Question about Samsung 226BW Monitor
2232bw samsung DVI in problem
(Couldn't find the monitor in the product section so i chose the earlier model.)
I just got a 2232bw Samsung monitor and went to go set it up. When it came time to put in the DVI Cable, it would not go in. It goes in on one side but the other side has just doesn't fit. When looking at the jack in the monitor, there are cutlike things where the red is that look like it is off center.
It will plug right into the computer. Do i need a new monitor or is it fixable
Try a DVI-D (Digital) Only cable, without the analog (right section). I´m basically talking about a DVI-D to DVI-D cable.
Posted on Jul 26, 2008
Have a Samsung SyncMaster 2232bw monitor that the power button flash is there a reset button on this monitor
I have another model of Samsung Syncmater monitors.
According to the manual, press the Source button then a key on the keyboard.
http://downloadcenter.samsung.com/content/UM/200707/20070721174815531_BN59-00585T-01Eng.pdf
According to http://www.tomshardware.com/forum/267699-33-samsung-syncmaster-906bw-display try pressing Source and Power or Power and Auto button at the same time.
Per Tomshardware.com, if these things don't work then the monitor needs an electronic repair(detailed in forum) or, if you are unable to get it fixed, replacement.
Please check http://www.fixya.com/support/t255653-syncmaster_paower_button_blinking_no for additional information.
Mar 24, 2016 | Samsung Computers & Internet
I have Syncmaster 2232bw. When I first switch it on it flashes for about 1 minute before it stopsa flashing. After that it runs fine until I switch off and it cools. Is this the backlight dying?
This happened with my 2232bw also. The problem was that the 5 820uF capacitors that had burnt out so I replaced them with 5 1000uF capacitors and it's now working like a dream.
Hope This Helps
Slick2160
Oct 15, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor not wrking
Sounds like you may have had a power surge.??
Disconnect power and signal input.
Turn the unit off for 20 minutes or so. Check the outlet against another device. ( Light )
Turn unit on without connection to PC video.
If you get a no signal, you good to go . Reconnect. If you continue to get a flashing light on power button,
Check warranty, get it back to Samsung for repair.
Hope this has helped
Sep 02, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Screen flickers in 1680x1050 - samsung 2232BW plus
Can your monitor AND PC put out that resolution??
I don't think your Dell and put that out, if it's an "old" machine.
Dec 02, 2008 | Computers & Internet
Any suggestions ?
hello,
firstly you check this monitor to another pc. it the same problem accure then
i thinks this problem due to falure of power supply or dead of flurocent tube. or any the vga cable is faulty.
ok
bye
Oct 29, 2008 | Samsung SyncMaster 920N 19" LCD Monitor
Samsung 2232bw monitor
this shows the internal circut problem, need to consult a technician
Oct 28, 2008 | Samsung 226BW Monitor
There is nothing broken, but you must become aware of the different standards in DVI connectors.
1)DVI-D which you have, does not have the 4 analog control pins around the alpha bar meaning it only works on digital devices.
2)DVI-A only has the 4 control pins and no bar, as well as a total of only 9-10 pins altogether. This is designed for analog only, and rarely see it anymore.
3)DVI-I stands for Interlaced, meaning it can work both ways, but will not fit in monitors that are set up for DVI-D because the analog pin sockets do not exist.
You can get more detailed by counting the pins in the rectangular area, if you use all 24 pins you have what is called a Dual-Link cable, so it can support resolutions over 1920x1280 if you have about 9 pins missing it is single-link and is limited resolution.
Jun 08, 2008 | Samsung 226BW Monitor
No sound in sm2232bw monitor
CURSE YOU SAMSUNG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Ok, I'm done now. Some monitors require a separate power supply for their speakers. I don't know if yours would have one, so you'll have to check. Also, are you sure that you have it connected properly? It you do, are you sure that the monitor has built-in speakers? Once you have checked these things, get back to me.
Mar 16, 2008 | Computers & Internet
Samsung monitor and mac os
Please do not adjust RGB unless you know what you are doing.
For critical color work, you will need to use a photospectrometer and calibration software to analyze what your monitor is spitting out.
There are a million obvious reasons you should not trust your eye making arbitrary RGB adjustments off the hip.
Feb 15, 2008 | ViewSonic VX2255 Monitor
Open Questions:
See all Samsung 226BW Monitor Questions
Samsung 226BW Monitor Logo
260 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
