Question about Vizio L37 Television
Vizio tv seems to have trouble with volume certain ch fox and ch 8 need to increase volume a lot also goes black loses sound g Have dishnetWork does true sound have to be off
    Novelist:
  • 123 Answers
It would be our pleasure in assisting you with that. We would recommend using our Volume Leveling feature which is available on our ViP222k, ViP612, ViP722k, and ViP922 receivers. Volume Leveling keeps the volume levels consistent between programming and commercials and prevents drastic volume level changes when watching television between HD and SD channels. Start by pressing the "Menu" button then pressing 6 for "System Setup" then 7 for "Audio Output". Select "Enable" below "Volume Leveling" then select "Done" to save these settings. If you're using a ViP922 receiver from the main menu select "Settings", select "Audio Output", and then enable Volume Leveling. This should help with the volume fluctuation issue you have been having. Thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Posted on Mar 01, 2011
    New Friend:
I have an E371VL with audio on true volume the sound fades in and out badly. can you help
Posted on Nov 28, 2013
SOURCE:
Vizio 47" screen won't stay on
Your Vizio TV may be exhibiting symptoms of power supply trouble even though it is quite new.
Dec 01, 2013 | Vizio E3D470VX 47 in. 3D LCD HDTV
Low volume
If it's a new TV, then it might just be as high as it goes. A lot of HDTVs don't come with great speakers due to the small flat feature of the TV not allowing anything better.
You will have to get external speakers for the TV to experience better sound.
Here is a great sound bar that is well priced. http://www.amazon.com/Vizio-VSB205-32-Inch-Theater-Soundbar/dp/B004VGI2EK/ref=sr_1_2?ie=UTF8&qid=1359416740&sr=8-2&keywords=32+inch+sound+bar
I've personally heard that sound bar and they are surprisingly loud and hardly take up any room at all.
Jan 28, 2013 | Polaroid TLA-01511C 15 in. LCD Television
Black screen
busted lamp. please increase the volume of the tv even thought there is a black display. if a volume comes up then chances are the ccfl lamp is busted that is why you get black display.
Apr 06, 2012 | Vizio P42HDEA Television
I have a constant ringing sound coming from the tv. It goes up and down as I increase or lower the volume by remote. As I change the audio option to "Spanish", regular "English" audio comes out on c
The fact it shows on tuner and not DVD means not likely a audio problem--check all audio settings in the set's menu AND if you are using a box for signal look there--has to be a setting.
Some JVC sets (brand indicated here) also had issues with when watching the background audio (like a sporting event) was louder than the people talking and could be interpreted as ringing--This is a setting in the set called something like "Theater" or "Hall"
Has to almost certainly be a setting in the set.
Mar 28, 2012 | JVC Televison & Video
Bought a vizio tv works good it but the volume control is real hard to get it to pick up every thing else works ok. It has the right code in.
Hey sherryg98, it sounds like you have a right code, but may not be a code to give full functionality as there are many codes for a Vizio TV.
You can check out this link for more info on codes: http://www.dishnetwork.com/SupportSection/remote-setup
Some codes you can try are 627, 766, 505, 006, 232, 458, 500, 670, 678. Depending on the model of your remote there may be different codes available. I've given the steps to address a remote below just in case.
Addressing Remote to TV:
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if working.
5.) If no function, repeat steps 1-4 with another code.
If you need any further assistance let me know here or email me at [email protected]
Jun 15, 2011 | DISH Network IR Remote Control
I HAVE AN AKAI TELEVISION WITH 8 BUTTONS ON THE FRONT 1 TV/VIDEO 2 CH UP 3 MUTE 4 VOL- 5 MENU 6 VOL+ 7 CH DN 8 TIMER
The button TV/Video button is used to select operating mode of the television. If you want to watch TV programs select TV. If you want to a watch movie from a DVD player you have to select VIDEO. The The CH UP is for channel search going up and CH DN for channel search going down. The VOL- is to lower the sound while VOL+ is to increase the sound. The MUTE button is used if you want your TV to run with no sound.
Dec 11, 2010 | Akai Televison & Video
TV turns off by itself or volume goes out usually within the first 15 minutes. The volume will go off and then I'll try to change stations and tv is black, I have to turn off, wait till the VIZIO light...
your Audio output chip has gone south and shorts out after warm up The unit will shut off to protect itself you need a tech to replace it try Pinicle Service solutions in Haverhill ma
Nov 02, 2009 | Vizio GV46L 46 in. LCD Television
Vizio screen goes black
It's possible that your sustainers are going bad. These are the two boards that goes vertically on both sides of the TV.
Jun 06, 2009 | V, Inc. Vizio P4 Plasma Television
Vizio speakers make a buzzing noise
The audio board on your 47" Vizio has gone bad. Replace that board will fix the problem.
Jan 21, 2009 | Vizio VO47L 47 in. LCD TV
Vizio L37 Television Logo
533 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Steve Allison
Steve Allison
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
