Question about Toshiba 57H82 57" Rear Projection Television
Toshiba 57H82 Blurry Pic on HD inputs except Xbox 360
Video component inputs into HD1 or HD2 shows a digitally distorted picture. Xbox 360 connection is crystal clear, and cable shows up fine. But DVD, laser disc, and vhs are totally unrecognizeable. A DVD played in the Xbox also is blurred up. We currently run through a receiver so it is odd some signals go through and some don't on the same cable. We have tried direct inut by pasing the receiver and no luck. We have taken equipment to a 2nd TV and plays fine. Something in the Toshiba seems to not want to receive certain signals.
  • felesae Jun 09, 2008
    Thanks. We will look into that. She's only 6 years old, have to weigh the price of repairs vs upgrade. Nice to have a ballpark to start from.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 92 Answers
Probably your G-Hyper board. You will need expert servicer and should cost about 3-400.00
Posted on Jun 08, 2008
How should I connect a Sony Wega KF-50WE620 to an XBox360 ?
Since the TV accepts HD signals only via DVI and component inputs, the only logical way is to use the "Xbox 360 Component HD AV Cable" as show in the link below:
How to hook up your Xbox 360 or Xbox 360 to TV
The TV will not accept a VGA input. A cable converting HDMI to DVI would also require that you break out the L + R audio channels, too. The one I mentioned above does this all for you with no degradation in video signals.
Mar 26, 2015 | Sony Grand WEGA KF-50WE620 Television
We lost picture (no picture) through cable portal. Tv has blurred picture using HD wire connection via HD1 & HD2 Portals. As tv warms up picture slowly clears. The problem has progressively gotten...
hyperunit failure. that tv uses whats called a " next hyper-unit" it is the digital scan card for the tv. it does the video and audio processing for the tv. they can be very heat sensitive and get better ot worse over time. the repair is very involved i suggest calling a repairman.
Dec 22, 2010 | Toshiba 57H82 57" Rear Projection...
I can't switch the picture size. When i hit the pic size button, it tells me it's not available. I tried changing the pic size with the tv/video input on our dvd, but it won't change it when its on out hd...
defective hd cable box is possible but each unit has its own picture size adjustment. use your cable box remote and change size there. use tv remote to adjust tv size to auto. dvd the same thing
Nov 10, 2009 | Toshiba 57H82 57" Rear Projection...
My Xbox 360 will not show a picture you can hear the sound but there is no picture.
1) make sure the video cable is firmly inserted into the back of your xbox 360. Sometimes a loose connection will produce this result.
2) Check the end to your television set and make sure it is in correctly. Is this HDMI ??
3) Cycle the inputs on your tv until it gets back to your xbox 360 and see if the picture appears.
4) If you have this hooked up via HDMI, connect it through another method and go into the video settings in your xbox 360 dashboard and set them to auto detect.
Let me know if this helps.
Jul 28, 2009 | Microsoft Xbox 360 Console
Xbox 360 and bose surround sound no video
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables). -Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
May 31, 2009 | Microsoft Xbox 360 Pro System Console
Its not broken or nothin i was wondering how to put the input for cabel from cable/sat to colorstream hD1
Cable boxes or satellite receivers typically only come with audio/video output, RF output, and component output. You need an upgraded one which has the Hdmi output jack. The upgraded box will cost you a service fee around $5-10 a month, so if you don't want to pay to receive the 1080p service you can receive 720p by using the component video output leads from your cable box.
The quality is almost as good. The only difference will be that you won't be able to receive the hi-def channels that the cable company offers.
Apr 29, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba TN55X Convergence problem.
You brought up an issue that we hadn't considered. Shortly after hooking up our TV to the receiver with a composite video, our convergence which wacko. My hubby replaced the 2 ICs, but now our power button just flashes red, with no picture. Not sure if new ICs are faulty or if it's another issue. He will replace old ICs to see if problem still exists with turning on the tube. And he'll try disconnecting the video signal to see if problem exists.
Ouch.. may have to consider another tv thanks to new technology ??????
Good luck solving your problem.
Jul 06, 2008 | Toshiba TN55X81 55" Rear Projection...
57H82-no picture from DVD input
How does line out from the DVD player do? I would suspect a bad preamp/buffer on the TV...accordianman
Mar 17, 2008 | Toshiba 57H82 57" Rear Projection...
Tv only watchable through component Toshbia 57H82
this is a known problem with these toshiba tv's, they will do nothing to help you we should form a consumer group and complain to Washington! The part that needs to be replaced is a hyper pcb,pd0637and is available from Tritronics, in Miami #1-800-365-8030.the part cost me $263.00
Dec 06, 2007 | Toshiba 57H82 57" Rear Projection...
Wavy picture on all video inputs except component video toshiba 57h82
make sure you replace all the 10uf caps and that the connections are good....
Sep 20, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H82 57" Rear Projection Television Logo
149 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
