Question about Car Audio & Video
2001 expedition amp/sub woofer location
Where is it???
  • Anonymous Nov 09, 2008
    the 2 passenger speaker not working
I have a 97 expidition. One amp and a 8" sub is located in the back passenger side. There is also a amp just below the head unit
Posted on Jan 26, 2009
    Scholar:
  • 71 Answers
Check with any good car audio shop, If they don't or won't help for free. Take your business elsewhere, Have you tried a Ford dealer parts Dept.? They do have the manual......
Sumthin
Posted on Jun 11, 2008
My sub woofer stopped working, please tell me where it is located so i can check the speaker and also check if power is going to it thank you very much joe
The JBL premium sound system has a large woofer in the bottom of each door, a small mid-range speaker next to the woofer, & tweeters next to the front door windows in the corner, & two full-range speakers near the rear seats. The woofer (not sub-woofer) handles all the low end. You can test the woofer by turning the BASS to max and TREBLE to minimum (make sure balance and fader are centered) and put your ear next to each woofer.
The woofer is usually the 1st speaker to have problems after 10 years or so. The outer edge of the woofer starts to degrade. You will usually hear a rattling sound out of the woofer when this happens.
NOTE: If no sound at all out of the woofer (tweeters are OK), you might take your car into a car stereo shop. They can put a speaker on the wires connected to the speaker and make sure your problem is not the radio.
PROBLEM: You can still hear sound out of the woofers but it is distorted
SOLUTION 1: Go to a car audio shop and have them install new woofers. These may cost $30+ each but the dealer cost is over $200 for each woofer (crazy).
SOLUTION 2: More involved but very cost effective. If you or a friend is handy, you can go to www.speakerworks.com and order a new set of speaker outer rings (on the site they are called speaker SURROUND) that will replace the damaged outer rings on the woofers (replace on both woofers). They really work great and your speakers should last for many more years.
Hope this helps.
Feb 07, 2011 | 2001 Toyota Sequoia
QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
hi,
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
ok
Feb 05, 2011 | Technics SA-EX500 Receiver
How to hookup
hi,
if u want to hook up the sub with ur av receiver the connect the sub woofer output of ur AVR to any one (left or right) input of ur sub woofer. then connect its power . set the frequency range between 90 and 120Hz. set the volume of sub woofer to 40% of its total. also check the av receives speaker setting. goto speaker setup and make ON the sub woofer out.
if want to connect the sub to a stereo amp without sub out. then connect the amps speaker line to the speaker input of sub woofer and connect the speaker out of sub to left and right speaker ( make sure to connect the red to red and black to black). set the volume and frequency as above
ok
Jan 01, 2011 | Wharfedale PowerCube PC-10 Subwoofer
CAN NOT REMOVE RIGHT REAR SUB WOOFER?
The sub-woofer is located behind the rear panel, so you will have to pull the rear panel to be able to get to all the bolts that hold the sub and plastic type box in place. It can be a pain to remove, it has about 4-5 bolts in the box.
Aug 28, 2010 | 1998 Ford Expedition
I installed an aftermarket radio in my 2003 ford expedition and my amp won't power up nor will my rear sub woofer play.
Do you have a battery positive wire as well as a switchable power wire? Is it properly grounded? Double check for power and ground. Aftermarket radios have two blue wires for switchable power. one for an amp, and the other for a power antenna. Make sure the right one is used.
Jul 01, 2009 | 2003 Ford Expedition
Sub woofer?
It is a tedious task, however simple if you have patience. In order to get the sub woofer out, you need to take out the paneling and floor in the back. Start with the plastic knobs near the rear hatch door and then pull the floor back and the panel with the cup holder. I believe i needed to take back the panel on the inside of the rear pillar as well. Everything snaps back in place, so it is not a big deal. Just don't force anything so that you don't crack the plastic. The subwoofer is mounted from the back, so that is the only way to actually get to the hardware holding it in place. Otherwise it will just spin and spin if you try from the front. i replaced mine about 2 years ago with an 8" Kicker, however i think the factory sub had better sound. The amp is designed specifically for that sub. However, it did blow out and the kicker gets the job done. Good Luck!!
Mar 10, 2009 | 2001 Ford Expedition
2001 expedition sub not working
there is an inline fuse running to the sub try locating it and replacing it it also may have cam out of its socket.
Dec 18, 2008 | 2001 Ford Expedition
Car Audio & Video Logo
187 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
