Question about OKI C3400n Laser Printer
Oki c3400 false paper jams - I keep getting false paper jams on this machine. There really is no jam. If I open and close the top cover it, continues to print another 10 copies or so and then I get another jam notification. Open and close the top cover and then it continues to print again. Very frustrating.
SOURCE:
  • 10 Answers
SOURCE: oki c5500 gives a false paper jam reading
service the rollers (either clean the pickup with clean alcohol or use sandpaper ) sometimes clean the fluff from the printer with dustoff helps as well
Health and Safety get an engineer to do it for you. if you have warranty call them out. check your total page count and diagnostics via printer status page before you call them out.
Posted on May 23, 2008
flopez
  • 161 Answers
SOURCE: Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Posted on Sep 22, 2007
  • 21 Answers
SOURCE: oki b6200 paper jam
restart the printer or reinstall driver again.
Posted on Oct 08, 2009
MalKontent68
  • 748 Answers
SOURCE: While printing with OKI C5600 very often error
Try cleaning all the paper feed rollers you can access, both from the bottom (paper tray pulled out) and from the front, behind the front door. It might be that the sheet is not fed properly and doesn't reach some sensor in expected time, thus the errors.
Also clean the separator - it's the small area on the paper tray where the feed roller touches; it needs some friction to hold the sheet(s) beneath the one being fed.
To clean use isopropyl alcohol or some kind of residue-free and oil-free cleaner on a piece of cloth or paper towel that does not leave lint.
Posted on Oct 24, 2009
  • 24 Answers
SOURCE: Oki C5500 printer keeps jamming
Open the tray and find yout imput roller. You can remove this roller and put it back on the other side. Normally this is caused because it is worn. The inside of the roller is like a new one.
Posted on Jan 24, 2010
I have an OKI C3530 MFP that tells me to open the top cover due to a paper jam, but no paper anywhere. The machine was stopped in mid print and is now confused. Help!
Open the machine and remove the paper tray, the drum tray, the transfer belt and the fuser. Check all for a sheet or part sheet of paper. replace all and retry.If still register a paper jam have a look underneath to see if one of the paper pick up sensors is jammed open.
Jan 03, 2018 | OKI Office Equipment & Supplies
How to clear a fake paper jam in oki B6250 printer
The usual cause of "fake" paper jams is a prior "real" paper jam. One of two things occurs.
  1. A small bit of paper tears off the jammed stock and hides from view, but keeps the printer jammed. These can be hard to find and remove, depending upon where they are.
  2. In the process of yanking the jammed paper out of the unit, the sensor(s) become damaged or misaligned and give false jam indications. This usually needs repair or replacement.
Jul 30, 2015 | OKI Office Equipment & Supplies
OKI b410d error 382
That is a paper jam code. Reopen the cover, and clear all paper jams. Close the cover, and then I would reset the machine by turning it off and on if the code continues. http://www.german-parts.de/oki_manual/paperjam/stau_b400_series.pdf
Feb 05, 2015 | OKI B Office Equipment & Supplies
Oki b431d paper jam
Paper jam is initiated by a sensor that does not register (or tell the logic board it has registered) a movement of the paper through the printer. Try finding out what sensor is near the point the paper stopped. Look if anything id blocking a optical sensor, or any small lever is blocked in free movement. Close all covers correct and make sure nothing is blocking the covers. Not even just a small piece of paper.
Jul 16, 2014 | Oki Electric Industry B431d Printer
Error code 391 paper jam - no paper jam though. Open front cover and close and that resets machine but when you try to print error code 391 again!
Check the area where its showing the paper jam to see if there are bits of paper there. Most of these issues are caused by tiny pieces of paper blocking the sensors.
May 04, 2011 | Oki Electric Industry C6150N Laser Printer
Hp Officejet L7480 false paper jam message. Resetting the printer has no effect.
Hp paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
May 20, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
The machine indicates paper jam on all areas but no paper jam exists
open all of the paper cassettes and make sure no paer is stuck ther. then with the cassttes open. open and close all of the covers. it is possible you have a bad sensor saying a false jam
Jan 25, 2010 | Canon imageRUNNER 400S Copier
Canon image runner 3200 false paper jam
First check all the tray's and make sure the papersize dial inside the paper cassette is set on the correct papersize,this is the most causes for false paper jams.Open and close all covers machine will send a reset data.Switch the machine off for 3 minutes untill it shows offline on the server and switch back on.
Dec 08, 2009 | Canon Computers & Internet
Paper jam message but there is no paper jammed. opening and closing cover doesn't work.
hi,are you sure no paper jam ok check very very small paper in your machine or clean the sensor.
Apr 28, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Oki c3400 paper jam
Run Status Monitor and make sure it is really a paper jum that prevents printer from printing. It is very likely that another reason is in place. For instance - toner empty of change drum request. All of this causes the "Attention" LED to blink: it's not only paper jam that causes it.
Oct 07, 2008 | OKI C3400n Laser Printer
OKI C3400n Laser Printer Logo
245 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
