Kemore washer/dryer starts briefly,then stops but continues humming.no water is introduced into cycle
  • 11,896 Answers
If there is no water entering or exiting themachine, then either the water valve is faulty and not letting water in, or there is no power to the water valve, or the pump is faulty and not pumping the water which is possible.
Posted on Oct 26, 2010
    President:
  • 1,554 Answers
The problem sounds complicated and troubleshooting can be very difficult and inaccurate since very limited information is given. Describe the problem explicitly, indicate where the humming noise is coming from and the most important information is the exact model number of the machine. You don't have to accept or reject and rate a solution to add information, comments, and follow-up questions. But accepting a solution will not terminate your communication with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Oct 25, 2010
  • Jahn27
    Jahn27 Oct 26, 2010
    Please provide the requested information for accurate troubleshooting. You don't have to accept or reject and rate a solution to add information, comments, and follow-up questions. But accepting a solution will not terminate your communication with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
SOURCE:
Kemore washer
REPLACE THE SWITHS DOOR
Aug 06, 2012 | Kenmore Washing Machines
Washer souds like trying to engage but won't
If the motor hums and will not pump out or spin, the motor is bad. It reverses direction and the reverse windings appear to be burned out.
Dec 28, 2009 | Kenmore 22422 Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Kenmore elite washer problem
LD stands for long drain, you probably have a bad pump or the pump is clogged with lint etc.
Jan 15, 2009 | Kenmore Elite HE4 Electric Dryer
My front loader has stopped in the middle of the cycle.
you need to clean your pump something is stuck not allowing the pump to drain
Dec 25, 2008 | Washing Machines
Dryer stopped working
The dryers drive belt most likely broke. it must be replaced with a new one.
Dec 20, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Maytag Performa Dishwasher draws water then stops
More than likely you need to replace the washer control panel.
Jul 19, 2017 | Maytag 24 in. MDB5600A Jetclean II...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
