Question about Canon PowerShot A460 Digital Camera
PowerShot A460 Battery Problem
It worked for the first 2 months or so I had it, then when it comes time to change the batteries, I do so, and it still says I need to change the batteries, while I have fresh ones in, and eventually it shuts off, and gives me that 'change batteries' screen. Help?
  • 4 more comments
  • Anonymous Jun 25, 2008
    I Have the same problem too. Is there a solution?
  • Anonymous Jul 10, 2008
    I have a Cannon Powershot A460 as well. I changed the batteries as well but it still shuts down and says I need to change the batteries.
    I hope there is a solution.
    I tried the 2500 ni-mh batteries and it doesn't help. still the same change the battery message as soon as I turn the camera on.
  • whitemamba Jul 18, 2008
    SAME HERE!!!!!!!!!!!!!!! SOME ONE PLEZ FIGURE IT OUT!
  • Anonymous Aug 18, 2008
    I keep getting a message telling me to change the batteries. I am using rechargeable NiMH batteries.
  • mangala84 Aug 21, 2008
    i have used new batteries still i m getting the meassage as change the batteries
    please give me some solution
    Problem Solver:
  • 5 Answers
Try 2500 miliamp (mAh) ni-mh batteries
Posted on Jun 12, 2008
Why is my canon A460 lens barrel not retract and gives an error message?
Again, could be battery life - are you using high power re-chargeable batteries (2100 or 2500) ? in it
Jul 20, 2016 | Canon PowerShot A460 Digital Camera
Of canon powershot A460
The A460 uses standard AA batteries. If you choose to use rechargeable batteries, you must charge them outside the camera in a separate charger.
Jun 26, 2012 | Canon PowerShot A460 Digital Camera
HI GOOD DAY I CANT TURN ON MY CAMERA IT DOESNT WORK EVAN WITH NEW BATERY THANKS
Check to make sure the batteries are inserted correctly.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.Close the [Memory Card / Battery Cover] securely, and then turn the power on.
If your camera still does not work even after you have performed the above procedures, your camera may be malfunctioning. Please have the camera serviced in this case.
Apr 19, 2011 | Canon PowerShot A460 Digital Camera
Canon PowerShot A460 displays Lense error
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Apr 29, 2010 | Canon PowerShot A460 Digital Camera
My Canon A460 powershot will not turn on. Changed the batteries. Using NiMH AA.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Apr 24, 2010 | Canon Cameras
I HAD THE DATE BATTERY CHANGED IN MY CAMERA. NOW MY CAMERA DOESN'T WORK AT ALL. WHAT COULD POSSIBLE BE THE PROBLEM?
You may have placed it in upside down. It's a very easy mistake. Double check that you placed the battery in correctly.
Jun 13, 2009 | Canon PowerShot A460 Digital Camera
Canon powershot A460 camera not recognized by
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Mar 03, 2009 | Canon PowerShot A460 Digital Camera
Canon A460 problem
I have a Canon A460 and the only red light I know of is the auto-focus light. If it's a low battery you'll see the indicator on the screen, not a light.
Aug 11, 2008 | Canon PowerShot A460 Digital Camera
Canon powershot A 460
Which batteries are you using? If they are rechargables, make sure they are not drained because you can overcharge them to the point that they discharge. If they are regular AA batteries, make sure they are reputable brand, and if they are, then use a pencil eraser to gently clean the battery contacts inside the camera. If none of these steps work, the camera may have an excessive battery drain issue and needs service. You should call Canon and see if you can have it repaired under one year manufacturer's warranty, or if you are beyond the year warranty, ask about the Canon Loyalty program where you can upgrade your camera for a deep discount for another model with a 6 month warranty.
Hope this helps!
May 31, 2008 | Canon PowerShot A460 Digital Camera
Canon powershot a460
I have a Canon A460 that does this every now and then. Usually if I removed the batteries and put them back in, it does the trick. If that doesn't work, and the camera will stay on, try resetting it. Click Menu> Tools and then scroll all the way to the last option Reset All. Good luck!
Oct 09, 2007 | Canon PowerShot A460 Digital Camera
Canon PowerShot A460 Digital Camera Logo
259 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
