Question about Maytag M7Q08F2ACOM Air Conditioner
How to remove cover of model M7Q08F2a
How to remove cover to clean coils
Need help wih dehumidifier Kenmore model#2519970180000451
well first ive never read in any manual that tells the homeowner to remove cover on any apliance , in fact the only cleaning ive ever read is clean the filter , this is right in front on side and slides right out and can be washed in sink with soap and water (do not scrub) but yes cleaning the condenser coils will require you to remove cover this is purposly made somewhat a challenge to discourage homeowners from hurting them selfs as there are live electrical parts and sharp edges inside , i sugest a qualified appliance repairman be contracted to have a look
Oct 16, 2014 | Dehumidifiers
My dehumidifer runs but no water is being pulled out
Might be a dirty coil and condenser.
I have had a AD75UST0 WHIRLPOOL Dehumidifier for several years. If it actually still runs, I would suggest you take off covers and give the coils a good thorough cleaning. Otherwise the units are not designed to be serviceable aka - "disposable small appliance". if you do dispose of it take it to a qualified recycle organization for Freon products. Shut unit off. Remove "bucket". You should find a "tab" at top of where bucket goes in middle front of unit. Pull down to remove tab of Filter. Clean thoroughly and dry Filter before re installation. Visually inspect the coils and condenser while filter is out ( a flashlight helps). If it looks slightly dusty or like covered in felt, then it would be wise to remove front and rear covers and give the coils and condenser a thorough cleaning.
WHIRLPOOL DEHUMIDIFIER Parts Model ad75ust0 Sears PartsDirect
Apr 18, 2013 | Whirlpool 75-Pint Dehumidifier
How to clean front cover M7Q08FZA
Spray with kitchen degreaser with filter gauzes out but cover closed. Allow to soak for 10 mins. Brush with nylon brush (dustpan brush) or old toothbrush to get into all the crevices then rinse with warm water from a garden low pressure sprayer and vacuum dry with a vacuum cleaner. Refit filters and run to check
May 17, 2012 | Maytag M7Q08F2A Thru-Wall/Window Air...
What is the btu of this model.m7q08f2a.
Hi, to find out the tonnage of your unit in b. t. u.'s, look at the 08 in your model number. There are 12,000 btu's per ton of cooling. You have a window /wall unit, and according to the model # 08 is not a 1/2 ton or a 1 ton, but a 3/4 ton unit or 8,000 btu's if indeed this is the correct model number. Most units we come across are in btus as 06 which is 1/2 ton, 12,000 is 1 ton, 018 is 1 1/2 ton and on up with a properly matched indoor coil. Your unit is a package window unit, so both coils are equal.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Nov 18, 2010 | Maytag M7Q08F2ACOM Air Conditioner
How to clean dirt that gets by filter of window air conditioner M7Q08F2A
Both the evaporator and condenser coils (inside and outside) can be safely cleaned with products specifically made for the job. Clean evaporator and condenser coils mean more efficient cooling - which means lower operating costs. Cleaning the coils can remove stale or other less desirable odors that originate from your air conditioner. An example is made by Thermwell which is available at Lowes and other hardware and home improvement stores. There are many different manufacturers of the cleaners - so if this particular brand isn't available at the store you shop, another will do. Different brands and types have different methods - so you should read and follow the directions on the can. Many of the canned foaming / spray type cleaners are "rinse free" - meaning it is not required to rinse the foam off - as running the unit will allow the condensation that forms of the coils to do the rinsing for you. It should be noted that window / thru the wall types and other non-central air conditioning units should be tilted so that the condensation and chemicals drain outside - not into the house. If your AC hasn't been dripping water inside, it should be fine. Usually all that is needed is to remove the front grill and filter to access the coil. With the unit off (preferably unplugged) spray the foaming cleaner into the coil and let it sit to work on the dirt, grime, mold, nicotine, etc. that has collected on the coil. When the last step of the can's printed directions are complete - the job is done. You can find some helpful videos on Youtube to show how the cleaning is done on the larger, central air type units.
Please rate this reply if it was helpful to you - good luck!
Aug 04, 2010 | Maytag M7Q08F2ACOM Air Conditioner
Need change plugs on 99 grand marquis gs how do i remove coil .do P meed to dopressurize anyting
Ford Crown Victoria, Mercury Grand Marquis, Marauder, Lincoln Town Car 1999-2005
Ignition Coil - Removal & Installation
  1. Disconnect the negative battery cable.
  2. Disengage the TFI-IV harness or the engine control sensor wiring connector from the ignition coil, as applicable.
  3. On the 3.8L engine, disengage the engine control wiring connector from the radio ignition interference capacitor.
  4. Remove the ignition coil retaining screws and the ignition coil and radio interference capacitor (if equipped) from the ignition coil mounting bracket.
Fig. Ignition coil and related components-late model 3.8L shown
Fig. Remove the ignition coil retaining screws
Fig. If your coil has this kind of build-up, it needs a good cleaning
Fig. This is the coil wire. Replace it if it looks like this
  1. Remove the ignition coil cover from the ignition coil by releasing the locking tabs on both sides of the cover, then remove the ignition coil.
To install:
  1. Install the ignition coil, then attach ignition coil cover, making sure the cover is firmly in place.
  2. If removed, connect the ignition coil and radio interference capacitor, then install the ignition coil retaining screws. Tighten the retaining screws to 25-35 inch lbs. (3-4 Nm).
  3. Connect the coil wire, then engage any electrical connectors that were removed.
  4. Connect the negative battery cable.
Hope help with this (remember rated this post). TY for using Fixya.
May 19, 2010 | 1999 Mercury Grand Marquis
How to Clean 1984 TRANE Cooling VENTS inside house No Manuals
The Outdoor unit will be easy 1st diconeect power at panel, or disconnect box near unit. Remove top of unit, be careful not to damage fan blades. Spray coils (fins) with a light degreaser let is soak for 5 mins. wash out coils from inside the unit out. Spray straight on so you push the dirt out the other side.
Re assemble and start up.
Indoor coil will be accessed by removing front cover and you may have another cover to expose the inside of the coil fins. That is where you need to clean. Spray degreaser on coils and rinse off. If its gunked up then use a wire brush 1st. Carefull not to bend the fins over.
Check the drain pan at bottom of the coil to be sure it's not full of stuff. Blow out if needed.
You should be clean and ready for the season
Jul 02, 2009 | Ruud Central System Air Conditioner
Air does not come out
These are a few questions you must ask yourself. Is the fan motor running. Is the evaporator & blower motor clean
May 18, 2009 | Maytag M7Q08F2A Thru-Wall/Window Air...
Removing grate cover to get to the coils so they can be cleaned
MOST GRATES JUST POP OFF,DEPENDING ON YOUR FRIG. MODEL,YOUR COILS ARE ON THE BACK BOTTON BESDIE THE COMP. OR RUN SIDE TO SIDE A LONG THE FRONT,YOU REALLY HAVE TO GET THE GRATE OFF AND LOOK UNDER TO SEE WHERE YOURS ARE,IT IS
IMPORTANT TO CLEAN THEM ONCE A YEAR-MIKE
Mar 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Maytag M7Q08F2ACOM Air Conditioner Logo
220 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
