Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis my dryer wont get hot? A wire in the cord burned up & I replace the cord but now it wont get hot.
  • tkatt Aug 19, 2008
    MAYTAG ATLANTIS MDE6400AYW - Electric front loading -- Have replaced the power wire, good voltage, drum light comes on with door open -- Otherwise, when I set the timer, nothing happens, but you can hear the timer running when very close to it --
  • mmwinefeldt Aug 29, 2008
    My dryer heats but not enough on the automatic cycle, but doesn't heat at all on the timed cycle any sugestions?
    Thanks
We have a atlantis dryer maytay and need to get in to it to fix the one of the bars in side the dryer its lose abit how do we get in it to tighten it up
Posted on Jul 24, 2008
  • 525 Answers
Usually you will encounter a situation where a wire will burn off and in so doing, it may trip a breaker,(turn it off then back on to be certain), or if fused, it may blow a 30 amp glass fuse or 30 amp cartridge fuse. Replace both tho eliminate any doubt. If all checks ok, disconnect the dryer from the power source and go internal to find the problem. Below is a popular link to provide you with more assistance, should you need it.
http://www.repairclinic.com/0088_8_1.asp#Level1_2
Posted on Jun 08, 2008
Wont get hot and dry clothes
If the dryer runs the same as before except it will not get hot then check your heating element that is more than likely your problem.
Sep 04, 2012 | Maytag MDG6400 Atlantis Gas Dryer
I have a maytag atlantis dryer and im trying to hook it up to a 4 prong hookup and there is only 3 wiring connections on this dryer
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Dec 18, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Trying to hook up three wire plug, witch wires go where? maytag atlantis mde6400ayw
the red and black go to terminals marked L1 and L2 polarity isnt an issue here,and the white or bare is the N terminal or neutral connection,if its non color coded cord as in gray insulated then the 2 outside conductors are the 2 hot wires L1 & L2 and the center is N neutral
Jan 09, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Replaced the electrical cord on maytag atlantis dryer < a year ago, but now it seems the hot connection is burning up.
BOTH HOT "L1" and "L2" connections or just one of them is burning up? if just one you could have a partially shorted heating element drawing excessive current
Sep 24, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis electric dryer Model
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 08, 2009 | Dryers
Maytag dryer
Replace the cord first. You won't be able to tell for sure unless it's replaced. Dryers pull so many amps and the dryer cord becomes hot while running it. The heat causes them to break down over time.
Apr 10, 2009 | Maytag PYE2300AY Electric Dryer
Dryer is a front loader approx year 2000 maytag. dryer wont turn on. already tried flipping breakers
Check the wiring in the back to see if any wires are burned off. There is also a thermal fuse under the top that may be bad. You can check it and see if it is bad. I bet, however, the problem is in the wiring. The plug that goes into the wall may have a wire that is burned off as well.
Jan 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Black and blue wires from terminal block have burned.
hi thanks for the question cut the wires back to get to good wire and re attach to block the appliance doc
Sep 03, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
110 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
