My 38 hdc 024 carrier unit outside will not run
The unit inside turns on and blows...my unit outside will not turn on i can hear a click but nothing else..it was just put in (the whole unit inside and out..we double checked power and lines..charged it ..but itstill wont run??? Please help
  • Anonymous Aug 22, 2008
    inside unit is working and outside unit will turn on but the fan motor just hums what is my problen
    Scholar:
  • 54 Answers
WARNING THIS A DANGEROUS REPAIR DON'T TRY IT UNLESS YOUR QUALIFIED TO WORK ON HIGH VOLTAGE!!
Tip: Never complete a 220v< circuit with your vascular system.
New Unit? wow wheres the installer? kk I'm assuming thats a dead end for some reason. Check for 220v at the compressor relay. I'm gonna go out on a limb and say your not getting the 220v power that you need to operate the unit. Do you have other 220v appliances such as a dryer or stove, if they are working properly that means that both legs of the 220v are making it from the pole to the house. Is the wiring in the breaker panel to the breaker that protects your condenser secure and tight. Are you getting 220v to that breaker? Is the wiring in the disconnect box by the condenser secure and tight? Are you getting 220v there? Is the connections to the compressor relay secure and tight are you getting 220v there. Is the compressor relay closing and are you getting 220v to the compressor? See how this works. Lol, Fun isn't it GL I hope this helped.
Posted on Jun 08, 2008
Carrier 38 leo 30320 ac unit....when the compressor shuts off the fan keeps running. a rap on the control panel shuts it off. I when changed the contactor the inside unit stopped working so I put the
Hello, if the indoor blower runs nonstop a relay in the intergrated control board faulty and the whole board must be replaced, you can get tap the board to stop the blower but eventually the board will need to be replaced. If the contactor is clicking that means it is receivingpower from the indoor unit
Jun 16, 2012 | Carrier Heating & Cooling
WHEN AC UNIT IS TURNED ON WE HEAR A CLICK BUT NOTHING ELSE.... WHEN UNIT WAS FIRST TURNED ON IT WAS BLOWING AIR IN THE HOUSE NOT COLD BUT OUTSIDE FAN WAS NOT TURNING.,,,,, WE THREW ALL THE BREAKERS AND...
The capacitor in the electrical compartment has probably gone out, it will be a dual run configuration and a large round device with three terminals with multiple connections. Slao check all electrical connections.
May 18, 2011 | Goodman CKL60AR60 Air Conditioner
Ac unit clicks outside but nothing engages fan or compressor on unit furnace still runs for heat setting and fan still blows but ac will not engage just hear a clicking was running for three days this...
Have you check the outside breaker? If its ok then you got a problem in your electrical system inside the unit probably the contactor is not engaging this is where the 24 volts from the thermostat calls for the 240 volts to run the condenser fan and compressor. Be careful checking this out because of the high voltage.
Jul 09, 2010 | Carrier 38CKC048 Air Conditioner
AC running inside but outside unit not....keeps blowing breakers
Hello my name is Heath it will be my pleasure to assist you. The compressor is locked up. What you could do is try a hard start capacitor on the unit which would probably get the compressor turning without blowing the breaker.
Apr 27, 2010 | Carrier 38CKC036 Air Conditioner
I have a carrier 38YCBO48300 Over the years ithas a history of eating the start Caps Which I replace myself. This time the cap was leaking so I replaced it but the unit still will not run.The blower runs...
You must have a bad connection from either the thermostat or inside unit. Check the wire going from the outside unit to the inside unit. Look for any in-line fuses or the fuse on the circuit board.
Apr 02, 2010 | Carrier 38BRC048 Air Conditioner
My air conditioner is not running on the outside but in the inside. temperature states 85 inside
If you turn down the thermostat to the air conditioner and the unit outside does not come on, you could have a few different issues. The usual suspect is a start capcitor. When you adjust your thermostat you should hear a click from the outside unit. If you hear a click but nothing happens, check the power disconnect out there by the unit. I recently had to replace mine because it finally just wore out. It can also be the contactor, the fan itself or the actual compressor.
Jul 02, 2009 | Honeywell Heating & Cooling
My A/C outside will not run, inside a fan is blowing air (a little cooler than the 82 degrees it is in here, but not cold). Unlike all the other posts I've read, my unit outside is not making any noise. I...
I am not an a/c expert but mine did this one time and it was the transformer I think it is called pull the panel off and look for wires burnt at connections also. BE sure you cut power off before doing this
Aug 25, 2008 | Carrier 38CKC042 Air Conditioner
I have a colman ac unit and the outside unit will not come on. i hear it clicking but nothing happens
On my computer screen these two problems are not the same.
To "garys2003" Clicking you hear is the contactor closing in calling for cooling. If no power is being supplied to the outside unit high voltage the unit will not run. Check your circuit breaker or fuses in the outside power box. If the outside power box is of the non-fused disconnect, check that the disconnect is inserted properly.
To Trenina: Is your unit a self contained unit outside ducted to the inside as with a Mobile Home. If so your evaporator cooling coil may be frozen over stopping air movement, turn the cooling off and set your fan to on until it defrosts, then return to normal operation and leave the fan on during cooling.
If nothing comes on inside as with a central A/C system you may have a problem with the blower motor itself.
May 12, 2008 | Heating & Cooling
Heating & Cooling Logo
449 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
