Question about Gateway Computers & Internet
Want to add more ram to my gateway mx6433
Hi
i want to add more ram into my gateway mx6433 laptop. Any help would be really apreciated. I will buy ram (i dnt knw wht kind) and then install it on my own.
Thanks
rd
  • 458 Answers
You need......
PC2700 DDR SODIMM
Posted on Jun 08, 2008
Need 2 add more mem
Hi BBrown,
There is an excellent step-by-step guide here
http://www.computermemoryupgrade.net/installing-laptop-memory.html
However, you NEED to find out what exact model of Gateway laptop you have to make sure that the RAM modules that you buy will work with your laptop since there are physical limitations to make sure you don't install the incorrect types.
For example, there's SDRAM (associated with Pentium III laptops from 10 years ago) and three generations of Dual Data-Rate memory (DDR for short).
DDR3 would be used in current laptops (maybe up to 2 years old), DDR2 (2-6 years old) and of course, Pentium4 era DDR as well,
Hope the helps
-BuzzPuppy
May 01, 2011 | Gateway Computers & Internet
Hi there. I am a RAM rookie. I have GAteway MX7118. are there two memory slots or one. It comes with 512 does that mean there are two slots and I can add a 1GB for A total of 1.5GB ?
Hi, defending on your cpu board usualy there are two slots, also if your board capable to 1 gigabytes memory, if your memory is DDR u can add 1 GB up . if your memory is SD you cannot add higher than 712 MB. if your memory is 512 and you want to add 1GB the total should be 1.5 you are correct in your calculation. thanks
Apr 29, 2011 | Gateway MX7118 Notebook
Can I upgrade the video card on a Gateway E4300 to work with Shader 3 graphics (Eve Online)? Or do I have to buy a new computer?
You only really need to upgrade the video card and the PSU (most video cards need more power than what most companies like dell and gateway provide.). So no need to buy a new computer.
Mar 22, 2011 | Computers & Internet
No light, no up, nothings. power nothing please i need help. battery 100%
So the first thing to do is to plug it in so you can eliminate the battery as a potential problem, but if that does nothing, things are not so good.
If the laptop makes no sound at all, there are really only two pieces you can fix or replace, the HD and the RAM. The Ram is the easiest and will cost you about $20.
The manual to replace the ram is here:
http://support.gateway.com/s/Mobile/Q106/Blade/8511418.pdf
The ram itself is here:
http://www.memoryupgrade.pro/1gb-gateway-mx6448-memory-1x-1gb-qnd1smerzztae8-pc2-4200-ddr2-533mhz-so-dimm-upgrade.html
It is possible it is the hard drive which you can replace for about $40, but at that point, you may as well buy a new computer, because usually it is only your data you care about on a computer over 3 years old.
...you might also try unscrewing the case. It is possible, but unlikely, you have a simple wire break in the power button or a weak contact in that switch. It is unlikely, but possible.
Good luck.
Dec 02, 2009 | Gateway MX6448 Notebook
How to install more ram
Most laptops have a small hatch on the underside, usually held closed by a single screw. Should be a piece of cake adding more RAM, remembering that there is probably only one slot, so your original one meg will have to be taken out before you add new RAM chips.
Sep 20, 2009 | Acer Aspire 4930-6862 Laptop
MT3705 Gateway, what motherboards will work with this laptop. I want to upgrade this laptop, so i want to get a motherboard able to really max out my ram but still use this chip set and everything else on...
You don't get different mainboards for laptops.....sorry. It's not like desktop pc's where pretty much any mainboard will fit. And even if you could, it's not really going to improve things, as you are using the same speed cpu. Your laptop has 2 ram slots. That's the most you will see on laptop mainboards.
Adding ram is probably the best bet. That laptop shipped with 1 gig of ram.....which is not enough for Vista. I bet it's quite slow. Vista wants 2 gig of ram to be happy, and 4 gig to really motor along. Laptop ram is cheap for that machine, so check it out. Ram is not expensive, and will give you an immediate, very noticeable improvement in performance.
Hope this helps. Post a comment and let me know how you make out
Sep 04, 2009 | Gateway Computers & Internet
Want to add memory to Gateway 700x
Max memory is 2GB, i.e. 1GB per slot(DIMM), so you will need 2 X (SimpleTech 1 GB PC3200 400MHz DDR RAM). {Always use matched pairs only}
Visit this link : http://www.simpletech.com/upgrades/gateway/700x/700xddrintelp428ghz/
.................sodeep
Mar 31, 2009 | Gateway 700 X PC Desktop
Question regaurding two different gateway laptops
Hi!
I compared them, the on you have is a good laptop, the one you consider to by is not.
The one you have has on mobile prosessor 2,7ghz, the 450 has an pentium4, that will get that laptop warmer and it will consume mote electricity
The 7320 have 512mb ram and you can upgrade it to 1,5gb ram if you want. The 450 have 512mb ram and thats the maximum it can have.
The 7320 has an 15.4 in TFT active matrix 1280 x 800 ( WXGA ) screen. The 450 has 14.1 in TFT active matrix 1024 x 768 screen.
The 7320 has Intel Extreme Graphics 2 Shared video memory . The 450 has ATI Mobility Radeon M6-P 32.0 MB
In my opinion, the only thing thats better on the 450 is the videocard, and that just a little bit better.
So my advice is..DONT buy that 450, there are better laptops out there for a good price.
I hope the info i gave you helped
If you have further questions, just ask me and i will do my best to help you
Good luck
Nic
PLEASE rate me
Dec 30, 2008 | Gateway 450SX4 Notebook
Upgrading RAM on your Gateway 700X (DDR) Computer is easy, Gateway 700X (DDR) Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. RAM Type, and comes installed with 512 MB (removable) of RAM.
You can upgrade your Gateway 700X (DDR) Computer to up to a maximum of 2.0 GB RAM, the Computer has 4 sockets to install RAM, already with 512 MB (removable) standard RAM installed. For best Computer performance use the maximum amount of allowed RAM per slot for your system.
Dec 08, 2008 | Computers & Internet
Installed new ram and now processor speed is 1/2 of what is was?
Hello Brian -
Is the new RAM you installed the same as what you took out? Are they both PC2700?
Is your laptop running on battery when you're testing to make sure you CPU speed is accurate? The laptop usually ramps down the CPU speed if it is being run off of just battery. Plug it in if this was the case.
Also, the Gateway and eMachines laptops I have encountered have all been notorious for displaying the incorrect CPU speed at times.
I would suggest putting your new RAM in, make sure the laptop is plugged in, and boot it up. This time, let it idle for about 10 minutes and then check your CPU speed to see if it has updated correctly.
Nov 24, 2007 | Gateway MX6438 Notebook
Computers & Internet Logo
160 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
