people viewed this question
Henry  Thomas
Henry Thomas
