Question about Samsung Televison & Video
How do you turn off the screen saver on the 50" plasma tv
    New Friend:
When you are in 'TV' mode press the MENU button on the remote. Click on 'picture' then scroll down to picture options and press enter. Scroll to the bottom and click on 'Burn Screen Protection'. You then need to turn off the 'Auto Protection time'. After this, it is a good idea to go to pixel shift, turn it on and set values 4, 4, 1 for Horizontal, Vertical and Time respectively. (You can set your own options though). XD. Jacob.
Posted on Dec 08, 2010
SOURCE:
SOURCE: I have a Philips 50 inch plasma tv. The light is
I have Philips 50 inch plasma TV purchased almost exactly 3 years ago. Completely out of warranty. Paid 1999 bucks for it new. Now Plasma TVs similar to this are 800 bucks. I figured the cost of a repair tech coming to the house would be around 500 bucks.. so I decided I could "do no harm" and look at the power supply. Sure enough, two 3300 uF caps were swollen.. I am far from a true electrical repair person, and if it were not for the caps being swollen, would have no idea that they were bad. I am however a little bit skilled in soldering. So I ordered replacements for about 8 bucks. The caps were actually only 1.50 ea. but the min order fee and shipping brought it to about 8 bucks.. I got them from studiosoundelectronics.com . They came in today and installed them... to my astonishment, my TV works as good as it did when it was new... I must say that I am dissapointed in Philips.. and will never buy another product from them. If it is out of warranty.. they will not even talk to you.. I don't think it is too much to ask when you spend 1999 bucks on a product from them.. I expected my TV to have more than 2.999 years in life in it. Thanks a million to this site for providing soulutions for folks..
Jeff
Florence AL
Posted on Oct 03, 2009
roety
  • 587 Answers
SOURCE: My 50'' Samsung Plasma has dead screen after only 2 years
welcome to fixya!
without doing voltage checks, my best guess is this:
Plasma hpr5053 or hps5053 models will burn out a buffer board or both, there are two buffers and the Y board.
I usually change all 3 at once, but if on a budget you can try to remove one buffer and see if you get half picture (upper or lower)
this is something only a technician should attempt. the boards cost $200 each (buffers)
$300-$400 (Y board).
if you actually get half a picture the Y and one buffer are good, a bad buffer usually burns out the Y board. and in really bad cases the panel is bad also (not common, but possible)
For part#s , specific help you can post a model# , but again this is a repairmans job not something the average customer can fix.
hope this helps
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Aug 27, 2009
Testimonial: "thank you sounds greek to me and costly but I guess I have to do what I have to do-----have you ever heard of a video IC board?"
SOURCE: we have samsung 50 inch plasma tv, we have only half a screen
I have a Phillips 50 inch Plasma. About two months out of warranty the top half of the screen would go black. Sometimes when we tapped on the back behind the upper right hand corner the picture would return. I did some research online and found that there is a Main Y sustain board (much like a mother board in a computer) and connected to that board is a upper Y Buffer board and a Lower Y buffer board. According to my research these boards seem to be the source of the problem. I am assuming that the upper buffer controls the top half of my screen and the lower controls the bottom. I removed the back of my TV (about 50 small screws) and searched for these parts by part number. Surprisingly all of the parts in my Phillips are made by Samsung. I found the parts on ebay at shopjimmy.com. I decided to try replacing the upper Y buffer first. I ordered it from shopjimmy for about 100.00. When I received the part I started to remove my upper Y buffer and realized that the new part was slightly different. The part number was the same but the REV. number was slightly different. The new part was missing a small white connector that connects the upper buffer to the lower buffer. I sent it back for an exchange for the right part with no problem. Ok so here is the interesting piece of this little adventure. When I started to remove my upper Y buffer I removed the screws and started to pull on it to loosen it. When I noticed that I had the wrong part I pushed it back into place and put the screws back . My TV has worked perfectly since I did that, with my original part. It has only been about two months, but if you are in the same situation it might be worth a try.
Posted on Oct 24, 2008
  • 8457 Answers
SOURCE: my vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Posted on Jan 08, 2010
xptareq2000
  • 1447 Answers
SOURCE: half of my screen plasma TV 50
Your Television problem on vertical section.
Solve: If you repair itself replace vertical IC or thoroughly resolder dry any components.
Posted on Jan 10, 2010
Plasma tv repair
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on ... samsung plasma tvnot working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56. by Matthew ...
Plasma TV Repair Tutorial - Common Symptoms ... - YouTube
? 7:13
https://www.youtube.com/watch?v=gnkyAGyI7GA
Oct 9, 2013 - Uploaded by ShopJimmy.com
Plasma TV Repair Tutorial - Common Symptoms & Solutions - How to Fix .... Samsung 50" Lcd tv model#Lf501EM6f Im not sure if its plasma or ...
WHAT Plasma TV BOARD CAUSES NO PICTURE REVIEW ...
? 4:10
https://www.youtube.com/watch?v=DC_75FfrR9w
Nov 8, 2012 - Uploaded by Tampatec
WHAT COMMON PART / TV Board IS BAD ON SAMSUNG Plasma ... a gamble. it the cost of repair is over 300 just buy a new 50 inch tv for 600.
Samsung 50" Tv Power Supply Boar...$34.00eBaySAMSUNG UN60EH6002FXZA...$23.00TV Parts Guy42% price dropSamsung 50" Pn50c550 Pn50c45...$18.99eBay
Dec 21, 2015 | Samsung PN60F5500 60-Inch 1080p 600Hz 3D...
Black line Down middle of 50" plasma screen tv
The tv T-CON board it is dying to causes this problems.This T-CON board sit in the middle at the bottom of the tv plasma screen panel.Try website like Ebay.com to buy a whloe new refurbish T-CON board for the replacement.
Jul 18, 2011 | Samsung 50 in. Plasma TV
My 50" plasma fell and
hello linda...
Plasma screen can be replaced with the new one, but its expensive like you buy new one.
Call samsung service center for informations.
Jun 28, 2011 | Samsung 50 in. Plasma TV
When the Samsung 50" plasma TV is turned on and during the whole time the TV is running there is one small green dot (or light) in around the middle of the screen. It continues and does not go away as the...
Still under warrenty?Yes,call the tv manufacture,get this tv replaced quickly.The Plasma screen is developing a burn in dead pixels.This problems,can't not be repair.Except replaced the Plasma screen itself.The plasma screen panel are 90% of the tvs,not worth repairing,if it damages or broken.Will cost the same as a new tv,if the screen require replacing.Still under warrenty call it in right away to get the picture screen replaced under warrenty.
Oct 04, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
I have a vizio p50hdtv10a every time i turn it on it goes into a deep sleep
is your tv energy saver? my tv has a feature and the screen goes blank check and see what your settings are on
Apr 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
No screen saver
depending on your tv there is a function to turn screen off. most tvs come with this feature. on the remote there will be an power key with a red or black button. this is to turn the screen off. if it does not have this function and there is no screen saver setting on the dvd play there is not much you can do for this situation .
Jul 05, 2017 | Panasonic DVD-S97 DVD Player
Plasma tv burn in
Hey napa15rt,
Many manufacturers may suggest not using video game consoles in conjunction with plasma or projection TV's, due to the potential risk of image retention. Unfortunately, image retention (or "image burn") can be caused by any number of sources including letter-box formatting, test patterns, scrolling banners and even the heads-up displays of many video games.
While some video game publishers may have taken this into consideration by including a "screen saver" of sorts for when the game is on pause, this cannot be guaranteed to apply to every game or console available.
Generally, you may avoid image retention by limiting the amount of time that any image is displayed on your TV screen. Simply turning the TV off when you're taking a break can often be one of the best ways to do so.
Additionally, please keep in mind that some Insignia TV models may offer a feature called Image Sticking Minimalization (or ISM) that is designed to help prevent image burn. For more information on your TV model and the ISM feature, you may wish to refer to your owner's manual or Insignia's website:
http://www.insignia-products.com/default.aspx
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 03, 2008 | Televison & Video
Televison & Video Logo
6,819 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
