Question about Crane Cow Humidifier
How can you tell if it is working or not, it used to have a visible mist coming out, now it doesn't, you can feel air coming out and hear the fan working, but is it working?
    New Friend:
Check the fan area on the base. My spongebob humidifier did the same thing, and then I noticed smoke and sparks coming from the fan area. i am trying to contact Crane for a replacement, but its 2 years old, and warranty is over.
Posted on Feb 02, 2011
SOURCE:
I got the Crane Cool Mist humidifier - drop shape in blue. Although i can feel a small amount of air coming out from the spout, mist is not visible, not a bit.
if you can hear the fun noise, you need to check major circuit, should be bad capacitor. if no noise at all, replace the fun.
actually they have very good customer service. just contact by email or phone, tell them what's happened, they should give you a RMA number, put the tank cap and cut small piece of power cable, send to them, you will receive a brand new humidifier within couple weeks. even your machine slightly out of warranty.
Apr 02, 2011 | Crane Humidifiers
I do daycare a parent brought me the nebuilzers/breathing machine it sounds like is on but I see no mist or vapor I disesemble to see if i feel air and i do but i see no vapor mother tells me it just...
Is there distilled water or liquid medication in the container? If not, all that will come out is air. There should be an adjustment valve on the hand-held part of the nebulizer, that adjusts the liquid flow and turns it into a mist.
Apr 01, 2011 | Humidifiers
There is not mist coming out. What should I do??
The moisture released by this (or any ultrasonic) humidifier should not be visible, so it is very possible that it is working correctly. Try filling the reservoir and marking the water level with a small piece of tape. Then run the humidifier for a few hours, and check the water level again. If the water level is below the edge of the tape, then you know it is releasing moisture into the air, and everything is working fine.
The older style of humidifiers created a mist by spinning a disk that was partly dipped into the water reservoir. They had to be refilled often, and the mist could leave water spots or dust on nearby furniture. The water level should change very slowly in your ultrasonic humidIfier compared to a misting humidifier.
Jan 13, 2011 | Vicks Ultrasonic V5100 Humidifier
Hello...i have a sunbeam filter free warm mist humidifier,and i put the water in and turn it on but it doesn't seem to be working. All the lites are on but nothing and it's brand new too never been used.
Hi, have you given it a while? That humidifier usually takes about 10 minutes to get going. After 10 minutes or so you should be able to feel the warm mist coming out, and soon after you should feel a difference in the moisture in the air.
Nov 28, 2010 | Sunbeam Health at Home Warm Mist...
Why does my humidifiers does not have any smoke coming out?
My Guess is that the reletive humidity in the room is not low enough to see any vapors coming from the machine. Normaly you won't see these anyway. Some models in the stores seem to make more mist than what you get at home. If the humididty level in a room is close to what is coming out of the machine there will be no signs of any mist coming out. Just make sure the filters are clean and check and make sure the water level is going down on the machine and this will tell you its workin. the faster you are using the water in the tank the more you are putting in the air! If this is a hot mist machine then I would say the heating element in the machine is not working.
Nov 16, 2010 | Venta Airwasher VS370 2 Gallon Humidifier
Family Care cold mist humidifer
cool mist humidifiers don't put out any mist. only the warm ones do. now if you put your hand over the area where it's coming out for about 2 minutes and take it away your hand should feel damp. almost clammy. if it feels like that the unit is working fine. so your not doing anything wrong. if you have any other concerns please let me know.
Mar 13, 2009 | Family Care HM1555 Humidifier
No mist!
unfortunately on a cool mist unit the mist shouldn't show up. on most units that's what it does. the warm mist units show the mist.. the best way to tell is if you put your hand over the spout that the mist is suppose to come out of for about 2 minutes and you pull it away and it feel clammy then it's working. if your hand is still dry please let me know and i'll see what else i can do for you.
Feb 26, 2009 | Holmes Products HM500-UC 1 Gallon...
Fan is running but humidity is not changing
Q: My unit has been running for several hours. I hear the fan spinning, but I do not notice the water level in the tank decreasing.
A:
First, check the filter to ensure it is wet. If the pad appears dry, remove it from the Base and gently rinse under cool water. Reposition wet filter in the Base. You may also want to note the current moisture level in your home. If the humidity level is over 60% the unit will not put out much moisture
as your air is already saturated.
UV bulb and filter are user replacement items
see manual from my other post
Owners manual LINK
Comment by Soulvisitor, posted on Jan 20, 2008 You should notice moisture on the widows in the room after unit has run for awile, this unit carries a 3 year warranty. More info coming...
Comment by Soulvisitor, posted on Jan 20, 2008 see this
4b54ac1.jpg Comment by Soulvisitor, posted on Jan 20, 2008 If water level in tank is dropping and fan runs then I'd say it is working.
OK?
Comment by Soulvisitor, posted on Jan 20, 2008 Q: I hear the fan turning, but I don’t see any mist. Is my humidifier operating properly?
A:
Dry air is pulled through the system and a fan disperses invisible, moisture balanced air. There is no
“mist” emitted. When operating normally you will feel only cool air coming from the unit. Monitor the
water level in your Tank/ Base. If you notice a decrease in the Water Tank over 24 hours then the unit
is operating normally.
Dec 02, 2007 | Honeywell HCM-300T Humidifier
Crane Cow Humidifier Logo
435 people viewed this question
Top Crane Humidifiers Experts
gggg
STEVE
Andrew Taylor
Andrew Taylor
Are you a Crane Humidifier Expert? Answer questions, earn points and help others
