Question about ASUS A8V Deluxe Motherboard
Asus a8v deluxe mobo no start
With power supply switched to on, i pressed power button to start. the cpu and case fans will spin momentarily and stop.
i then tried pressing the power button again and nothing happens.
i then turned power supply switch off and i unplugged all powered components and tried again with same result.
i turned off the power supply switch and turned it back on again and the fans again turned momentarily and stopped about 2 seconds later.
i pulled the main 24 pin power supply cable from the mothrboard and connected to a simple power supply tester and it showed that power supply was working with green light.
i reconntected the 24 pin cable and tried a restart again. this time the box powered up and a voice message came which said "system failed cpu test" repeatedly.
i shut down and tried again and now it won't start with the fans turning momentarily and stopping again.
i'm thinking of flashing the bios to try to get it going again. should i?
    Novelist:
  • 142 Answers
This is a NO POST scenario
How to troubleshoot No POST
1. Check wall socket whether power is working fine
2. Check PSU (Power Supply Unit) fan whether it is rotating or not.
3. Change power socket.
4. Change the the main power cable from the wall socket to the PSU.
5. Check whether the lights on the keyboard flash when you turn on the power.
6. Check the voltage selector swicth at the back of the PSU ( Ideally should be 115v for US region and 220v for Asia ).
7. Check all peripherals like keyboard, mouse, video cable whether they are connected properly or not.
8. Open Chassis >> Check RAM connected properly.
9. Remove add-on cards like graphic cards, modem card, PCMCIA card slots, LAN card etc.
10. Take out main power connector (grey-black) or brown, green cable from front board panel of cabinet from where you turn on the power for CPU. and also take it out from the motherboard,
11. Check I/O cable which comes from power button on cabinet whether it is firmly connected nor not.
12. Plugg all the cables back in.
If still u face the same problem Then
13. Take out CMOS battery from motherboard and press power on/off button for 30 seconds and plugg CMOS battery back in to the motherboard.
ram chips swapped out with a known working chip of the same type
HDD swapped over with the HDD out of my portable external backup HDD
FLASHING A BIOS:
A couple of items are really important if you decide to flash. First. Make sure the updated bios addresses the issue you are trying to solve. eg many motherboard makers update their bios's for many different reasons. A reason may simply be to get a certain big name brand of pc to work correctly with a new cd writer big brand pc is selling.
So you really have to read the docs so see if the upgrade addresses your specific niggle or concern. Secondly, try your motherboard maker first to see if they have the files you need. Bios's upgrades are best had, if available, from the company that made your motherboard or pc. In most cases these are free.
Thirdly, READ THE DOCS CAREFULLY AND FOLLOW THEM TO THE LETTER. Dont skip any steps, especially the backup option if available. Fourth, if the upgrade calls for a clean bootdisk, use one. The disk I made especially for bios flashing is the one you can download above. It's a DrDOS bootdisk with NO drivers loading up in config.sys or autoexec.bat which is very important. My bios flash bootdisk is recommended by the most popular motherboad makers.
If you dont have a 1.44 drive I also created a utility to use to flash from a CD which you can add the new bios and flash utility to and then burn it.
It should have room to add your new bios, the flash utility, and also have room for the backup. If not one can always use another disk for the info. Always use BRAND NEW MEDIA when dealing with flashes.
In order to locate the correct bios upgrade for your motherboard you need to know who made it AND you need to know the model number. If your PC was made locally perhaps you have the manual. If not, then you need to find out the maker and model. Or, and very common with major brands, your computer maker will/may have the updated bios's on their website.
I have one windows and three dos utils that find your motherboard maker and model number. One of them should work for you. The DOS utils are on my DOStools Page under Diagnostics, and are called CTbios, MBID, and HW iNFO. The windows utility is called BIOS Agent and is on my Utilities Page under Hardware .
Once you ID your motherboard and model go the the manufacturers website and see what they have available. Note that some upgrades will come with their own bootdisk/utility so you may not need the disk I made.
Again, note that even tho many people flash their bios regularly to get the latest features and never have a problem, I still recommend it as a last resort as a flash gone bad will make your pc unusable if the backup doesn't work. Look at it this way, suppose I have a used 80 gig drive I want to resuse and my old P400 cant even detect it so I have an unusable pc. This is the best, and most common reason to flash.
On the other hand, if you have a more modern pc that cant see lets say a 180 gig drive and but all else is working properly then you may want to consider a PCI hard drive controller card which has an onboard bios that will see your new large hard drive and also come with 2 more IDE channels you can use in addition to the 2 channels you already have. This is safer than flashing the bios.
Posted on Jun 08, 2008
I seem to have a problem with the power to my computer. After 2 days of searching all kinds of forums I still haven't found a solution. The computer won't power up, no fans are spinning, not a...
First remove the power plug from the smps and press the power switch few time and wait for few minutes the re plug the power connector to the smps and switch on the computer if you still dont have power then you will have to check whether the smps work to test that its not enough to test the voltage in the 21/24 pin you will have to short the green wire and the black wire and see whether the smps fan is working if the fan is not working then the problem is with smps
Jul 30, 2011 | ASUS Computers & Internet
I'am working on ASUS P5PE-VM mobo, I removed the memory, video card and isolate the mobo away from the casing so no short circuit may occur during test. I plugged in the power supply and the front switch...
HI,
Clear CMOS or remove CMOS battery, Press the on off switch for 30 seconds.
Now go to BIOS setup,and set bios fail save default,and press F10>enter.If the problem same change the RAM if you have a spare.
http://www.computerhope.com/help/phoenix.htm
Hope it helps.
Jan 13, 2011 | ASUS P5PE-VM Motherboard
My power supply died (popped), so I replaced it (Antec SL350 with an Antec SL350S). However, when I turned on the switch on the back of the power supply, the motherboard powered up immediately (tower...
If you "popped" the power supply, I would check to see if the RAM might have taken a hit as well. Ram chips and CPU are sensitive when it comes to power surges. I would troubleshoot the system, unplug everything. you need monitor, power, cpu, and ram (1 at a time). Check to see if the system will POST. if you do get it to POST, start with 1 item at a time and see if the system will POST every time. If nothing happens, there is a chance you may have a damaged motherboard or cpu.
Mar 28, 2017 | ASUS A8V Motherboard
I am slowly rebuilding my computer. When I nearly got it finished, and turned it on, it came up with "Windows Was Not Found". Knowing what to do, I turned everything off, unplugged it properly, and...
Check for motherboard. use only 3 parts:
motherboard
PSU
CPU + COOLER
Connect your motherboard to PSU and see, if any LED light comes from motherboard. If LED is on, then try to turn motherboard on and see if cooler works.
Are case wires (power +, power -, hdd +, hdd -, reset+, reset -, power led+, power led - and speaker wire ) connected correctly?
Those wires look like this:
front-panel-headers-nsatmeh50lx5u1woeaeqllmn-4-0.jpgThis image is just reference.
If the power wire (sometimes called POWER SW) is not connected correctly, when you press the power button of case, PC just won't turn on.
If PC turns on and CPU fan spins, then try to add RAM, Graphics card and try again.
Next step is to hear BEEP sound. One short beep sound is normal, anything else is not normal and indicates the problem of the specific hardware according to the sound code. Sound code is BIOS dependent. In case ASUS A8V-E Deluxe, it is Award BIOS. Check below for Award BIOS beep codes
1 long, 2 shortIndicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information
1 long, 3 shortVideo card not detected __ (reseat video card) or bad video card
Beeps repeating endlessly __ RAM problem.
Repeated high frequency beeps while PC is running __Overheating processor (CPU)
Repeated beeps alternating high & low frequency ___Issue with the processor (CPU), possibly damaged
Mar 17, 2017 | ASUS A8V-E Deluxe Motherboard
Hi. my CPU (system) does not start. When i press the power button, the light turns on for a second then nothing happens.
Does the power supply fan spin when you switch it on ??
Do you hear a"posting" beep??
Does the CPU fan start to spin??
If no to all of these probably dud mobo.
Dec 21, 2009 | Intel CPU
Motherboard flashes when power cord plugged in
I had the same issue with the same mb. The cpu has gone bad. rare, I know, but it happens.
Dec 15, 2009 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
I have bios version 1008 on the computer. Should i update the bios version to the newest one? The fans are always running, they never shut down
Actually if your MOBO are working fine as of now no need to update the BIOS version. Updating BIOS version may affect some parts of MOBO so no need to update the BIOS version.
Regards
nicole
Oct 03, 2009 | AMD Asus A8V Deluxe Socket 939 Motherboard...
ASUS A8V-VM MOBO
To turn your computer off, hold the power button in for 6 to 8 seconds. I would disconnect the fans you installed to see if you are loading your power supply. If you install a video card take it out and in a couple time to clean the contact, with the power off.
Oct 11, 2008 | ASUS A8V-VM Motherboard
Asus a8v-vm se fans always run
Hi jderek4, try this. locate the toggle switch on the back of the power supply. Just find it do not flip it.
Plug the PSU's power cord into the PC. Just as you got a good connection & the PC begains to power up move the toggle switch to it's other position. The PC should power off that very second.
If the PC does not shut off than the PSU is bad. If it did shut down wait a few seconds. Press the cases power on button. The PC should start to boot up. Let it finish loading. Click the start button & choose to shut down windows. The PC should shut off.
Yes? If not than your back to (bad power supply). Swap it out.
Mike
Mar 29, 2008 | ASUS A8V-VM Motherboard
ASUS A8V Deluxe Motherboard Logo
292 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
