Question about Breezaire WKL 4000 Wine Cooler
Unit runs but does not cool. - Breezaire WKL 4000 Wine Cooler
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 52 Answers
IF YOU UNIT IS IN FACT A WKL UNIT(DIGITAL DISPLAY) IT COILD BE TWO THING A BAD BOARD THAT IS NOT SENDING POWER TO THE COMPRESSOR OR A FREON LEAK.
ON MAJORITY OF CASES ON A FREON LEAK THE UNIT WILL FORM ICE ON THE COIL, SOME TIMES A LOT OF CONDENSATION ON THE BODY OF THE UNIT AND IT WOULD LOOSE COOLING GRADUALLY UNITIL IT WOULD RUN NON STOP.
CONTAVTTHE MANUFACTURER FOR A BOARD OR ASK FOR A TEMPERATURE DIFERENTIAL TEST TO CHECK FOR A FREON LEAK.
Posted on Sep 16, 2011
SOURCE:
Rtu model# 50TCQDO8A2A5AOAOAO how to figure out if why its not running on cool even there is a cooling call
There could be a lot of reason why unit is not running in cooling .First is the unit low on refrigerant, if it is and system have a low pressure switch it would not run.
Are you getting 24 volts on R to ground.
Does the unit have a econimizer
May 25, 2017 | Heating & Cooling
What does the snowflake mean on a Honeywell thermostat in cooling mode. Also had the problem in the heating mode.
The snowflake means it's cooling. If the outdoor unit is not running then the problem is likely outside.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 21, 2017 | Honeywell Heating & Cooling
Norcold 6120 gas heats and electric warmer heats still doesn't cool has no ammonia smell
Only offering I have for a consumer is to run a "highpot" test on the cooling unit. This will bypass all the controls from the board and test the function of the cooling unit. Remove the leads from the board for the heating element and connect leads directly to 110 volts. Run for 3 hours to see if cooling is stating in the freezer. If cooling detected let run for 6 hours. So on and so forth. DO NOT RUN FOR MORE THAN 12 HOURS LIKE THIS!!!!!!! If no cooling detected in the first 3 hours the unit is "stopped up" and will have to be replaced.
Oct 04, 2015 | Refrigerators
I meant the AC does not cool
Make sure the mode is set to freeze and temperature is set to below the room temperature.
If it is a split system, check the outdoor unit whether it is running. If it is running, see if you can reach and feel the temperature of the pipes connecting between the indoor and the outdoor unit. It should be cool.
If it is not cool, you may need to get somebody to check the refrigerant.
May 22, 2014 | Dometic 57915531 Air Conditioner
Unit runs and blows air but does not cool, can it be recharged?
check to see if compressor running if ok bad cooling unit or temp sensor
Jul 03, 2012 | Dometic Rooftop RV Air Conditioner
Global.netOur ac/heating unit is approx 2 years old. The unit triped the breaker resulting in the fan continueing to run, but the cooling unit no longer cooled.. Re set the breaker and unit immediately...
I would check all the connections at the breaker panel, and in the disconnect and in the control panel of the unit, the connections must be tight. If the breaker is sized to small a dirty coil could be to blame if so give it the hose, a full solid stream and be thorough is cleaning it.
Jul 02, 2011 | Heating & Cooling
True GDM-12 - Unit runs, but won't cool below 60 degrees,
Is it very hot out side the unit.recharging may not hurt is it cleaned the lint could be trapping the radiator were the coolan goes through to cool down try cleanning underneath before recharging
Jul 26, 2010 | True GDM-12 Refrigerator Commercial
Unit does not cool
It would appear that the unit needs to be regassed and checked for leaks.
Sep 11, 2009 | Refrigerators
Lower unit does not cool
check for conditioned space fan not running. Does top cool and not the lower or are both not cooling properly. If fan is running, it could either be that the thermostat is not set low enough, evap is frozen up, the unit is low on freon, the compressor is not running. Start checking as much as you can and let me know.
Mar 22, 2009 | Carrier Beverage Air® DP46 Commercial...
Breezaire WKL 4000 Wine Cooler Logo
274 people viewed this question
Top Breezaire Refrigerators Experts
Isidro Sevilla
Isidro Sevilla
Level 1 Expert
Brad Goodale
Chris Huff
Chris Huff
Are you a Breezaire Refrigerator Expert? Answer questions, earn points and help others
