Question about Garmin Nuvi 660 GPS Receiver
We have a Garmin Nuvi GPS which was purchased just over a year ago. It was working fine but all of a sudden was not. The message coming up is Cannot unlock maps? What do we need to do to solve this problem as we are unable to use the GPS and it is very frustrating. Regards, Leanne Dalglish
  • Garmin Master
  • 2,130 Answers
Your unlock code has become corrupted or the map has been deleted from the Nuvi's drive.
Please email me at: sharcnet-usa AT sharc DOT net and I'll be try to help you resolve this issue.
- Jim
SHARCNET-USA
Posted on Nov 04, 2010
SOURCE:
Garmin Nuvi 610 not Acquiring satelites. it was working fine and while driving suddenly said something about poor reception, now nothing
Its sounds like your GPS's internal receiver is broken, you may be able to fix this with a firmware update but it is likely you will have to purchase an external antenna for your GPS to be functional.
Hope this helps!
Dec 10, 2010 | Garmin Nuvi 610 GPS Receiver
I turn on the Garmin 265wt and it boots up, searches for satilites and then freezes. I have only had it for 2 months and all of a sudden this is happening. Although it worked fine yesturday and then the...
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted. Don't skip the hard reset step (or the backup step!)
I can help you reset and fix your Garmin Nuvi 265WT.
There are three steps to take to get your Nuvi 265WT running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265W Manuals here.
Mar 04, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
My Garmin nuvi 250W GPS is NOT powering on.
try connecting it to your computer via the usb cable. that may reset it. outdated maps will not cause this problem.
Feb 21, 2010 | Garmin nuvi 250W GPS Receiver
Was working fine and suddenly deided to lose maps. message on screen says "no detailed maps found that support routing. The nuvi cannot be used without them." What happened and how do I GET THEM BACK. ...
Call up Garmin and have them walk you threw a trouble shooting procedure. It sounds like your unit has erased itself by no fault of yours. Garmin will replace it once you get ahold of them. There is not anything that we can do without thier support.
Nov 25, 2009 | Garmin nuvi 205 GPS Receiver
Garmin Nuvi not acquiring satellite
I am having the same problem with my nuvi 350 and its about the same age. I read on another post it may need a new battery but you need to send it to garmin. I am going to contact garmin directly.
Aug 20, 2009 | Garmin nuvi 350 GPS Receiver
My Garmin Nuvi 200 has a message that says No detailed maps found that support routing. The nuvi cannot be used without them. I just used this garmin a few hours ago, and it was fine. Now I can't get...
You need to call garmin to have them help you unlock your unit. It sometimes requires the 25 digit unlock code which they have on hand. 1-800-800-1020 I believe.
Aug 15, 2009 | Garmin nuvi 200 Car GPS Receiver
No detailed maps found. Help! Please
my email address is ada @ ebucksmail.com.
Can u please help with my sons nuvi 200 that shows no detailed mapsfound. Thanks A Million, Ada.
Jan 22, 2009 | Garmin nuvi 350 GPS Receiver
Garmin NUVI 200w
the same issue with mine, but mine cut out after one day. Purchased 6-9-08
Jun 09, 2008 | Garmin nuvi 200W GPS Receiver
Garmin gps
How old is the gps, if you answer is more than 2 years could mean you have a bad antenna, i would look into purchasing the extended antenna from the manufacturer if its not too expensive to test that theory.
Oct 23, 2007 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
71 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
