Question about Fuji FinePix S700 Digital Camera
The flash is spring loaded and does not fully open when the release button is pushed. Must be manually held in upper position in order for the flash to work. Help me fix it
    New Friend:
  • 4 Answers
The Spring mount breaks in the flash and loses tension.
Anyway if you are brave and handy you CAN fix this.
First remove the back of the camera - 3 screws in battery bay, 1 in the side above the memory card door, The two rear most on the bottom, two in the USB/video door, and the rear most on the left hand carry strap bracket.
Carefully prise the back rearward about 5 to 8 mm.
Now take a look at the two screw holes under the flash (when popped - or flopped out now that is broken) now go and bend a screwdriver of the type you used for the previous screws - you will need a 90 degree bend very close to the tip to fit in this gap and be able to turn the screws a few degrees at at time.
A little at a time lock the screwdriver into the screws and undo until the flash cover comes off.
You can then slide the shaft out of the flash to release the spring which will have the end that should fit into the broken bracket now sitting proud..
Make a suitable U shaped bracket that will slide over the broken plastic bracket and drill a tiny hole in the side where the spring will clip in.
make sure it fits really well and then epoxy into position.
Getting the spring back in is a fiddly job - I found the best way was to fit the end of the spring into the new bracket, slide the shaft just into the spring - the lever the other end of the spring down into the back of the flash body and then slide the shaft all the way into place.
I did have to file down the little plastic "blade" inside the lid which presumably is designed to assist the the (now broken) bracket from breaking....
reverse the dis-assembly and now you should have a working flash
Posted on Dec 08, 2010
  • buysellgb Jan 23, 2011
    DnC Sourcing is to make an Expert of developing products. ---> www.artdnc.com (82) 70-7893-2100)http://www.sourcingbuysell.com
    We have 15 years developing experiences and will implement the advanced products to our customer.
    Electronics, home appliances, sporting goods, medical products, smart phone, General Phones, machine equipment, cattle. Midsize engine
    * Mechanical design, tooling, product design, machine design, reverse engineering (image), product design, MOLD Analysis
    * Processor: AVR series, DSP, FPGA, ARM7, ARM9, etc.
    * Circuit design, PCB ARTWORK Use Program: ORCAD, PADS
    70% Motor Sales ---> www.buysellmotor.net, sourcing everything ->http://www.sourcingbuysell.com
SOURCE:
How do I open Kleenmaid top load washing machine KAW693W-3050 so i can replace the hose
generally take a putty knife and push it between the lid and the body in the front near the two sides. it is held down by spring loaded clamps. push them in to release them. good luck.
push hard.
Jun 11, 2016 | Washing Machines
Why Can't I add another remote to a merlin mt60p
If you purchase additional transmitters, the garage door
opener must be programmed to accept the new remote
code.
Program the Receiver to Match Additional Transmitter
Codes:
Using the orange "LEARN" Button:
1. Press and hold down the transmitter button you wish to
program to the opener. The orange LED will flash to
indiciate it is receiving signal from the transmitter.
2. Press and release the "LRN" button.
3. The sourtesy LEDs will flash once.
Ensure the door is clear of obstruction, then test the
transmitter.
Using the Motion Detecting Control Panel
(optional accessory):
1. Press and hold the button on the hand-held remote that
you wish to operate your garage door (1).
2. While holding the remote button, press and hold the
LIGHT button on the Motion Detecting Control Panel (2).
3. Continue holding both buttons while you press the push
bar on the Motion Detecting Control Panel (all three
buttons are held) (3).
4. Release buttons when the opener light flashes. It has
learned the code. If the light bulb is not installed, two
clicks will be heard (4).
Now the opener will operate when the transmitter push
button is pressed. If you release the transmitter push button
before the opener light flashes, the opener has not learned
the code.
To Erase all Transmitter Codes:
To deactivate any unwanted remote, first erase all codes:
Press and hold the orange "learn" button on opener until
the learn indicator light goes out (approximately 6 seconds).
All previous codes are now erased. Reprogram each remote or keyless entry you wish to learn.
http://gomerlin.co.nz/getattachment/2949a1dd-74ab-4576-850d-4f40de28fbe3/mt60p-installation-guide part 27 from installation manual page 15
May 05, 2014 | Building Materials
My honda odyssey 2002 hood latch stuck it opened the hood and now not closing even droping the hood from difference hight and even pressing it ???
SOUND LIKE YOUR HOOD LATCH IS STUCK IN THE RELEASE POSITION. YOU CAN DO TWO THINGS. REPLACE YOUR HOOD LATCH OR PUSH THE LATCH BACK INTO POSITION MANUALLY EVERYTIME YOU OPEN YOUR HOOD. IT'S EASY. FIRST CHECK YOUR HOOD RELEASE LEVER (DRIVER SIDE KICK PANEL)AND MAKE SURE IT'S MOVING FREELY. IF LEVER IS OK,GO TO YOUR HOOD LATCH. LOOK TO THE RIGHT OF THE LATCH (LOOK DOWN FROM THE TOP VIEW)AND YOU'LL SEE A SMALL METAL BAR WITH A SPRING PULLING DOWN ON IT(MIGHT NEED FLASH LIGHT TO SEE BAR AND SPRING). TAKE A FLATHEAD SCREWDRIVER AND PUSH DOWN ON THE METAL BAR WHERE SPRING CONNECT. THE BAR SURE MOVE ABOUT 1/4 INCH DOWN. CLOSE YOU HOOD AND YOU'RE DONE. YOU JUST HAVE TO PUSH THE BAR DOWN EVERYTIME YOU OPEN IT.
Dec 14, 2010 | 2001 Honda Odyssey
How to set up garage door opener on my 2002 diamante
Detail Instructions from the owner's manual 1. Turn off engine
2. Prepare transmitter by erasing all three of the factory default channels by holding down the two outside buttons until the red light begins to flash. Release both buttons.
3. Hold the end of your hand-held transmitter (garage door remote) against the Homelink transmitter keeping the red light within the Homelink icon in view.
4. Using both hands push the hand-held transmitter button and the deisre button to be programmed on the Homelink transmitter. Do not release the buttons at this time.
5. Hold down both buttons until the red light on the universal transmitter flashes, first slowly then rapidly. When the light flashes rapidly, release both buttons.
To program the remaining two buttons, follow steps 3-5.
Jan 17, 2010 | 2002 Mitsubishi Diamante
Opening gas tank
There is no release - the door is spring loaded push on the right or left upper corner of the door and then release.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 03, 2009 | 2008 Chevrolet Malibu
Don't have owners manual. I how do I setup the
garage door opener that may be different. But, I believe there are 2 ways to do it. Try pushing the button on the back of your garage door opener by the LED. The light will begin flashing for 30 seconds. During this time, it is accepting new signals. So you have to quickly get in your car and push and hold the button you want to work your door. If the opener accepts the signal, it will flash its floodlight. Then just push the homelink button again to see if it raises/lowers the door.
The second way I don't remember quite so well, but I believe you hold the corresponding button on the homelink until THAT starts flashing, then point your remote at it and push that button. The homelink will flash 3 times quickly if it accepts it. I don't think I've ever gotten this method to work, which is why I'm unsure of the procedure.
I've had new and used cars with and without manuals and the first procedure has always worked. It may take a couple of tries, though
Oct 22, 2009 | 2000 Chevrolet Impala
Craftsman Garage door opener not working
First, check the springs in the actual door to make sure that they are not broke. Since you held the learn button down to reset the opener, you have to reprogram all of your remotes. This button only resets the remotes. It has nothing to do with the rest of the opener. To reset the opener, simply unplug it for a couple of minutes and then plug back in. Pull the handle on the door and see if you can operate the door manually with one hand. If it takes more than 15lbs to move the door, there is a problem with the door balance. If the springs are not broke and the door operates smoothly, the likely cause is the rpm sensor on the opener.
Feb 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Pop up flash will not stay open when you push the release button.
The post that holds the spring commonly breaks off. The top has to be removed to replace it - a $60 repair by an independent repair shop. I wouldn't recommend removing the top yourself unless you know how to discharge the 300Volt capacitor.
Dec 03, 2008 | Pentax MZ-50 35mm SLR Camera
The flash unit for my D50 doesn't pop up automatically
The flash is spring-loaded and always "trying" to spring up. It is held down by a small lever that should disengage automatically when the flash is instructed to pop up either manually or in automatic mode. It sounds like the small lever has broken on the inside and will not release. The camera must be opened in order to repair this, and this should only be done by a qualified technician.
Mar 03, 2008 | Nikon D50 Digital Camera
Fuji FinePix S700 Digital Camera Logo
335 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
