Question about Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Dryer stops running after 10 minutes no heat at all all light flashing and stops. repairman came out and put new part in, but said the reason was we had a problem was we had a telescopic vent that caused dryer to overheat. His fix was to put a reset switch. problem is it shut off after one week, and we don't know how to open the dryer up to hit the reset button. Also my husbnd doesn't beleve the theory about the telescopic vent being the problem. Has anybody had similar problems, or instructions on how to open the dryer up to get at the reset button?
    New Friend:
I'm having this exact same problem. What was the final solution??
Posted on Oct 10, 2011
SOURCE:
My Maytag Bravos dryer is shutting off after running 10-20 minutes. Will not restart for an hour. Feels very warm
Have you considered calling a repairman .. sounds like you have a thermal overload malfunction .
Mar 16, 2016 | Maytag Dryers
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
Maytag dryer panel lights are flashing how do I reset
Unplug the machine for a couple of minutes. Let the onboard computer reset itself this way. Plug back in and see if it stops the flashing lights. If unplugging for a couple of minutes does not solve the problem, call a repairman or contact the seller where you bought the machine and ask them what you can do. Hopefully the flashing lights are not an indication of larger problem that only a repairman can fix. Worth a try.
Nov 01, 2014 | Dryers
Summit washer/dryer combo quit drying. Repairman came and replaced themafuse and thermastat kit. Shortly thereafter, the dryer cycle timer would indicate 10 minutes left and never clock down. The dryer...
summit washers are prone to board failures i would say that is where the fault lies . thermafuse fuse means it has been overheating. means it can damage other parts. thermostat would thing that has just worn out thermostat can go if the unit overheats. under line is an electrical fault. but like i've said it is a common fault with this make and others. the main boards can only handle around 50c in temp after that they start to over heat and cause problems. the faults started when they moved the main board from the bottom to the middle.
Oct 25, 2013 | Summit SPWD1470C 24 Inch Washer Dryer...
Stops and all the lights come on
Instructions
    • 1 Make sure the home's gas supply valve is turned on. Check your Maytag owner's manual to find the location of the dryer's gas shut-off valve. This is usually behind the dryer's front panel or in the back of the unit. Open the valve to allow gas to flow into the dryer.
    • 2 Open the lower front panel of the dryer to access the pilot light assembly. Press and hold the starter button as you light the pilot with a handheld lighter. If you have trouble getting it to light, release the starter button and wait a few minutes before trying it again. Once the pilot is lit, hold the starter button down for another minute to make sure it will stay burning.
    • 3 Close the dryer's front panel and run a test cycle to see if it is producing heat. Call a repairman to evaluate the problem if lighting the pilot did not restore the heat.
Jan 15, 2013 | Kenmore Dryers
My dryer is not getting hot. After 10-15 minutes of running, it stops and all of the lights on the control panal flash. The screen that usually reads the time reads "Aj"
it is more then likely the heating element, here is a website to assist you, Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Mar 06, 2011 | Frigidaire Electric Dryer
The dryer is new and its not drying at all. also ths cooling system light is on?
Usually the reason is the exhaust vent in the wall leading to the outside of the house is heavily restricted with lint or other debris. Pull the exhaust vent out of the wall and run the dryer to see if the load dries normally. If it does, you will need someone to clear out the exhaust vent to resolve the drying issue.
The cooling light is a display that tells you what will be happening during the cycle. When it flashes, the dryer is in the cooling mode and is continuing its operation but with no heat. That usually lasts about 10 to 15 minutes.
Good lucj
Oct 04, 2010 | LG DLE2301 Electric Dryer
Haier washer/dryer combo not drying clothes
Check things like the Filter / clear fluff...Make sure outlet hose if any is not kinked and passing air..Hope this helps..
Oct 02, 2009 | Haier 14.3 lb. Washer/Dryer Combo
Dryer stops working after 10 minutes
Motor may be over heating.may need new motor.
Mar 01, 2009 | Kenmore 73952 Gas Dryer
Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer Logo
401 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
