Question about Sony Ericsson K800i Cellular Phone
Hey bajanguru thanks for listening
Well one day i turned off my phone and took out the battery to look at the sim but i did not take the sim card out. Then i put the battery back on and tryed turning it on but nothing and i tryed again and i saw a red light flashing in the infrared port it flashed 6 times. I tryed charging it and pluging it to the computer but it did nothing. I tryed this that i found online from some guy, step by step but in the end it did not turn on""""""
Sticky: USB Flash Drivers (Sorry, bored of repeating myself) Ok, for the final time instead of replying the same thing to each person who posts a problem with this, I will in future link to this post instead.
Follow these intructions TO THE LETTER if you are having problems getting SEUS, DaVinci or WontonServer (purposeful spelling error) to recognise your phone (DOESN''T MATTER WHICH SE MODEL IT IS, AS LONG AS IT USES A DCU-60 USB CABLE. YOU CAN TELL THIS BY THE FACT THE CABLE CONNECTS TO THE ENTIRE PORT ACROSS THE BOTTOM OF THE PHONE, THEN TO THE USB PORT ON YOUR PC)
* POWER OFF YOUR PHONE
* CONNECT THE USB CABLE TO ANY USB PORT ON YOUR PC
* REMOVE THE BATTERY COVER FROM YOUR PHONE AND TAKE OUT THE BATTERY
* REMOVE THE SIM AND MEMORY STICK FROM YOUR PHONE
* REPLACE THE BATTERY AND BATTERY COVER
* OPEN DEVICE MANAGER ON YOUR PC (Start > Settings > Control Panel > System Properties > Hardware > Device Manager)
* MAKE SURE THIS FILLS THE SCREEN
* DOWNLOAD THESE AND UNZIP THEM TO YOUR C: DRIVE INTO A FOLDER CALLED USBDR (YOU MAY NEED TO CREATE THIS)
* ONCE ALL THE FILES ARE EXTRACTED, CLOSE THE USBDR FOLDER AND YOU SHOULD BE LEFT WITH DEVICE MANAGER
* HOLD "C" DOWN ON YOUR PHONE
* KEEP HOLD OF C AND DO NOT LET GO UNTIL THIS HAS COMPLETED
* LOOK IN DEVICE MANAGER FOR A NEW USB DEVICE WITH A YELLOW CIRCLE CONTAINING A BLACK "!" NEXT TO IT
* RIGHT CLICK ON THIS AND CHOOSE UPDATE DRIVER
* DO NOT ALLOW WINDOWS TO CONNECT TO THE INTERNET TO GET THE DRIVER, INSTEAD INSTALL IT YOURSELF FROM A SPECIFIED LOCATION.
* TO THE RIGHT OF THE BOX ASKING WHERE YOU WOULD LIKE TO LOOK FOR THE DRIVER, CLICK BROWSE
* SELECT YOUR C DRIVE, THEN THE USBDR FOLDER YOU CREATED THEN PRESS OK.
* PRESS NEXT AND IT SHOULD INSTALL THE DEVICE FOR YOU
If your phone has powered on in the meantime, you will need to disconnect the USB cable and remove then reinsert the battery again. However, the driver should now be successfully installed.
I will do screenshots for this when I can be bothered, but for now I am in work and have better things to do.
Well hope you reply to this and help me out. Thanks
  • 2 more comments
  • Richardmuse Jun 13, 2008
    wat do you men by gdfs
    What do you mean by gdfs? Do you live in united states, California? Or where?
  • emiaj Jun 13, 2008
    i have same problem, i try to download the driver but it cant be found, any options, thanks.
    i have tried several times to follow instruction but still no "yellow circle" has appear on device manager for USB device even if i click "show hidden devices". is there any other way to resolve it? yellow circle appear but on keyboard devices.
My sony ericson submerge in water but technician manage to repair but it cannot down load picture from its memory stick to pc. what shall i do...
Posted on Jul 01, 2008
Repair gdfs
Posted on Jun 11, 2008
I have a Nokia 5800 Express Music, I tried restoring my phone to its factory settings and it froze for ages on a white screen with Nokia written on it in blue, I took the battery out, turned it on again,...
hey guy ptoblem is not in the sim or battery. it is the memory card who is the culprit.teke out memory card , back up data on computer ,format ihe memory card.
now copy the backed up data to memory card again .
switch on your phone now and then insert the memory card.
Everything is fine now.
For detailed explaition read this tip by clicking here
Sep 05, 2010 | Nokia N70 Cellular Phone
Blackberry storm battery won't charge and device won't turn on.
Hi! My phone had exactly the same problem a few days ago! I got a new battery - it worked fine for a couple of days and here we go again... It is dead! Please let me know what you did with your phone! I have a new BB curve! Thank you!
Jul 14, 2010 | RIM BlackBerry Pearl 8100
How do I replace a SIM card in a Nokia 2115i?
firstly turn off your phone then open the battery back cover which easy just slide then take out the battery and you will see the sim card holder take out old sim card and put new sim card then put battery back and put back cover.
Dec 30, 2009 | Nokia 2115i
Screen turned white
Remove the back cover, Remove the battery, if the phone is GSM take the little card out of the back of phone by sliding the metal cover in proper direction. Should be arrows. Put the Sim card back in battery back in then turn phone on. If this doesn't work let me know. Main thing is reseating the sim card. (this assuming you a service provider that requires a sim card. )
Jan 01, 2009 | RIM BlackBerry Pearl 8100
Sim card slot
try go to a different tmobile retail store
and have them test out a new sim card
to see if it help.
and good luck.
p.s
come back to me and let me know
if its helped. kk?
cool.
and again, good luck. hope
that help.
Aug 14, 2008 | T-Mobile Sidekick II
Cannot import contact from sim card to iphone 3G
Turn off the iPhone before inserting the sim, insert sim, turn on, import contacts. If you put the sim in the phone without restarting it for some reason it doesn't get all the contacts sometimes.
Aug 02, 2008 | Apple iPhone 3G
Show test mode
my handset model1600 shows test mode , how do i turn on phone ?
thanks
Feb 29, 2008 | Nokia 1600 Cellular Phone
Samsung e-250 i need unlock code
Please follow the instructions carefully! Following are the 12-point instructions to unlock your Samsung E250 phone:
1. First do a CUSTOM RESET by tying in:
*2767*2878#
(Phone may display foreign language – don't worry! The last digits after the * will appear as - - - -; this is normal)
2. Turn off your phone
3. Take the battery and SIM out of the phone
4. Take a wrong network SIM (a SIM the phone does not currently accept) and insert it ONLY HALF way in, so when you turn on the phone it won't detect the SIM. Very important so the phone won't ask for network password and will show "Insert SIM" message.
The process of inserting only half of the SIM. I advice you to take care and do it with a soft approach as you might not have done this before.
5. 2. Now put the battery in carfully behind the protruding SIM card and switch the phone on. The phone must show "Insert SIM" message.
6. 3. Without turning off the phone, now push the SIM card all the way in, at this stage the phone must continue to display the "Insert SIM" message with the WRONG SIM inside.
7. Now make a FULL RESET by typing: *2767*3855#
9. Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#
8. The phone should reboot working with "wrong" SIM inside. (Do not turn off the phone)
10. Disable network lock by typing: #7465625*638*00000000#
12. Check this is done with *#7465625#
If your phone is not unlocked please retry the above ensuring all steps are followed to the letter, 9 out of 10 people who have problems have made a simple error and find that when they repeat all the steps it works.
Jan 08, 2008 | Nokia 1600 Cellular Phone
Water damage
It might be to late, but doesn't hurt to try, keep battery / sim card out, and put the phone in a freezer, if you don't have a freezer place it next to an air vent, wait over night (10 hours at least) And you should see water dripping out, warm it in your hands for about 20 seconds, dry it out with any towel / cloth place the sim card than battery in, if it doesn't turn on contact your phone company from a land-line about your insurance
Dec 01, 2007 | Nokia N80 Cellular Phone
Sony Ericsson K800i Cellular Phone Logo
137 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
