Question about Cameras
I have a problem with Olympus FE-280 Digital Camera, this camera displays an error that reads: PROTEC. ESCR, i read other solution but it hasnĀ“t got the switch, help me
Tengo mi camara dijital que me muestra un error dice protec desc que puede ser ?
Posted on Nov 09, 2010
SOURCE:
In olympus fe 280 when i have placed the xd in the camera and turn on the camera then it displayed two options either to clean up or format then i have chosed format then it displayed after some time like...
A camera memory card should always be formatted IN the camera.
Do not format camera memory cards in a computer card reader.
If the card is formatted in the camera and after that the same error pops up,
you should replace the memory card and recheck.
Jun 15, 2011 | Olympus FE-280 Digital Camera
My olympus camera cannot connect to the computer.i need driver for olympus FE-280
The camera is a AutoConnect camera and uses the driver usbstor that is located in windows. when you connect the camera to the computer, you should see PC highlight on the camera screen. Press ok and the camera should display one moment please then go blank. It should be able to see the camera through computer or my computer icon.
Jun 06, 2011 | Olympus FE-280 Digital Camera
My camera Olympu FE-340 is locked, it got locked when i conected it to my laptop, i can transfer the photos i have in it to my laptop, but when i want to take photos the screen gets black and red letters...
Perhaps the protection slider on the memory card has slipped into the locked position, or is there a 'protection' or 'favourites' setting in the camera menus?
Dec 11, 2010 | Olympus FE-340 Digital Camera
Buenos dias tengo un problema con mi camara es una olympus con memoria xd picture card la prendimos y no podemos sacar fotos ni filmar nos aparese la palabra protec escr con signo de admiracion que puede...
Desde el menú de la cámara formatea la memoria.
Si no funciona, formatéala desde la PC.
Si no se formatea en una PC, la memoria está defectuosa. Compra otra.
Nov 09, 2010 | Olympus FE-240 Digital Camera
This camera displays an error that reads: PROTEC. ESCR
Some memory cards have a Write Protection switch on them.
To check this please remove the Memory card from the camera. Check if there is a "lock" switch on the left side.
Slide this switch to the "Unlocked" position, and reinsert the card into the camera.
This should resolve the issue and the error should go away.
In case the issue persists, it could mean the the write protect on this card was perhaps set by mistake while it was connected to the computer.
You will need to use the computer to cancel the read-only setting.
Please connect the card to your computer through the camera or a card reader and cancel the write protect on the card.
This will resolve the issue you are facing.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will look forward to your feedback and positive rating.
Sep 10, 2010 | Olympus Stylus 1010 Digital Camera
Al prender mi camara digital alympus dice protec. escr que hagO.?? pOr favOr aiiudaamee
When this problem occurs Protec. Escr., Just enter the tools menu and find "Format" and voila, the camera returned to work usually remains
Aug 27, 2010 | Olympus FE-240 Digital Camera
Protec. Escr. ¿qué significa esto?
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Jul 28, 2010 | Olympus FE-240 Digital Camera
How do you get Olympus FE-280 to display time date?
Hello
I think the manual will be best to explain exactly how to do this. Just click o the link below, you will be navigated to the download page.
http://www.retrevo.com/support/Olympus-FE-280-Digital-Cameras-manual/id/3256dj697/t/2/
Kind regards
Andrea
Jan 04, 2010 | Olympus FE-280 Digital Camera
Cameras Logo
274 people viewed this question
Top Cameras Experts
Marvin
Marvin
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Camera Expert? Answer questions, earn points and help others
