Question about Dell Latitude CPX Notebook
Is it possible to run two CD drives with the jump cable?
I have a Dell CPx, and it has the cable that allows you to run both a floppy disk drive, and the CD at the same time. Does anyone know how, if it is even possible, to run an additional CD drive, with a CD drive inserted into the computer? I have hooked it up, but it still shows that the additional drive that I have added with the cable, is a floppy, when it is actually a CD/RW DVD ROM drive. If anyone out there has the answer, or knows how to configure it, I would appreciate you letting me know at thomsonprof@msn.com.
Thanks!!
Tom
  • thomsonprof Jun 08, 2008
    It figures. I own about 15 Dell Latitudes, as I use to do lease buy backs, and sell them at the HamFest in Dayton, Ohio a few years back. I can take them apart, fix them, and do just about anything with them, but for the life of me, I could not figure this optical thing out. The one that I currently use as my personal laptop has a regular CD-ROM, and whenever I put a CD/RW or DVD into the port on the computer, it takes the whole system down for some reason, and just will not work. I have no idea what the problem is, as I have never had this happen to me. I just was hoping that I could ad the CD/RW to the jump cord to burn CD's, but I guess that is impossible!! Thanks for all of your help!!
    Tom
  • 3,940 Answers
The Latitude CPx only has the capability of running 2 IDE devices (1 HDD, 1 CD-ROM) The optical drive can be connect via the drive bay in the chassis or the Cable. If Optical drive is connected via cable only the floppy can be used in the bay.
In short, you can't use 2 optical drives at once.
Posted on Jun 08, 2008
Older dell latitude cpx running XP. yesterday after loading firefox and a few mozzilla add ons .. today I boot to error 0 no primary hard disk found.. bios says no hdd installed ????
Hello, Jay.
Well, as the message indicates, your hard disk drive is failing or failed. Try running your diagnostics to verify (boot and press F2 or F12 repeatedly).
If the hard drive is failing, see if someone locally can help to retrieve your documents and other files by removing the drive and setting up the drive as a slave drive on another computer.
The drive would then need to be replaced. Price the same type of drive but it may not be cost-effective to use another drive in this computer.
Hope this helps.
Oct 18, 2011 | Dell Latitude CPX Notebook
"Floppy Diskette seek Failure Strike F1 key to
maybe the floppy disk drive is defective or maybe the IDE cable is deffective, or maybe the cable on the floppy drive is not properly inserted , try to replace IDE cable of the floppy drive if still the symptoms happens replace the floppy drive
Jul 20, 2011 | Dell OptiPlex GX520n PC Desktop
I get this error msg a disk read error occurred on my dell inspiron 3800 how can i fix it
It's caused by the failure of the hard disk - you will have to replace it and reinstall Windows.
Apr 20, 2011 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
HP Pavilion 7955 main HD failed; my data is on second drive (Maxtor ATA/EIDE) - still good. I want to install this as a second drive in Dell Optiplex 620 which has SATA main drive. The only IDE cables are...
Most IDE cables have THREE connectors:
* one to the motherboard
* one to the "primary" device (CD/DVD or disk-drive)
* one to the "secondary" device (disk-drive or CD/DVD)
If your IDE cable only has TWO connectors, buy a cable with THREE connectors, and connect your disk-drive to the third connector.
Mar 03, 2010 | Dell Optiplex GX260 Refurbished Intel...
Need to upgrade
Yes call Fries Electronics let them know what model laptop you have they can tell you the type of memory you need SoDimm more then likely, they will give you a price. It is better to remove the old memory and take it with you when you go to buy it has to match. Also you can ask what is the largest recommended hard drive they have for this model laptop, probably 60gb. The motherboard for that laptop does have limitations. That laptop probably does not have a built in wireless card so you can either use a hard wire RJ45 Data cable and plug the other end into your Internet Router, or you can purchase a PCMCIA Wireless Card to insert into the slot on the side of the laptop. This PCMCIA Card will allow you to access the internet wirelessly. You have now beefed up your CPx Latitude.
Jun 16, 2009 | Dell Latitude CPX Notebook
How to install new HD w/o a floppy?
Your computer should be able to handle either the 120 or 150 replacement drive. Most drives today come ready to load. Your Dell installation disk would be the best bet to install everything on the new drive. The restore disk will look for existing software and not find it. The other thing you might want to try is once you get the new disk up and running, change the pin setting on the second drive to be a slave drive and your new drive to a master with slave, and try to recover your data. If you don't have the dell install disk, a copy of Windows will also do the trick. No you don't need a floppy unless you plan on reformatting the new drive.
Hope this helps
Mark
Dec 02, 2008 | Dell Dimension 2400 PC Desktop
Dell C600
Here goes, first download the A12 BIOS from this page or others,
http://drivers.softpedia.com/get/BIOS/Dell/index5.shtml
Then, Run this file to make a bootable bios floppy disk. Reboot the laptop floppy will start dos mode, the updater will detect any bios newer then A12 and say finished without changing anything and come to an a: prompt.
type dir for a list of files on the floppy. If your typing gets you wierd symbols try holding the Fn key (lower left) lookfor the filename C600_A12.exe or somthing like this. type it at the a prompt exact. The bios flash will check system bios and ask your permission to revert back to A12. say Y.
Computer will reboot. take floppy out.
My batteries charge grat now, but I don't get all ythe settings pages in Bios that I should, It seems to hang when i enter Bios. Laptop works fine though. i have installed and tries all bios from A12 yo A23, the A12 seems to be the best. No problems from winXP.
Oct 01, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Software purchase
Hello dazz_hammer,
You can put up to Windows XP. If do, I would suggest to add memory and bigger hard drive.
Or if the pc has Windows Product Key Tag, and what ever the operating system it indicates then you can re-install that operating system.
Hope this helps and good luck.
Jul 27, 2008 | Dell Latitude CPX Notebook
New hard drive(s) in Dell4500s
You would have to contact dell for the OS disk.
I dont think you can install the hard disk in place of floppy drive. An external Hard disk would be a better option.
May 04, 2008 | Dell Dimension 4500S PC Desktop
Dell Latitude CPX Notebook Logo
63 people viewed this question
Alun Cox
