Actiontec (GT704WG) Wireless Router Lights
The Internet, Ethernet and Wireless lights flicker a lot. Is that normal? Does it imply anything?
The power and DSL lights are solid.
  • 47 Answers
Yes, this is normal. The flickering lights are showing activity - data is being transferred when the light is on, and vice versa. The power light should always be on when the unit has power. The DSL light should be solid as long as your DSL line is connected properly.
Posted on Jun 11, 2008
When power switch is turned on the Power light is rapidly flashing & the 4 Ethernet lights are flashing. The box is Actiontec GT704wg
I do not have a solution to the problem. However, I am having the same problem. This morning the Actiontec GT704WG power and ethernet lights were rapidly flashing. The modem was non-functional. I could not even connect to the modem through the browser to see if I could find a problem.
The problem lasted a couple of hours. Then all of a sudden the modem started working again. I won't be able to tell if the problem recurs until I restart the modem. And if the problem does occur again, I won't be able to connect to the internet.
Oct 08, 2009 | Actiontec GT704WG Wireless Router...
Actiontec (GT704WG) Router wireless access point problem
first of all try to turn the router of, wait for atleast 5 mins and then turn it on, if it still doesnt work,
click on start on the bottom left of ur screen
click on run
type cmd and click on ok
on the black screen type ipconfig
look for ethernet adapter local area connection
take down the default gateway written ther it is usually,
open internet explorer, type these no.s on the address bar
it will ask for a username and password, if you havnt changed it
it will be
username:- admin
password:- password
then click on wireless setup and c if wireless is turned on or off, turn it on if its off and then click on apply
if its on already, turn it off and turn it on again
check if this works. else we will have to reset the router but then u will loose all the settings on it done by your isp (if any)
Sep 26, 2009 | Actiontec (GT704WG) Router
Power led solid red, internet led solid green
This is a sin of a bad unit already, first thin that you can try here is to reset the router by pressing the reset button of the device for 30 seconds , but after that and still the same light better contact your device manufacturer...
Sep 15, 2009 | Actiontec GT704WG Wireless Router...
After several years of service, now my Actiontec
electronics like these usually have a reset button behind them, try it. If not, it could be a problem of age, since staying on 24/7 for years really wears electronics out.
Aug 22, 2009 | Actiontec GT704WG Wireless Router...
Power Light Is Red, Internet Light Is Green, Other Lights Off
Check cable connections.
Try unplugging router from power for five minutes.
If that does not work call Internet Service provider to check if there is a problem with their server.
Apr 10, 2009 | Actiontec GT704WG Wireless Router...
Unable to Access GT704WG Router with Laptop
normally there is a small hole for reset to factory default, just put a pin inside...
Other than that, u can also connect using network cable and access the router configuration, inside, u can edit the wireless security keys
Feb 27, 2009 | Actiontec (GT704WG) Router
Wireless router on but not working
Who is your ISP? I belive what you have is a modem router. If the interney light is not lit then it only mean that the actiontec is bridged and you need to use a dialer on your pc to connect to your ISP. If the internet light is lit, no need for a dialer just connect it straight to your pc and check your internet.
Aug 25, 2008 | Actiontec GT704WG Wireless Router...
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
May 01, 2008 | Actiontec GT704WG Wireless Router...
Actiontec wireless router
This is a Wireless Gateway not a router. Although the Actiontec website says that it uses NAT firewall like a router would.
If you do not get any green lights this usually means the wireless gateway is broken. Try plugging it into power but not the modem. Wait a few seconds. Are there any green lights?
If so, then the gateway is not configured correctly to work with your modem. You may have a smart modem. Call your ISP, for help.
If not, then it is probably a bad gateway. You can try to connect to the configuration web page that comes with the gateway. OR Power on the unit while holding down the Reset button for a minute. This will reset it to factory defaults.
Nov 20, 2007 | Actiontec (GT704WG) Router
Computers & Internet Logo
271 people viewed this question
David Payne
David Payne
