Question about Schwinn Exercise & Fitness
I need a SCHWINN ripp pro machine exercise manual--help! I just acquired this fantastic piece of equipment and need instructions on how to perform exercises with it.
I had the manual ebooked as they do not make the machine any longer and there are no paper manuals available here is the 800 # as Iit was sent after a phone call and I looked for a while believi it at 1-800-605-3369
Posted on Aug 01, 2012
3 Suggested Answers
SOURCE:
  • 103 Answers
SOURCE: i am looking for an exercise manual for the Weider
Hi there. You can go here and enter the model number (located under the seat) In the model number box and download a manual for free.
http://www.iconservice.com/CustomerService/manuals.do
Posted on Aug 16, 2010
SOURCE: I have a weider pro 4850 and I need the exercise
this is the for the assembly of the product not on how to perform the exercises dummy.
Posted on Nov 19, 2009
I need an owners manual for a Schwinn Recumbent Model 230 exercise bike. On line manual isn't for the 230 that i have. Will you send me one please?
We don't send anything. We are FIXYA, we are not Schwinn.
There are 5 different 230 models depending on the year. The manuals are in this link.
Product Manuals - Schwinn Fitness
www.schwinnfitness.com/manuals.html
  1. Cached
  2. Similar
Schwinn® 230 Recumbent Bike (2013 model), Assembly & Owner's Manual. Schwinn® 230 Recumbent Bike (2016 model), Assembly & Owner's Manual. Schwinn® 230i Recumbent Bike (2013 model), Assembly & Owner's Manual. Schwinn® 230i Recumbent Bike (2016 model), Assembly & Owner's Manual. Schwinn® ...
Schwinn Fitness Manuals
Dec 26, 2017 | Schwinn Exercise & Fitness
I need a user manual for the schwinn 120p exercise bike.
You can purchase one at FitnessRepairParts.com by going to the Schwinn 120p equipment page. They also have a complete parts list and diagram for this model.
Aug 25, 2010 | Sport & Outdoor - Others
How do I get a manual for different excersises for the Jones machine
Go to www.beyondmoseying.com click on commercial exercise equipment then strength & circuit then the Jones Machine their is a video that will show a number of exercises that cam be done with this unit or just call BodyCraft @ 1-800-990-5556 and see if they have a manual that shows how to use the equipment.
Jun 11, 2010 | Bodycraft Jones Lat Attachment with...
Owner's manual for older Schwinn Airdyne
http://support.nautilus.com/support/schwinn/uprightbikes/prdcdovr~3550012/Schwinn+Airdyne+Exercise+Bike.jsp
Follow this link and you can download the owners manual as well as the exploded parts schematics. There will be information about the different years. other than the consoles they have remained the same for 20 + years. If you ever need to replace the bottom bearing be sure to get the lock ring as well. It changed from left hand thread to right. Thats it. You can also upgrade the console to the newer version. A little expensive but with proper care a 20 year old Airdyne will last till the frame rusts out from under it.
Apr 23, 2009 | Schwinn 430 Elliptical Trainer
Rowing machine safety rules
" 1. Inspect equipment before each workout. Check that all nuts, bolts, screws and pop pins are in place and fully tightened. Also, before use, check cables for signs of wear. Replace all worn parts immediately. Never use machine if any parts are damaged or missing. FAILURE TO FOLLOW THESE RULES MAY RESULT IN SERIOUS INJURY. 2. Keep clear of cables and all moving parts when the machine is in use. 3. Always make sure all Snap Links are closed when doing any cable/pulley/strap exercises. 4. Exercise with care. Perform your exercises at a smooth moderate pace; never perform jerky or uncoordinated movements that may cause injury. 5. It is recommended that you should workout with a training partner. 6. Do not allow children or minors to play on or around this equipment. 7. If unsure of proper use of equipment, call your equipment dealer and ask him everything. 8. WARNING: Consult your physician before starting your exercise program. For your own safety, do not begin any exercise program without proper instruction."
Dec 01, 2008 | Kettler Rowing Machine Kadett Rowing...
Stair climbers / steppers maintenance
" * Read all maintenance instructions thoroughly before beginning work. * In some cases, an assistant is required to perform the necessary tasks, use all precautions. * The safety level given by the design of this equipment can only be maintained when the equipment is regularly examined for damage and wear. * Inoperable components should be replaced immediately or the equipment should be put out of use until it is repaired."
Dec 01, 2008 | Schwinn Wide Ride Pedal
Saftey rules
There is a risk assumed by all individuals who use this type of equipment. To minimize risk, you must follow these rules:1. Inspect equipment before each workout. Check that all nuts, bolts, screws and pop pins are in place and fully tightened. Also, before use, check cables for signs of wear. Replace all worn parts immediately. Never use machine if any parts are damaged or missing. FAILURE TO FOLLOW THESE RULES MAY RESULT IN SERIOUS INJURY. 2. Keep clear of cables and all moving parts when the machine is in use. 3.Always make sure all Snap Links are closed when doing any cable/pulley/strap exercises. 4. Exercise with care. Perform your exercises at a smooth moderate pace; never perform jerky or uncoordinated movements that may cause injury. 5. It is recommended that you should workout with a training partner. 6. Do not allow children or minors to play on or around this equipment. If unsure of proper use of equipment, call your local Body-Solid distributor or the Body-Solid customer service department at 1-800-556-3113. 8. ARNING: Consult your physician before starting your exercise program. For your own safety, do not begin any exercise program without proper instruction. Including maintaining the equipment the owner’s responsibility is also to: 1. Be sure to always provide adequate supervision to all end-users. 2. Be sure to instruct all end-users of proper usage. 3. Be sure all supervisors and personal trainers who instruct end-users on equipment use are properly trained and know the function and importance of every adjustment and setting. Also, be sure these trainers provide proper instruction to end-users on the fundamentals of strength training.
Dec 01, 2008 | Body Solid Cam Series Ab/Back Machine
Exercise & Fitness Logo
791 people viewed this question
Top Schwinn Exercise & Fitness Experts
Bill Boyd
Treadmill Repairs...
Tom Chichester
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
