Question about Goodman CKL36AR36 Air Conditioner
No cooling I received a call from my tenant that they have no ac. When i get my inspection of the unit to find an extremely durty air filter, which i replaced. Also i cleaned the a coil which was also full with dust. So i figured the time it took me to to do all that cleaning that the unit had time to reset it self. Long story short i still have no cooling at all still. through the first sequence of operation every thing seems ok . dtill no cooling
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
"You forgot the "first rule , check to see if everythings is working! If the filter was dirty , then you skipped the second line of defense to prevent dust from going into the vents is the squirrell cage blades. Air flows thru the filter first,,,2ond, thru the squirrell cage...& 3rd thru the coils last. Make sure the outside is working fine.
Posted on Aug 23, 2008
Why does the aircon cant stay on
Most modern air conditioners are designed to offer up to 10 to 20 years of reliable use. However, even the most reliable of air conditioners may stop cooling or suffer from problems from time to time. Remember that one of the best ways to prevent unexpected A/C problems is to have regular maintenance performed on your unit. If you cannot perform the maintenance yourself, hire a professional to do so. Spending money on maintenance now can save you from big repair bills in the future.
Some of the most common AC problems are listed below, and they may even be the reason why your air conditioning unit won't kick on. Review this information so that you know how to best troubleshoot problems with your unit. Be sure to determine whether your unit has shut down entirely or whether only a part of your unit has shut down or isn't working. Remember that it is always necessary to cut power off to your unit before inspecting it for wiring-related problems.
  • The AC unit does not cool rooms evenly: Inspect your unit's distribution channels. Make sure that the fan on your unit is kicking air into rooms or into your duct system.
  • The AC unit turns on but doesn't cool: If your unit turns on but doesn't cool, check your thermostat to be sure that it is set at the correct temperature. You should then check the condenser and evaporator for dirt and clogging. If too much dirt builds up, your unit may not turn on at all.
  • The condenser unit returns on and off repeatedly: Having a unit turn on and off repeatedly is extremely frustrating. In general, this problem is caused either by a dirty condenser and fan or a clogged condenser.
  • The condenser unit won't turn on: If your condenser unit won't turn on at all, you may have a faulty motor or the unit may not be receiving power. Examine all wiring and ensure that the unit is plugged in.
Sep 23, 2015 | Cars & Trucks
Previous tenant left ac window unit Haier HWF05XC5, but took the remote. Can I manually turn on this ac unit? when turning the power button, only the fan turns on, I'm unable to switch to AC
According to the Model Number you listed, it's a Mechanically or Manually Controlled AC unit. There is no remote control for it.Please be certain the Model Number you listed is correct and get back to me.
If it's the correct model number and it's manually controlled. You should have 2 rocker switches. One is to turn the power ON & Off. The other is to set the Fan Speed either on Low or High. Then there is a dial, numbered 1 to 10 to set the cooling level. 1 is min cool and 10 is Max Cool.
If the controls on your unit match what I described above, it's a manually controlled unit. No remote.
I hope this helped you. Please advise. Thanks.
Jul 11, 2011 | Heating & Cooling
Unit ices up and quits cooling
There are a couple of things that contribute to the problem you're experiencing:
1. A dirty or clogged air intake filter. Turn unit OFF, remove and clean the filter. If filter is washable
be sure filter is thoroughly dry, before reinstaling it.
2. Cooling fins are dirty. Turn unit OFF, remove the outer shell of the AC unit, if necessary and
clean the fins with an old toothbrush and a vacuum cleaner.
3. Humidity level in your area is extremely high. This is Mother Nature's problem and is not readily
solvable.
4. Defrost sensor is not functioning properly. Replace sensor.
5.. Low refrigerant gas in the AC's compressor. Have compressor recharged.
Hope this helps you trouble shoot and solve the problem. Please let me know. Thanks.
Jun 16, 2011 | Friedrich TwinTemp EL24J35A Air...
AC was cooling fine. Now, won't cool room even though cool air comes out. Exhaust hose is extremely hot.
Check filter, if you have a 5000BTU unit (small) and it is extremely hot, then it wont work great for a big room. BTU is the rate of what the AC will put out. 5000 BTU is good for a small single room. 10,000 will cool a bigger room and 18,000 btu is meant to cool a home.
Jul 07, 2010 | Whirlpool ACP102PS Portable Air...
Compressor is kicking in but isn't cooling
This problem is related to partial durty in the filter. you can't do that by your self. If you are a technician , :
1. recover the freon,
2. remove the filter;
3. replace by a new one;
4. vacuum the system;
5. charge the freon .
Sep 20, 2009 | Frigidaire Compact Air Conditioner
AC not working. Sound but no cold air.
Dirty filter and or froze up indoor coil. most likely locked or stuck blower motor.
Jun 27, 2009 | Heating & Cooling
What is required in the service of a 3.0l subaru liberty at 100000kms?
your owners manual will tell you exactly. usually all filters should be changed (oil, air, auto transmission if equipped, fuel, cabin air etc) as well as spark plugs and wires, distributor cap and rotor if equipped, check the belts and hoses as well as the charging system. All fluid levels should be checked and topped off. Check your tire p.s.i. as well.
Mar 20, 2009 | 2004 Subaru Legacy
Run(heat) for a certain minutes then it stop.
You may have a durty evaporator coil do to a durty filter, the heat is cuting off by the limit control sensor
Feb 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Goodman CKL36AR36 Air Conditioner Logo
113 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
