Question about Philips GoGear HDD1830 MP3 Player
Cant switch it on!
I have a phillips gogear 2GB player. its stuck in its switched off mode. it doesnt respond to anything. it doesnt switch on nor does it get detected by the comp. i tried to reset it but in vain. nothing happened. its still switched off. please help.
  • 8,596 Answers
This could be a hardware issue (requiring repalcement), but try the "soft" fixes first:
Make sure the lock slider is not in lock position, and then try turning the player on again. Connect to the computer, and see if you get any activity. If all else fails, try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
Posted on Jun 11, 2008
Hi there! I recently purchased 2 Phillips Go Gear SA018 mp3 players, and I have the same problem on both of them...they don't switch on...any tips on that, please!? maybe I don't really figure how...
I have just purchased one and have the same problem. It charges with an orange light that doesnt turn green and then goes out when unplugged and then doesnt switch on. Pressed button over and over.
Did you resolve yours? If so how?
Jun 28, 2011 | Philips GoGear SA018 (2 GB) MP3 Player
Need to reset phillips gogear 2GB SA2627/37 as it displays PHILLIPS on start up & shuts down. On connecting to PC, it displays OK TO DISCONNECT and doesnt even recognized by PC as USB device.
Your player might hang up. Use a pen tip or other sharp object to insert the RESET hole gently on the side of the player and connect it again to your PC.
If it is still not recognized, your player may be at fault. Try the Philips Device Manager software and repair device with it.
Contents will be removed by using the repair function.
How to do it is described on the manufacturer's web site here:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&mid=Link_FAQs&view=aa12_view_partial.html&session=20110504030502_93.189.114.198&list=aa12_list_partial.html&slg=AEN&ctn=SA2627/37&dct=FAQ&refnr=0073454&faqview=1
Thanks.
gylacz
May 04, 2011 | Philips GOGEAR SA6045 MP3 Player
I have a Phillips GoGear (Marietta GA 30006-0026) 2GB Mp3 player but i have lost the installation disc software. How do i go about downloading this?
Aug 06, 2010 | Philips GoGear SA3125/37 MP3 Player
Philips GoGear HDD6330 MP3 Player will not sync music files onto it? How do I fix that and has deleted all previous ones! Please help>
This could be the player's connection mode in combination with your synchronization software. If you are using Windows Media Player or Philips Songbird to sync, the player will need to be set for MTP connection mode. Most other software that works with regular flash drives will need the player set for MSC connection mode. Whatever you are using, simply try the other mode.
To change the connection mode, select "PC connection preference" in the Settings menu of the player.
If you found this information helpful, please indicate as such.
Apr 12, 2010 | Philips GoGear HDD6330 MP3 Player
How to charge phillips mp3 2gb player with fm radio gogear
found mp3 player phillips gogear in street need to know how to charge it.Dont have manuel.
Oct 15, 2009 | Coby MPC-848 MP3 Player
I pod
Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab.  Then click on the “Repair” button to start the repair process.  Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in.  If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
Philips GoGear Firmware Upgrade
You need to get the latest firmware upgrade from the Philips website:
1. Go to www.philips.com/support
2. Enter your country/language
3. Enter your model # SA6045 or whatever
4. Click on the link for your exact model # (the one w/o the "B" in it)
5. Click on "Software & Drivers"
6. Download the updated "Device/Firmware Manager"
7. Once installed, open the Philips Device Manager
8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course)
9. Your Mp3 players firmware will update automatically
If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date."
-Tha Mp3 Doctor
Aug 28, 2008 | Philips GoGear HDD6330 MP3 Player
Philips gogear 2gb player
all of you are having different issues
1.Reset
2.Run the repair in device manager
3.Run recovery mode: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jul 07, 2008 | Philips GoGear HDD6330 MP3 Player
Phillips go gear stuck on Repaired all contents cleared!!!
i held the volume+ button in while i plugged the usb cable. the computer recognized new hardware was found. i opened the phillips device manager and hit the repair tab. it automatically ran a repair through the mp3. then i installed new firmware through the phillips device manager. i lost all my contents but windows media 11 sync all my music back. THANKS ANYWAY!!!!
Jun 27, 2008 | Philips GoGear SA178 MP3 Player
2gb Phillips go gear
Some older Philips models are not compatible with Windows Vista.
Which model do you have?
May 26, 2008 | Philips GoGear SA178 MP3 Player
Philips GoGear HDD1830 MP3 Player Logo
117 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
