Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
The screen flickered then the tv shut off. now the power light turns on for about 5 seconds then it shuts itself back off. i unplugged it and let it sit overnight, the next day it came on for a few hours then it went down again. i cant get the tv to stay on now. any idea?
5 Suggested Answers
SOURCE:
  • 119 Answers
SOURCE: tv doesnt complete power on, shuts itself down 3 times
the 3 start attempts in the tv indicate a horizontal shut down fault. if you have repair knowledg, the most likely thing is the capacitors in the horizontal circuit, check those. then check diodes. if the tv still does not work then you have a bad high viltage transformer or a bad hight voltage splitter. further testing becoms dangerous to do at home due to the high voltage. if the caps are bad the typically run around $4- 12 each, h.v. parts $75 to $125. each + you local shop rates. good luck.
Posted on Jan 03, 2007
  • 97 Answers
SOURCE: Green screen for 30 seconds, then shuts down
yes you need a new picture tube, those tend to lose there power after a few years.
Posted on Jul 15, 2008
SOURCE: TV shuts self off
Did you get your problem fixed?
Posted on May 24, 2009
yammy_alf
  • 666 Answers
SOURCE: Screen Flicker then tv shuts off
please re solder  first all parts specially in hot area, and observe if problem still occur, then next is replace filter capacitor. observe also too hot parts and check for change value resistor.
Posted on Apr 04, 2010
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
Feb 25, 2016 | Sony Televison & Video
Philips LCD TV Turns Off After Being Turned On
Most LCD TV power problems are simply solved by replacing the power supply board.
Oct 07, 2017 | Audio Players & Recorders
Hi, my Panasonic PT47WX49E rear projection tv suddenly shut itself off. It won't turn back on at all unless I unplug it and plug it back in. However, when I do that, the power light comes on but nothing...
Either give me a yahoo or note if light on front of set blinks--count the blinks if it does.
most common is 3 blinks, pause 3 or 5 blinks etc.
Let me know if I can assist you.
SD TECH
Sep 14, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Help me
Either lamp or ballast(driver) bad, likely.
Apr 07, 2010 | Philips Magnavox 51MP392H Rear Projection...
My Philips 20PT633 has started shutting off mid program.
Consult your technician there is a semiconductor problem inside your tv. Probably lose connection, and need to resolder.
Jun 08, 2009 | Philips 20PT633R 20" TV
When I power up, 5 seconds later this back projector TV turns itself off
t does sound like a bulb problem, either its over heating and shutting off to protect itself, or its already shot. Give a TV repair shop a call and see if they can give you an approximate price, then decide to ditch or repair it.
May 30, 2009 | Televison & Video
The tv suddenly shuts off
flyback on the verge of giveing out on you.. needs a new flyback..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 21, 2009 | Toshiba CF36G40 36" TV
Blinking light on 37" Dynex LCD
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Dec 22, 2008 | Dynex DX-LCD37 TV
TV turns on and then suddenly the screen will shut off but the power will remain on
there is a problem somewhere in the power supply or horizontal circut.
It will need a technition to troubleshoot this problem.
Thanks Guy9
May 04, 2008 | Hitachi 50UX58B 50" Rear Projection...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
54 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
