Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Its slow, does not boot up after shutdown (unless re-plugged again) disconnects randomly and has hard time searching files!
    Guru:
  • 773 Answers
Download the seagate utility from seagate and run a diagnostic. It will tell you what's wrong with the drive. Your drive should have come with this software on it.
Posted on Oct 25, 2010
SOURCE:
Verykool s505 Spark stuck at boot/ continuously restarts. I Flash my Verykool phone with new rom. I dont know why,. This is scond time.
first time it may give this kind of things. wait and watch. first boot may be slow. if Problem persists then Try to hard reset and do the Flashing Stock firmware on Verykool s505 Spark again with fresh Files. fresh Files
Sep 24, 2017 | Computers & Internet
My desktop frequantaly booting what can i do
When you say frequently rebooting; Is it randomly rebooting without warning? Do you get a BSOD (Blue Screen of Death) error message? Or does the PC just reboot without any error's other than windows was not shutdown properly?
MOST random reboot issues are caused by Power issues;
-Failing Power Supply
-Blown Capacitors on the motherboard
-Insufficient power to run the system.
These would be a good place to start to troubleshoot if you do not get a Blue Screen Error Message.
-Failing Hard Drive can cause this issue as well but is usually acompanied by a Blue Screen Error of sorts.
-Failing RAM again usually accompanied by a Blue Screen Error.
You can test for failing hardware, by using Hiren's Boot Disk for diagnostic tests on your Hard Drive or Ram.
Hiren's Boot CD 15.2 - http://www.hirensbootcd.org/files/Hirens.BootCD.15.2.zip
You will want to run memtest X86 to test the Ram or Hitachi's Drive Fitness Test or SeaTools to test your hard drive.
This BootCD is not for the typical end user whom may not know there way around the features and options this Tech CD provides.
You will want to burn the Hirens Boot.ISO file to a CD (Burn Image Option) using any of your favorite flavors of burn software.
Hope this helps.
You can also download these diagnostic test individually such as memtest x86 and Hitachi's DFT or SeaTools independently from the Boot CD just by doing a google search. This might be the easier way to perform these tests for people who aren't very savvy with boot CD's.
Dec 09, 2013 | Intel D845GVSR Motherboard
Slow computer shutdown
Tip #1: Cut down of the programs and processes running in the background.--When you start your computer many unnecessary processes are loaded. You can eliminate this by managing your msconfig.
Here is how:
1. Open your Start menu.
2. Click Run
3. In the command screen type "msconfig.exe"
4. In the system configuration utility,click either service or startup tab.
5. Uncheck all programs that your are no longer want to run in the background.
6. Click OK
Tip #2: Defrag your Computer--The faster your computer can find files the quicker it can shutdown. A very slow computer shutdown can be the result of your hard drive trying to search for disorganized and fragmented files that it needs for shutdown . Organize your hard drive by performing a defragmentation.
Here is how:
1. Open the Start Menu
2. Click on My Computer
3. Right Click your C: drive or your hard drive image.
4. Scroll down to the Properties and Click
5. In the Properties Menus, Open the Tools menu.
6. Choose Defragment Now.
7. In the Disk Deframenter menu. Click on Defragment
Tip #3: Clean your Registry- Usually slow computer shutdown often occurs due to a corrupted registry. You should perform a registry clean, use RegInOut to fix this issue instantly.
Dec 18, 2011 | Microsoft Windows 7 Home Premium 64BIT...
I use hp nx9010, i want to re-install windows xp but any time i try, the machine shutdown. sometimes is able to move up to copping files sometimes not then shutdown; i don't understand why is only windows...
If you can't keep your laptop stable and on for longer period, and you're experiencing random shutdowns I'd say you're facing a motherboard problem. This failure is actually well known and hapens a lot with Toshiba and HP. You'll most probably need to repair the motherboard that suffers from the Maxim 1987 or Maxim 1532 power chip failure.
The repair process is fairly straightforward, but it isn't for the faint hearted. It requires a resolder of the tiny Maxim 1987 chip that should get your motherboard up and running again in no time. The other alternative is to go for a new motherboard, or just get a new laptop alltogether.
If however your laptop experiences random freezeups, and you notice that the DVD is slow at reading data, and especially if you experienced some random mouse and keyboard freezeups, then you'll need to repair the motherboard from a FSB chip failur, which causes these random freezeups, which is a bit easier to do but still a challenge.
Hope this helps
Jan 17, 2011 | Computers & Internet
I need the directions for using the external hard
Hello Friend,
  • It is better to Unplug your External Hard drive when Booting time.
  • Only plug it in after window Started / in ON stage.
  • Try to Plug in Backside USB Port of Desktop PC.
  • Correctly Plug in
  • Do not try to Overload(Something like trying to copy More/Different files at Same time;Only try to Copy One by One]
Hope this make you better..Thanks for Contacting FixYa...
May 28, 2010 | Western Digital My Book Essential 500GB...
Windows shutdown and won't start again
If the system doesn't start even enough to access the BIOS then it's a hardware fault, take it to a shop.
If you can access the BIOS then change the boot order and boot from a Linux Live-CD like http://pclinuxos.com/  , recover all your files and reinstall. Once the reinstall is over check the hard disk using HDTune.
Mar 28, 2010 | Acer Aspire One PC Notebook
Random shutdown and hard reset
I had a similar problem and it turned out that there was a backup program called ´Sprite´ that was loading an image file of the system after every hour of use, erasing all changes to the configuration and saved data.
The folder of the ´Sprite´ program has a text file with the configuration data. I opened the text file and set autoexec. and similar options to ´false´ and saved the file again. After that, the problem had disappeared.
Regards,
Joep
Jul 31, 2008 | HP iPAQ h6315/h6365 Pocket PC
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
170 people viewed this question
Top Seagate Computers & Internet Experts
Ekse
Alun Cox
Argospete
Argospete
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
