Question about Sharp EL-1801AII Calculator
How to feed paper in calculator el-1801a need diagram
3 Suggested Answers
SOURCE:
  • 11 Answers
SOURCE: Where do I feed my paper into the Sharp El-1801P calculator
Hello, my name is Curtis, I am a Sharp Customer Servicer Rep. Normally the calculator would have a thin slot on the back, where you would feed the paper through, then once you press the paper in till it hits an inner wall, you would press the feed key which is on the upper left side of the calculator. If there are any problems doing this please call our technical support line at 1-800-237-4277, I am very glad to hear you like the calculator though!!!
Posted on Jun 30, 2009
  • 11 Answers
SOURCE: how do I thread the paper tape to the machine
Hello, my name is Curtis, and I am a Sharp Customer Service Rep. What you will want to do is on the back of the calculator there should be a thin horizontal slot that you would feed the paper through, it will only feed so far before it hits a wall on the inside, make sure the calculator is turned on and press the feed key in the upper left side of the calculator, it should take up the paper, if not then give us a call at 1-800-237-4277 or 1-800-BE-SHARP. Hope everything works out.
I have an old Sharp EL-1701C calculator and for some reason can not feed a new roll of paper into the unit? Batteries are new and the feed option works well, just doesn't grab the paper roll to start?
you may need to cut the corners off a little bit on the start of the new roll and feed the paper in while advancing with the calculator advance control/button
Dec 10, 2014 | Sharp EL-1701C Calculator
Sharp calculator EL-1197P III paper feed stuck
Hi
I trust you are well.
This might be trivial however when you replace your paper roll the edge of the edge paper must be cut straight otherwise the paper will not feed correctly.
Hope this solution is as easy as that, If not open the claculator paper feed compartment and check the gear mechanism for chipped teeth or foreign objects stuck inside.
Hope this helps you
Kind regards
Aug 15, 2014 | Sharp EL-1197PIII Calculator 12-Digit...
Jun 23, 2009 | Sharp EL-1801P Calculator
How do I thread the paper tape to the machine
Jun 08, 2009 | Sharp EL-1801AII Calculator
How do I replace the printer paper in my sharp EL-1192BL calculator
Feed the paper into a VERY thin slot on the back side of the calculator. This thin slot is below the removable clear plastic paper guide and is very inconspicuous.
Apr 10, 2008 | Sharp EL-2196BL Calculator
Tape wont register on this after we changed the tape
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Sharp EL-2196BL
mechanism.
Sharp EL-1801AII Calculator Logo
96 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
