There is no color on the printed page,or black and white.
  • 1,218 Answers
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Posted on Oct 25, 2010
6ya staff
SOURCE:
I want to print white format on black paper
about the problem is the warm-up color
Oct 06, 2012 | Zebra ZM600 Printer
My color laserjet 2025 won't print color
If you print the demo page from the menus is that in color? If it is then it is possible that you have a black and white only printer driver installed or your driver is defaulted to black and white only. It is also possible that you have one color empty which stops color printing but often allows black and white printing to continue.
Mar 10, 2011 | HP Office Equipment & Supplies
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
Dell color laserjet 5110 cn will not print color documents. This network printer was printing color fine until yesterday mid-day when it started printing in black & white only. I tested by printing a...
This has to do with the document printing properties. When you are ready to print a document, choose properties and make sure you go through the printer settings under that software.
The test page only verifies the cartridges. The printer properties of the software control the printer during printing.
Mar 17, 2010 | Dell 5100cn Laser Printer
Lexmark Z705
In the printing preferences you need to select Black and white.
1. open the document you want to print
2. click file
3. click print
4. select printer from list, then click on preferences
5. look around the pages.
In Color tab I found a print in Grayscale - this setting will print the document in black and white colors, the pages may be diffrent on diffrent printers. look for black and white setting or Grayscale.
picture: printing preferences, color page on a hp printer, select grayscale with black cartridge only.
May 19, 2009 | Lexmark Z705 Inkjet Printer
I just got a hp photosmart c4480 printer and it makes black and white copies, but I can't figure out how to print in black and white like when I am on a web site.
OK, Whe you select Print from the File Menu and the Print window opens, selct the Color tab.
There should be an option to Print in Grayscale. Check the box beside it and click OK at the bottom. Then back at the Print window, click Print.
(Note: If this option is not on the Color tab, or you do not have a color tab, look on the Advanced tab for the same thing.)
Need additional help...use the Comment link.
Thanks for using Fixya.
Apr 22, 2009 | HP Photosmart C4480 All-In-One InkJet...
Colored page in black and white
don't click on color, click on black/white and it should work
Jan 04, 2009 | Canon PIXMA MX310 All-In-One Printer
Dell 5110cn Color printing only printing in black and white
check in the printer properties and make sure on the color page that "print in grayscale" is not selected. This option will make the prints all in black (grayscale)....
Dec 31, 2008 | Dell 5110cn Laser Printer
Canon Imageclass MF6530
the imageclass MF6530 cannot print in color it can only print in black and white. the only thing that this machine can do with color is to scan color documents to your computer otherwise it is a black and white copier and printer with color scan.
Jan 02, 2008 | Office Equipment & Supplies
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
24 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
