Question about Raindrip R673CT Digital Water Timer
How do i set the programs - Raindrip R673CT Digital Water Timer
Raindrip shows three different timers
http://www.raindrip.com/timers
Click on your timer, and next page has manuals for you to download
Link below is manual for R673CT
http://www.raindrip.com/images/stories/pdfs/R673-digital-timer.pdf
The instructions fill up a page.
I am willing to help with problems you have while programming the timer.
Please get as far along as you can, and then answer this post, and I will help you further.
Posted on Oct 25, 2010
SOURCE:
I have totalmedia 3,5 arcsoft per windows vista, but i need to use it with windows 7. Could you help me? Thank you Gennaro
The router may not be the problem. It may be the compatibility issue.
Here is the article that addresses running older program with Windows 7
Make older programs run in this version of Windows
Most programs written for Windows Vista also work in this version of Windows, but some older programs might run poorly or not at all. If a program written for an earlier version of Windows doesn't run correctly, you can try changing the compatibility settings for the program, either manually or by using the Program Compatibility troubleshooter.
getcontent.aspx?assetid=745c7204-cf9f-46fb-a86c-98d4b9c644cf&documentset=en-us&prod=win700&market=us Go to the Windows website to watch the video. (1:26)
If changing the settings doesn't fix the problem, go to the program manufacturer's website to see if there is an update for the program.
Warning
  • Do not use the Program Compatibility troubleshooter on older antivirus programs, disk utilities, or other system programs because it might cause data loss or create a security risk.
To run the Program Compatibility troubleshooter
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open the Program Compatibility troubleshooter.
  2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
Tip
  • You can also open the Program Compatibility troubleshooter by right-clicking a program's icon or shortcut and then clicking Troubleshoot compatibility.
To change compatibility settings manually for a program, right-click the program icon, click Properties, and then click the Compatibility tab.
Setting
Description
Compatibility mode
Runs the program using settings from a previous version of Windows. Try this setting if you know the program is designed for (or worked in) a specific previous version of Windows.
Run in 256 colors
Uses a limited set of colors in the program. Some older programs are designed to use fewer colors.
Run in 640 × 480 screen resolution
Runs the program in a smaller-sized window. Try this setting if the graphical user interface appears jagged or is rendered improperly.
Disable visual themes
Disables themes on the program. Try this setting if you notice problems with the menus or buttons on the title bar of the program.
Disable desktop composition
Turns off transparency and other advanced display features. Choose this setting if window movement appears erratic or you notice other display problems.
Disable display scaling on high DPI settings
Turns off automatic resizing of programs if large-scale font size is in use. Try this setting if large-scale fonts are interfering with the appearance of the program. For more information, see Make the text on your screen larger or smaller.
Privilege level
Runs the program as an administrator. Some programs require administrator privileges to run properly. If you are not currently logged on as an administrator, this option is not available.
Change settings for all users
Lets you choose settings that will apply to all users on this computer.
Article ID: MSW700015
Jun 08, 2011 | Computers & Internet
IS NOT CAMPATIBLE WITH WIN 7
Run the Program Compatibility Wizard
  1. Open the Program Compatibility Wizard by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
  2. Follow the instructions in the wizard.
If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
Setting
Description
Compatibility mode
Run in 256 colors
Turns off automatic resizing of programs if large-scale font size is in use. Try this setting if large-scale fonts are interfering with the appearance of the program. For more information, see Make the text on your screen larger or smaller and Ways to improve display quality.
Privilege level
Show settings for all users
Dec 27, 2010 | Computers & Internet
Do not know how to set timer DT300 for Lights
Hi
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Thanks.
Dec 27, 2010 | Audio Players & Recorders
Can not reopen Cal Creator 10 On my new windows 7 computel please help
Make older programs run in this version of Windows (from help section in Windows 7)
Warning
Tip
?id=microsoft.windows.resources.collapsearrow?id=microsoft.windows.resources.expandarrow To change compatibility settings manually
Setting
Description
Compatibility mode
Run in 256 colors
Privilege level
Dec 18, 2010 | Broderbund Calendar Creator Deluxe 10 Full...
Please tell me how to program my timer. How do I set the time and when it should come on and go off everyday
Smarthome has the T-1032 pdf manual
http://www.smarthome.com/manuals/4256.pdf
1) Test installation to see if your wiring technique is correct.
Open cover > set on-off switch to 'ON'
Press the tiny round reset button with paper clip
Screen displays 0:00, MO, MAN, OFF
Close cover
Push cover inward like a push-button (the cover is the manual override)
Lights should turn on
If lights don't turn on, then you need to rewire ... so re-post a re-wire question ... and then come back to this answer to program
2) Set Time and Day/ Correct time and day are needed for programs to work.
To start, notice on the screen - in the corners are little letters: MAN, MO, OFF. And to left of time is PM.
Set the Hour: Press hour button until correct hour shows, including PM or AM
Set minutes: Press MIN button until correct minutes show
Set the day. Press day key ... MO in corner changes ... for example TU is Tuesday, WE Wednesday, TU Thursday
Press one of the control buttons to finish operation
Programming overview
Timer allows 7 programs
Program 1, Program 2 etc
Each program has ON and OFF time
So you have to select Program 1
And then set DAY for Program 1, set ON time for Program 1, and then set OFF time for Program 1
Next you do the same for Program 2 , and then Program 3, 4 etc to 7
If you only want Program 1, then you do not need to set Programs 2 thru 7
Let's program
Press PGM button ... the timer screen show a P to right of time
The number 1 appears below P and indicates Program 1
Set days you want Program 1 to work: Press day button and you can see MO TU WE TH etc appear on screen.
If you want all week long, press day button until all 7 days appear in tiny print on bottom of screen
Now you have the Day set for Program 1
Notice the screen shows ON ... this means you are going to set the ON time for Program 1
First, Set hour you want Program 1 to turn ON: press Hour button until correct AM PM time shows on screen
Last, set minutes to go along with hour: press MIN button until correct ON time minutes show
You have the day, hour and minute set for ON time
Set OFF time for Program 1: we are going to set a Day, hour and minute you want Program 1 to turn OFF
Press PGM button, and notice that OFF appears in top right corner of screen
Set the day you want timer to turn OFF for Program 1 by pressing DAY button >>> Tip set same days you set for ON times. So if you selected all seven days for ON time, then select all seven days for OFF time
Set the hour and minute you want Program 1 to turn OFF by using Hour and MIN buttons as before.
OK, the ON and OFF day, hour and minute are set for Program 1.
To continue to Program 2, press PGM button until a 2 appears on screen below the P
If you do not want to set more Programs, then you're finished
To finish, press any control button
Close the lid, cross your fingers, you did good
Sep 30, 2010 | Aube Technologies Aube 7-Day 40-500w Light...
Does not want to install Platinum print master version 18
The Windows® Vista Program Compatibility Wizard can allow older programs that were not designed for use with Windows® Vista to run on Windows® Vista.
The Program Compatibility Wizard prompts you to test the program in different modes (environments) and with various settings. For example, if the program was originally designed to run on Windows® XP2_bing.gif, set the compatibility mode to Windows® XP and try running the program again. If successful, the program will start in that mode each time. The wizard also allows the use of different settings, such as switching the display to 256 colors and the screen resolution2_bing.gif to 640 x 480 pixels.
To run the Program Compatibility Wizard, complete the steps below:
  1. Close all programs and windows and return to the desktop.
  2. Click the Start button on the Windows® taskbar. The Start Menu will appear.
  3. Click on Control Panel. The Control Panel window will appear.
  4. Click on Programs. Additional program options will display.
  5. In the Programs and Features section click the link Use An Older Program With This Version of Windows. The Program Compatibility Wizard will launch.
  6. Click Next to Continue.
  7. Click the “I want to choose from a list of programs” radio2_bing.gif button and click Next. A list of programs will display.
  8. Select the program that is to run in a Compatibility Mode and click Next to continue. A list of Compatibility Modes will display.
  9. Click the radio button next to the desired Compatibility Mode and click Next. A list of display settings will display.
    NOTE: These display settings are not available options in Windows® Vista. They are only available when running a program in Program Compatibility Mode. The only reason to choose either of these settings is if you are experiencing difficulty installing or running an older application designed to run in Windows® 95, Windows® ME or Windows® 98. If all options remain unchecked, then the current Colors and Screen Resolution settings will not be altered.
    By default, Windows® Vista uses visual themes that may change the appearance or behavior of other programs, especially those games or educational programs that include intensive graphics and animation. To prevent the visual themes from affecting these programs, check Disable Visual Themes.
  10. Choose the desired display settings and click Next to continue. Administrator privilege options will display.
  11. Choose the desired administrator privilege setting and click Next to continue. A Test Your Compatibility Settings window will display.
  12. Verify that the settings are correct. And click Next to continue.
    NOTE: If the settings are not correct, click the Back button to return to the previous screen (or screens) and make the necessary changes.
  13. With the correct settings selected and showing in the "Test Your Compatibility Settings" window, click Next. The selected program will launch.
  14. Run the program to test the settings.
  15. After testing the settings, or close the program to return to the Program Compatibility Wizard.
    NOTE: After the program is closed, a window with the question "Did the program work correctly?" will appear. The "Yes. Set this program to always use these compatibility settings" will be selected.
  16. If the program functioned properly using the compatibility mode that was selected above click Next. The Program Compatibility Data window will open.
    NOTE: If the program did not function correctly, click "No, try different compatibility settings" and complete the Wizard. After completing the wizard, try the program again.
  17. Choose Yes or Now and click Next to continue. The Completing the Program Compatibility Wizard window will appear. Click Finish to close the window.
  18. Launch and use the program.
NOTE: If you have questions regarding the Program Compatibility Wizard or Windows® Vista (or both), contact Microsoft®, or go to http://www.microsoft.com for additional information.
Apr 01, 2010 | Broderbund PrintMaster Platinum Version 18
Is a 64-bit windows compatible version available?
The Program Compatibility Wizard prompts you to test the program in different modes (environments) and with various settings. For example, if the program was originally designed to run on Windows® XP, set the compatibility mode to Windows® XP and try running the program again. If successful, the program will start in that mode each time. The wizard also allows the use of different settings, such as switching the display to 256 colors and the screen resolution to 640 x 480 pixels.
  7. Click the “I want to choose from a list of programs” radio button and click Next. A list of programs will display.
Apr 01, 2010 | Broderbund American Greetings Creatacard...
Can I run Printmaster Platinum 16 with windows vista
Yes you can !!!
The Windows® Vista2_bing.gif Program Compatibility Wizard can allow older programs that were not designed for use with Windows® Vista to run on Windows® Vista.
The Program Compatibility Wizard prompts you to test the program in different modes (environments) and with various settings. For example, if the program was originally designed to run on Windows® XP2_bing.gif, set the compatibility mode to Windows® XP and try running the program again. If successful, the program will start in that mode each time. The wizard also allows the use of different settings, such as switching the display to 256 colors and the screen resolution to 640 x 480 pixels.
Mar 31, 2010 | Broderbund PrintMaster Platinum 16
"trying to set AOL as default email program when sending photos" via windows photo gallery using Vista
you can set aol as the default email program by pressing start / then all programs or program / then you should see program access and defaults, use the program to set your email program settings all into aol. if you wish.
Jun 03, 2009 | Microsoft Windows Vista Home Basic for PC
Raindrip R673CT Digital Water Timer Logo
234 people viewed this question
Top Raindrip Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Brett Duxbury
Brett Duxbury
Are you a Raindrip Hardware and Accessory Expert? Answer questions, earn points and help others
