Question about Maytag NMPEB08F2A Air Conditioner
HELP!!!!! hi! I got Maytag thinking it was good and I would be cool, this portable, works 15 /20 minuts and shots off. It seems that the water compartment is to small.So.. I have to empty it all the time. Please do you have a solution? The other is at the window and drips constantly. Thanks for any info/suggestions. Lin
  • LEIAH Jun 08, 2008
    hi there...May be because here,,,Montreal,Qc. it was very hot and high humidity day.Hopefully was it.
    We found a solution.,,,Home Depot.Got an extension , connected to the evacuation tube into a container,,, it works...Wht do you think? is that gonna damage the ac?
    Thanks so much for your expertise. Lin
  • 828 Answers
It seems you have a very bad problem with humidity beyond what would be considered normal. The source of the excessive level of moisture in the area you are trying to cool must be found and eliminated or reduced.
Posted on Jun 08, 2008
  • James Helmer
    James Helmer Jun 08, 2008
    Some units have a place where an external drain can be connected and routed to a drain at a lower level. And no it should not damage your A/C. part of air conditioning is removing moisture from the air. The moisture must be removed in order for the air to be cooled to a lower temperature. Enthalpy of air (total heat content) is directly related to the grains of moisture in a given quantity of air. The bucket or tank has a full switch, if not drained out it does shut the unit down.
Clean cooling coils. in the last week or so my dehumidifer in the basement seems less productive in collecting water, i have two down there and the other works - i have to empty it often, thats how i...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 18, 2011 | Maytag M7DH45B2A Dehumidifier
Msd2556ae side by side freezer seems ok refrigerator warm? think it is in defrost mode?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 29, 2011 | Maytag MZD2766GES Side by Side...
Refrigerator side not working. freezer side seems to be working.
heatman101
Dec 26, 2010 | Maytag MZD2766GES Side by Side...
I have a Maytag lsg7804aae stackable unit. The problem I am having is that the washer will not agitate or fill with water, however the unit will work on the spin cycle in all modes. Opened front panel of...
timer is good, if you tried it on all the different cycles, must be the water inlet valve, does the hot water work, if you set to warm or hot..if so the cold water valve is shot
Dec 19, 2010 | Maytag LSE7806A Top Load Stacked...
Maytag model # MZD2752GRW. Ice build up in bottom of freezer. Seems to be coming from vent behind bottom freezer basket.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 18, 2010 | Maytag Refrigerators
The fridge and freezer are both working normally. However, water is leaking out of the freezer compartment. We have checked the hose that feeds the water supply to the ice dispenser and it looks fine. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 31, 2010 | Maytag Refrigerators
Portable Dehumidifier is not working
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Jul 01, 2010 | Maytag M3DH30B2A Dehumidifier
Portable a/c water problems
either the area you are cooling is extremely humid or your a/c is freezing up, shutting off  and melting alot of ice before it comes back on.
Sep 02, 2007 | Maytag Portable Air Conditioner M6P09S2B
Maytag NMPEB08F2A Air Conditioner Logo
168 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
