Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Tv comes on for a few seconds only
I replaced both convergence chips .now it comes on for a few secs then turns off .the power light in front blinks. I have to unplug to stop.I didn't check the resistors or any other caponets . didn't have this problem before .only convergence.
  • diditnow Jun 08, 2008
    philips projection tv model60pp9202/17f
    coulda bad convergence chip cause this .i just replaced them
    Novelist:
  • 142 Answers
Check the main power capacitors and could you plz tell me the Model and the make of the TV
Posted on Jun 08, 2008
  • Rohit Chadha
    Rohit Chadha Jun 08, 2008
    yes it is a power supply related, it's chirpping usually something is
    shorted or using to much current draw, it's not nessassarly the power
    supply but something causing the power supply to do this
  • Rohit Chadha
    yes, they go bad interment because they have a large current go thru
    them and they generate heat, they are mounted on a heat sink with white
    silicone to help disapate heat. replace both not just one, try MCM
    Electronics get heat sink compound also
    Genius:
  • 1,847 Answers
May the the tv model #
The power on no piture
If the power light comes on (green) for a few seconds and goes off:
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Nov 06, 2012 | Mitsubishi WS-73713 73" Rear Projection...
How to replace cicuit breaker mitsubishi ws 48511
It does not have a circuit breaker but if green light comes on for a few seconds and goes off:
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
Oct 29, 2012 | Mitsubishi VS-45609 TV
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Replaced a convergance chip..(ps8003) now tv
hello Eight GA_googleFillSlot("TL-IMU-Article"); blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board
regards
shaun
Feb 24, 2010 | Sony KP-46WT500 46" Rear Projection...
IT COMES ON FOR THREE SECONDS THEN CLICKS AND TURNS BACK OFF. ANY TIPS?
hold the input and menu button down on the front of the set for 5 seconds then release. The power light should start blinking a code. 2-2 is a convergance chip problem
Feb 04, 2010 | Mitsubishi WS-55807 TV
Turn on the power and the green LED blinks on the front for a second, but tv does not power on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
Jul 30, 2009 | Mitsubishi WS-55411 55" Rear Projection...
The set does not come on. The red power indicator blinks on and off for a few seconds, stops for a second or two, then blinks again for a few seconds, stops again, etc...
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Jul 10, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Red power light blinks 9 times
Either a missing cable or you shorted the chips when you soldered them back into the TV.
May 29, 2009 | Philips 60PP9363 60" Rear Projection...
Panasonic PT-53TW53G
Aug 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Power on, then off- blinking red light
I have the same problem. I took the back off and it appears that the Green light has gone out. The TV will not run with out all three lights. I am looking for just the green light, but all I can find is the whole unit for almost what the tv cost.
Oct 01, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
