SOURCE: freezer seal
Turn the machine on to full empty all contents and leave for about 30 minutes then try to close door if doesn't work check the seal for splits.
Thanks J
SOURCE: Frigidaire Deluxe Chest Freezer is constantly
Two things to check without knowing the model number.
It is possible the drain plug was left out or not inserted correctly after defrosting and it is leaking..
Also there is sometimes an evaporator pan with a heater element on the bottom. If the heater element failed the evaporator pan would overflow.
SOURCE: freezer door has a gap in the middle. Seal doesn't
Put a long straight edge on the door to verify a warp. A 4 foot level is good for this test.
If the door is in fact warped. You should pull back on the seal,loosen the screws behind the seal holding the door liner in place,adjust the door to the straight edge and re-tighten the screws.
If the straight edge does not show a warped door,take a hair dryer and heat the seal where it is off the frame. Do this with the door closed and you will see the seal relax and touch the frame. Let it cool in this position before opening the door again.
If neither of these is the cause,loosen the door hinge and re-adjust the door position,then re-tighten the hinge screws.
SOURCE: Not sure how to ask this question...should the
You have to contact service center immediately.
SOURCE: installed a new door seal on freezer, old one was
you can use a blow dryer and heat the seal until it forms to the cabinet wall
Hello friend, I appreciate your post!
I see you are trying to fix the seal on your Frigidaire chest freezer. Are you having an issue with your freezer not closing? If so, have you verified that there is nothing blocking the door from closing as well as making sure there was nothing between the door gasket and the freezer body? Next, I would check to make sure that the gasket is not damaged or compromised in any way. If it is not damaged, I suggest contacting your local authorized technician for further assistance. I hope this information helps. -Matt
Hello dotty26 - The door gasket should be securely closing with no resistance. You may try lubricating the door gasket with petroleum jelly to make it easier to open as well.
