Question about Apacer Memory Audio Steno AS820 (128 MB) MP3 Player
Hello my mp3 player apacer audio steno as820 dont appear in my computer when i plug in usb.sign what its connected appear in mp3 display.thanks form assistance
bobhifi
  • 635 Answers
SOURCE: Hi, I have an old
Your balance 247MB files must be write protected. You will have to untick the protect tab and then delete. Or else you can connect the device to your computer and right click on the AV220 icon and click on the format command.It will warn you that you will loose all data -- just ignore it and click yes.
Posted on Mar 07, 2011
Testimonial: "Fast and very helpfull respons! Thanks!"
Hi, I have an old Apacer Audio Steno AV220 mp3-player. After deleting all visible files and folders, there are still only 11MB avaiable (out of 247MB). I guess I need to formate it(?) but how do I do that?...
Mar 07, 2011 | Apacer Memory Audio Steno AV220 MP3 Player
The lcd display has gradually got feinter over the last few years. It is now practically unusable. I have not tried to fix it.
Have you been using it by sunlight?
This happens to all LCD displays if they are by sunlight.
You may have to get the unit replaced.
Aug 05, 2010 | Apacer Memory Apacer DISC STENO CP200,...
J ai le mp3 tout le temps allume et il ne   fonctionne pas
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} ok tu peut essayer de la formater
Suivre les étapes suivant:
cliquer le : Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
essayer de la formater en fat 32 et fat nfts
Merci
uttam
Jan 13, 2010 | Apacer Memory APACER AUDIO STENO AV220 1GB...
Hello,I cannot access my 1GB apacer mp3 so plzzz help me to start that...
Plug it in and see if it shows up in my computer if not then install the drivers off the CD that came with it
Dec 02, 2009 | Apacer Memory APACER AUDIO STENO AV220 1GB...
Mp3 not recognized by the computer
try re installing the cd program of ur mp3 or if you dont have any... try this. (for windows computer only)
1- plug your mp3 in the computer using your usb.
2- go to my computer.... in the left task pane. click view systems information.
3-the system properties dialogue box will appear.
4-click the hardware tab then click the device manager.
5-the device manager tab will appear.
6- click the portable devices then you will see the name of your device.
7-click the name of your device .
8- you will see in the general tab in the dialogue box that will appear 'device usage'
9- enable it.
thats all..
Jun 07, 2009 | SanDisk Sansa E280 MP3 Player
To unprotect
It would depend on your Operating System. If you are using Windows 98 you'll need the drivers from your CD or from Apacer's website. The CD also has tools to perform various functions which might include protecting and unprotecting your flash disk.
Apacer's download site: http://usa.apacer.com/us/support/downloads.asp
Nov 17, 2008 | Electronics - Others
Usb drives show write protected when plugging in any device
ok, i found having the flashdrive in a usb hub doesn't help this (http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip ) repair kit to work cuz it can't recognize the flash drive.
so i took ejected it and put it straight into the computer usb and then tried again to format it and hooray. it formatted.
so i managed , thanks
adele
Nov 15, 2008 | iLO (2 GB) MP3 Player
Samsung YP-Z5F MP3 player malfunction
I have that kind of Mp3 Player too... that happened to me, but the PC was able to read mine. However, the reason why the message: "Low Battery USB Disabled" appears, is that you still have remaining battery life, but will only last for less than an hour (indicated by low light and red empty battery sign) you have to make sure the Mp3 is completely discharged. (you'll be notified when you turn on the device while it says: "Low Battery") once that it is completely discharged, you can now plug in the USB cable with the device to the PC... if problem persists, check your PC.. can it read the device? Check if a notification balloon appears at the bottom right corner of the monitor screen. It should say, "Found New Hardware... Samsung YP-Z5F..." if it did not appear, try to INSTALL using the Installation CD given when you bought the product. Just insert the disk into the PC and continue on, then when it is already installed and ready for use, plug in the device! This may be a little hard, but this is the only way I know. Feel free to ask me! I am no technician but I know a lot on devices and fine mechanics. Good luck!
Oct 11, 2008 | Samsung YP-Z5 MP3 Player
Can't re-synchronize deleted files
your gonna have to reinstall all your stuff as I always tell peeps if you need to reformat or clean up your files and you got alot of data you should always have a copy or backup files on your puter. Sorry
Apr 11, 2006 | Apacer Memory APACER AUDIO STENO AV220 1GB...
Apacer Memory Audio Steno AS820 (128 MB) MP3 Player Logo
19 people viewed this question
Top Apacer Memory Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Apacer Memory Audio Player and Recorder Expert? Answer questions, earn points and help others
