there are series of problem in ps3 which can be
solved without much technical knowledge ........ your problem belong to that so
dont worry i will give you the link to download the ps3 repair guide that
will help you a lot
u check with the manual whether it has the capacity to play the blueray disk..or else u check with settings there might be some change should be made to play blue raydisk and even check with the site to solve the problem...
A bad laser could affect the sound cause it can't read all the information from the disc. Try games as well and see if it does the same thing, sounds like a new drive is in order. There is one laser in those drives and require different strengths to read different discs. Also try a music disc that you know is good. If your still getting the same issue then get the drive replaced or just replace the laser if you have some technical knowledge.
At this time the region lock on ps3 only includes DVD and ps1-2 titles. Although some games will have the 80028F10 error. Most ps3 and blue ray will play without problems, my only suggestion being that if you are in the US, make sure you get a US ps3.
was accidentally inserted a crack cd,after that we can no longer play games or wacth movies.the cd display on tv screen disappeared....
