Question about Peavey Escort 2000 Microphone
No power our escort 2000 has been setting on a stand, not in use. we went to power it up and nothing. wonder how to check and or replace fuse. also wonder about the thermal protection circiut.
  • prince2028 Jun 08, 2008
    know about fuses. have the top off.fuse is under the plug. how do you take the fuse cover off to replace it.
    also if the thermal protection circiut has tripped does it reset itself or do you have to reset it?if so,how
  • prince2028 Jun 09, 2008
    Ok, doesn't seem to be the fuse. Was able to pop it out (it was the fuse cover I was having difficulty with... would not open until I used enough force I was sure I would break it!)It had a spare fuse, popped that in and no dice. Bought a new fuse today, again, no dice.
    I've opened the system up, just to take a look, (I'm a computer hardware tech... so I know just enough to be dangerous with electronics :)and I find no loose connections, nothing visibly 'fried', and remarkably little dust. I blew out some dust from the fans and around a couple of contacts.. .but nothing significant.
    I'm beginning to believe that it may be the thermal protect circuit/switch. I'm thinking the system was left on and the fan may have been blocked causing the switch to trip... Perhaps over and over until the switch died? Just a thought.
    I started surfing looking for repair schematics for this system and found only one site, bought the archived file for $15 AND ... of course ... it craps out on the download (several times) AND... of course ... won't refund the cash. :)
    I know I'm asking you to fly blind here... but could you help me identify where the thermal protection switch/circuit may be? I dosen't seem to be that hard to replace ... yea yea... I DO understand use epoxy/screws and do not solder (or use needlenose plier as a heat sink) Like I said, I know enough to be dangerous :)
    Or perhaps you could give another suggestion as to why it won't power on?
    Thanks!
  • 2,323 Answers
You could remove the cover and find the fuse and replace it with the same voltage and current rating.
Make sure you unplug the device before start working on it.
Posted on Jun 08, 2008
  • Jaime Hernandez Jun 09, 2008
    It could be just snap in, if you use a small flat screwdrivers and pull gently to remove it.
  • Jaime Hernandez Jun 12, 2008
    If the fuse is good, the thermal protection is engaged. If that is the case there might be something else wrong with your device, it could have a defective amplifier IC or transistor.
    If this device is less then 2 years old, I would suggest to call the manufacturers and ask them to fix it for you under warranty.
    Main support number601-483-5365
    Email supportwebmaster@peavey.com
Where is the jenn air mixer thermal cut out
Wonder if you checked the user manual on possible causes for not turning on. see page 10.
http://content.abt.com/documents/5384/JennAir-Mixer
Aug 13, 2014 | Jenn-Air Attrezzi JSM900 Stand Mixer
1999 ford escort no power
Dirty connection at the battery post ?
Jul 04, 2012 | 1999 Ford Escort
Headlights went out on a 98 ford escort while driving
if both headlights went out at the same time, check your fuses. because high beams use more power than headlights, they are often on a separate fuse. if fuses are fine, replace the headlights.
Nov 29, 2011 | 1998 Ford Escort
Dead in the water
Have you checked for fuses in/at, thermostat ? What type of RV is this in? Power board should need to be replaced again, if at all, my guess is it's something else. Do you hear any "clicking" form unit when you move thermostat to other settings? Is nothing working at all, fan, furnace etc?
May 11, 2010 | Dometic Rooftop RV Air Conditioner
2000 escort - tuner does not work but CD and TAPE are fine
most likely is the radio itself- typical ford radio... best bet is look in a junkyard for a new radio- there are no fusible links- there usually is just one 10amp fuse in the inside fusebox. but if the cd& tape players work it is in the stereo itself. hope this helps and good luck
Jun 08, 2009 | 2000 Ford Escort
2000 ford escort want start. checked fuses and battery . try to turn over but want what can i check. it was running went in house and came back out would not start
Hi
Get a jump start, with good set of leads.
If no joy , follow the Positive lead from the battery to the starter motor, and give it a tap with a small hammer or big spanner, while someone turns the ignition key.
Good Luck !
Remember to give me a FixYa rating....Thanks...John.
Feb 27, 2009 | 1996 Ford Escort 4 Door
My '99 Escort is getting no power
two things i would check, bad alternator or faulty ignition switch
Feb 19, 2009 | 1999 Ford Escort
I have a 2000 Nissan Frontier XE... My dashlights are out!!!!
Sound like the guage cluster has went out. You will have to replace the whole dash cluster, Check with junk yard to save on money.
Feb 04, 2009 | 2001 Chevrolet Blazer
94 escort
there are some main fuses in the black box that bolts on to the live of the battery hope this helps
Jun 12, 2008 | 1994 Ford Escort
Peavey Escort 2000 Microphone Logo
211 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
