Question about ViewSonic VX2235wm LCD Monitor
Audio adjust blue screen stays on monitor
I have the viewsonic vx2255wm the problem is the audio adjust screen keeps poppong up and flashs between volume and mute
  • 2 more comments
  • bubbabob Jun 10, 2008
    no comment hay
  • dsjr23 Jul 28, 2008
    I have the same problem, any solution?
  • Anonymous Aug 26, 2008
    i have a same shitty problem, poppin out by
    it self in midof no where
  • Anonymous Nov 18, 2008
    Same problem but from different model - VP720b. "Audio Adjust" OSD stays on screen and the value decreasing from 50 to 0 when I first turns it on (like the "down" button kept being pressed). No problem with the button, I checked it inside out.
bammbammfran
  • 159 Answers
SOURCE: Problem with monitor
Hi.
Are you able to see a slight image on it at dusk and maybe with the help of a flashlight. since your blue light stays on the video board, may be okay.
It sounds like you have bad capacitors on your powerboard or possibly a burned out transistor on the inverter.
Only way to really tell is to open it up.
If you unplug the screen to video board ribbon, you may notice a different effect in the screen lighting.
There is a chance one of your bulbs is creating a problem
Should the screen happen to light up all white, then your power board and inverter are okay and the problem may be in the video board.
If it looks pinkish or dark or flickers then the bulbs or a bulb may be the issue.
If it flashes on then goes off, it's in the power or inverter board.
ebaysbammbammfran
Posted on Oct 12, 2008
SOURCE: audio adjust screen pop up
audio adjust pop up
Posted on Dec 06, 2008
I contacted ViewSonic with the same problem. They told me to turn off the monitor and unplug all the cables. Then hold the power button on the monitor for 10 seconds. Turn it back on and it should be gone.
If that doesn't work, I was told to do a memory recall on the monitor by pressing the 1 button and selecting memory recall from the list. It sets the monitor back to factory settings.
I haven't tried any of these yet but hopefully they work for someone.
Posted on Jul 19, 2009
  • 644 Answers
SOURCE: Viewsonic VX2255wm - worked this morning - dead this afternoon?
The problem you have sounds like the inverter board has failed it can be repaired by replacing the inverter board which may be a cheaper option than buying a whole new monitor, you can do a search online for lcd repairs and spares to find the part you looking just state your make and model and price one up.
But before you do do that, and you feel confident that you could take the back cover off the monitor, you could have a look for blown capacitors, they are quite a comman fault in lcd monitors, once the back cover is off check the power supply board, it will be where the power cord plugs into the monitor, The capaciters are barrel like in shape with silver tops, check for any leakage from them or on the board surrounding the capacitors, also make sure they are fully flat at the top, if they are slightly domed or pretruded they will need to changed. post back your findings if you do find any bad caps ill will try to explain how to get the right ones and what do to. cheers.
Posted on Feb 01, 2010
  • 1584 Answers
SOURCE: I cannot get any sound from my ViewSonic VA1912wb
You may need to load the monitor drivers.
I assume your PC sound is OK.
When you are plugging the green lead in the Moniotr / PC do you hear any noise from the monitor?? if not may be faulty.
Try plugging a friends set of speakers into the back of your PC.
Posted on Mar 09, 2010
ViewSonic VA1930wm Screen stays on for about 2 seconds, and then goes off. 1) If no computer is connected you get a "no signal" message which stays for about 1 seconds and then goes off; blue...
Very typical of View Sonic. Sounds like a back backlight or inverter. I would go to www.viewsonic.com and open up a RMA. Most view sonic screens have a 3 year warranty. They will repair at no cost ..(if it is within that period) There is a date code on the back of the screen that will help you validate the above information.
Nov 07, 2010 | ViewSonic VA1930WM LCD Monitor
Monitor flashes on then off power light stays on whats wrong?? shows screen for about 3 seconds then goes black
Some 22" Viewsonics will have worn out bulging capacitors in the power supply that causes this symptom.
Monitor Mike
Apr 14, 2010 | ViewSonic 22" FLAT SCREEN CRT BLACK...
The model is vx2835wm lcd display. the screen just stays blank in blue
Please see my pictures here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
This common problem with ALL LCD monitors.
Post back what you find so it may help other people also.
Apr 10, 2010 | ViewSonic VX2235WM Monitor
Screen keeps going into auto adjusment flashes every 30 seconds
Install the cd that came along
Well try to go in menu after 20 min (warming up) after powering ur monitor & try to adjust
or
U may need to press a button on ur monitor to disable the message...
for e.g viewsonic screen is button num 2
Feb 06, 2010 | HP w1907 LCD Monitor
Feb 01, 2010 | ViewSonic VX2255wmh LCD Monitor
Screen dialoge analoge and turns black i have no credit card then i dont know how to pay for asistance
I'm assuming turns black and blue then turns off? First make sure your connectors to your monitor and back of pc are secure. But it sounds like your video card needs to be reseated.
May 24, 2009 | ViewSonic VA721 17" LCD Monitor
Audio adjust screen pop up
Dec 20, 2008 | Computers & Internet
Hi.
ebaysbammbammfran
Sep 14, 2008 | ViewSonic VX2235wm LCD Monitor
ViewSonic VX2235wm LCD Monitor Logo
318 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
