Question about Lightning Audio FF150.2 Car Audio Amplifier
I'm currently driving the two rear speakers with this unit, would it be possible to add the two front one too? Or would I be better off with a different model?
  • kwanderi455 Oct 25, 2010
    Thank you the advise. That's kind of what I thought, but I'm no audio expert. I now have the info I need to implement the correct solution.
    Guru:
  • 773 Answers
This is a 2 channel amp. Right and left. It is also only 4 ohm stable. As long as you do not have an ohm load lower then 4 ohms, you can run what you want on it.
However.... If you run 2 more speakers off of this for the front, they would all be on the same rear channel, meaning you will have no fade, and some songs that are designed to have parts of the song louder in the front then the back, will loose some sound.
If you want to run front and rear speakers on an amp in your vehicle, it is best to either have a 4 channel amp,or buy another 2 channel amp. This way you ohm loads will be correct, and your balance and fade will be as well.
Typical setup, 4 channel amp running the front and rear speakers, and a Class D mono block am driving a subwoofer(s) in the trunk area. In place of 1 4 channel amp, you can use two 2 channel amps.
Posted on Oct 25, 2010
SOURCE:
If you can help me i need to know if it is possible to wire a amp into a 2002 landcrusier stock headunit cheers
yes, there is an amp turn-on wire from the head unit (black with a red stripe). You will need to add a power wire and fuse from the fuse box to run the amp. You can use the speaker outputs as inputs to the amp, depending on what you are trying to do. Please let me know if you need more help, and identify the amp model as well as the speakers you will connect.
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Black/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Black/Red
Car Stereo Amplifier Location: Under the center console.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): Yellow
Aug 27, 2011 | Car Audio & Video
Where do you hook up the external speakers?
Most common external speaker hook ups are RCA jack type or if it is an older unit it may have screw terminals. Most are clustered together and are marked clearly L or R channels and if it is a surround sound unit, it will have markings for front L, front right, rear L, rear R and center for 5.1; add two more channels for 7.1. These are located on the rear of the unit.
Hope this helps.
Feb 11, 2011 | Audio Players & Recorders
I need pinout assignments for a Philips 5.1 Home Theater Speaker system (PWR2006-37)? It has a DB-15 style input connector that hooks to the output of a Philips dvd / amp / control unit. this was...
Pin assignment is as follows (not sure of levels required- preamplification / attenuation may be necessary:
1: Control 0/5V.
2: Unused
3: Unused
4. Center speaker in
5. Ground
6. Ground
7. Subwoofer in
8. Ground
9. Unused
10. Ground
11. Left Front speaker in
12. Right Front speaker in
13. Ground
14. Right surround (rear) in
15. Left surround (rear) in
Jul 10, 2010 | Philips DVP642 DVD Player
I have a 1999 chevy prizm, I currently have a stoc...
The red wire is for ignition power, the yellow is for constant power, for the stereo memory, the black is the ground wire, the blue wire is for a remote amp or power antenna, the 2 white wires are for the front left speaker,and 2 gray wires are for the front right speaker, and the 2 purple wires are for the right rear speakers and 2 green are for the left rear speaker.
May 16, 2010 | Car Audio & Video
Subwoofer for alpine cde-9843
In short, no.
The CDE-9843 cannot drive a sub of the type you mention without an amp, but you can fit a sub with it's own built-in amp.
As standard, the head unit has a basic in-built amp supplying 4 x 16w RMS at 4ohms but there is the facility via the unit's own menu to turn off the in built amp and use the output sockets as a pre-amp feed, but in reality if you want to drive an amp you'd be better off to start with a more highly specified head unit to begin with, even the next model up, the CDE-9845 is better suited as there are pre-outs for front and rear speakers.
User instructions are available from here.
If my reply has been of assistance then please return the favour by rating my answer.
Nov 09, 2009 | Alpine CDE-9841 CD Player
Can I bridge channels on my JVC RX-D201S it cuts out when I turn the volume above 30 I want to drive 2 x DALI concept 6 front speakers 2 x concept 1 rears and a concept centre. Do you think I can add the...
putting the extra speakers on wont solve the problem the unit has a max output it might give a better alround sound so it will be clearer a little but pushing to far on standard speakers wont help if you need better go for some active speakers there more exspensive but will give better definition and the volume limit might be higher.
Aug 06, 2009 | Audio Players & Recorders
Hey is ther any why i can run six Speakers off this head unit + an amp and sub system?
The head unit will drive four speakers, 2 front ,2 rear.
Best way to add two more speakers and a sub is to get a 4 channel amp. Hook it up to the RCA jacks from your head unit. Bridge two channels of the amp to drive your sub, and use the other two channels of the amp to drive the extra two speakers. Just make sure whatever amp you get it's bridgeable.
Aug 05, 2009 | Sony CDX-M800 CD Player
Battery powered Car Speakers
your problem would be in doing this ,is that the battery you want to use may not have enough amperage to drive the amps as they do draw a lot of current
Oct 23, 2008 | Digital Audio 2000 WATTS SINGLE CHANNEL...
Need to know
I would recommend running a four channel amplifier using component speakers up front and co-axial speakers in the rear. You can add more speakers up front, but it depends on what you're trying to accomplish in your car. Do you want it louder? Do you want it clearer? Any system will benefit from an amplifier. More power to your speakers will give you better sound because you'll have more accurate control over the speaker cone. This extra power will result in better clarity, not only at high volume, but low volume too.
Sep 06, 2008 | Kenwood KDC-3024 CD Player
Wiring new speakers
hello melgiblett, as adding additional speakers to you current factory speakers will cause and abundance of power drain, you head unit is only designed to handle 4 speakers.. the only option would be to either splice your front or rear speakers to the new 6x9's, however you will notice a significant drop in audio volume and quality as your head unit would not be powerful enough to run all 6. with the assistance of an amplifier, you may be able to acheive all 6 speakers
May 31, 2008 | Car Audio & Video
Lightning Audio FF150.2 Car Audio Amplifier Logo
62 people viewed this question
Top Lightning Audio Car Audio & Video Experts
80stech
Mark Skinner
Sheldon Dedek
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
