Question about GPX PD808B Portable DVD Player with Screen
D200B DVD player. It's nearly new but two solid green bars have appeared horizontally at top of screen when playing DVD's. One goes all the way across and the other halfway. When I push set-up button, the green fills the entire screen.
  • 666 Answers
This is either a video driver error caused by out of date drivers or trying to display something your computer does not have the capacity for if you meet the min system requirements and your drivers are up to date try displaying other programs to make sure that you find the same lines if after updating drivers you still have lines either the monitor or graphics card has burnt out
Posted on Oct 25, 2010
  • dfkuz Oct 25, 2010
    Called my son in Seattle and he said to disconnect the cables and reconnect. Did the trick. Thanks anyway. Sometimes the simplest and least expensive solution should be tried first.
6ya staff
SOURCE:
Gpx d200b dvd player. Why won't it play certain dvds? It plays all my other movies except for one that I just bought brand new.
The format of your new disc is probably NOT COMPATIBLE with your disc player. Verify through your owners manual & the format of your new disc.
May 15, 2015 | GPX Televison & Video
What other hacks are there for the GPX D200B, manufactured in 2010?
I BOUGHT THIS 4-1-13 Hack is
hit setup
on the remote press 9 9 9 9
region 1 will come up at the top right.
use the side arrows go to 255
hit setup region free
Sep 08, 2012 | GPX D200B Player
DVD player model D200B
either a mechanism issue or possible bad optical unit (pickup) in the player.
Jun 14, 2012 | GPX Televison & Video
My kids lost the remote to our GPX D200B dvd player. I got a GE universal remote but neither of the GPX 4 digit codes are working. When I try to search I can get it to play but nothing else works. I...
Unfortunately, the only real answer is that GPX is such an uncommon brand that many 'universal' remotes are not compatible with it. Your best bet is to look for a replacement remote for your D200B, but they don't seem to sell replacements. You may have to settle with using buttons on the DVD player itself, or buying a new player.
Mar 19, 2011 | GPX D200B Player
Dvd's aren't fitting my screen, the sides and top/bottom is being cut of. I've tried the display menu, zoom, and making it widescreen, and it doesn't work.
Are you playing wide-screen movies on a 4x3=1.33:1 (standard=SD) TV? DVD output by default is SD. Even 16x9=1.78:1 (HD) movies with have top and bottom bars. Many "wide-screen" DVDs are squeezed horizontally so that you have to stretch them. Many theatrical releases are up to 2.7:1 or so. Side bars indicate you have the DVD output set for 4x3 and your TV is HD-like. There are usually controls for the screen format on HD TVs--no controls on SD TV. Hey, early movies were 1:1--take them side bars. More on aspect ratio (AR) in Wiki, I bet. With letterbox of SD you can get "pillar box" with black on all 4 side. Get a better source and/or choose a different AR. -Ken
Jul 15, 2009 | Pioneer DV-400V DVD Player
Wavy lines
Are the wavy lines horizontal or vertical? If they are horizontal and up near the top of the screen it could be 60HZ interference from a power cord running over the cable from the DVD player to the TV. There could also an internal breakdown of the shielding by the power supply of the DVD player. If the lines are vertical it is likely the cable or maybe the input jack on the TV. Could be a number of things.
Nov 09, 2008 | Sony DVP-S500D DVD Player
Horizontal Blue Line
WHEN YOU HAVE A SOLID BLUE LINE THAT DOES NOT MOVE...YOU HAVE A DEFECTIVE PANEL...LIVE WITH IT OR REPLACE PANEL..NOT COST EFFECTIVE TO REPLACE PANE....JOE ACE
Jun 13, 2008 | Westinghouse TX-42F430S Television
VHS Picture on new recorded tape shows horizontal bars.
clean the head of your vcr that will help also connections of the wires good luck.
Mar 29, 2007 | Sony SLV-D550P DVD Player/VCR
GPX PD808B Portable DVD Player with Screen Logo
96 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Ekse
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
