Question about Dishwashers
I have a 4H code on my whirlpool dishwasher and it does not cancel out so my machine is not working, how do I clear the code and what does it mean?
5 Suggested Answers
SOURCE:
SOURCE: Whirlpool dishwasher ADP5962 F7 error code
f7 means lack of water. It could be caused from dirty (internal) filter or chocked water pipe
Posted on May 29, 2008
  • 117 Answers
SOURCE: whirlpool dishwasher won't start
Your dishwasher has one door switch and the dishwasher will not operate if this switch is not working. So you are right!
Posted on Feb 25, 2009
emmanuelr is spot on with this advice. The dishwasherr had been idle for a few months so as advised disconnected and reconnected the connection to the water flow meter and job done. My friend you are a scholar and a gentleman thank you so much. You are not an apprentice to me.
Posted on Apr 06, 2010
I have had the same problem with my dishwasher. I.e., the buttons don't respond (no LED) when you press them. Only the "Cancel/Drain" light works and the dishwasher reacts to cancel/drain. I found a diagnostic in the kick panel that has you press; "heated dry, normal, heated dry, normal" within 6 seconds and the washer goes through a diagnostic. All of the tests perform as they should and at the end the washer works again. I don't know why unless doing this resets the circuit board. Does anyone know?
Posted on Aug 01, 2012
Whirlpool quiet partner iv. Turn breaker off then on. Displays 4H then goes off few mins later. Press the cancel button and then the POTS AND PANS along with NORMAL buttons start flashing back and forth.
this is not from me but i found it and am passing on..
Hi
Thanks for using FixYa. Error code 4h means 4 hour delay start which means that the dishwasher is in delay start mode and has been set to 4 hours. You can either wait for 4 hrs or to start it immediately press the cancel button to cancel the delay start option. After this program the cycle and options and press Start again as the dishwasher will not start the wash until it reaches the delayed hour i.e. till 4hrs. If after 4 hrs still the light blinks and it wont start then you'll have to replace the control panel. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Dec 28, 2017 | Whirlpool Dishwashers
SHE043705UC/4H fills with water but does not wash. Have to hit the two buttons to get it to drain. Was settin up for awhile
Look for the automatic shutoff switch underneath the machine left side , hard to find. might have to take machine and tilt it way over to find. just push switch up to reset.
Mar 28, 2014 | Bosch 24 in. SHU43 Built-in Dishwasher
What is error code no. F6E5 mean in Whirlpool Dishwasher (ADP 6776), and how to solve this problem?!
The error code F6E5 means "Cancel key error". Press the "Cancel" and "Start" keys in the following order: CANCEL, CANCEL, START. Verify the error code displayed on the control by observing for longer then 1 minute. If the error persists, the display board has to be replaced.
Sep 27, 2013 | Dishwashers
Normal wash and rinse only lights keep blinking on whirlpool gu1500xtls. tried cancel and uplugging and they still blink
Have Whirlpool GU1500XTLT1 with exact same symptoms, even tried power off but the lights resumed blinking when powered back up. Used solution from "kent168" of 17 Nov 2010 for similar GU1500XTLS1 with a different problem, and IT WORKED: "Reset the machine: press control buttons in this sequence: sani rinse, air dry, sani rinse, air dry, clear."
Jan 18, 2012 | Whirlpool 24 in. GU1500XTLS Stainless...
Whirlpool dishwasher adg 642 not working start light flashhin 4 times
Hello Faye,
The F4 error code is a drainage error and it means that the control board did not detect a drop in the water level in the tub so it thinks it didnt drain.
The things that could cause this are a clooged filter on the pump asm, a blockage in the drain pump or hose or even a defective control board if in fact all the water has seemed to drain out of the tub.This is how ya set the diagnostic test to clear the codes and see if it reoccurs
  • Make sure the appliance is empty of water before running Diagnostics as it does not pump out before starting to fill and therefore you could overfill the appliance.
  • Open the door and set the program to the first program. (Normally rinse).
  • Turn the power off.
  • Press and hold the start button and while holding turn the power on.
  • After a little while the start button will flash, release the button.
  • Press the start button once and close the dishwasher door.
  • The machine will now run through a diagnostic routine.
  • Diagnostic takes about 20 mins.
  • The machine will stop during diagnostics if an error is found and will display the error code. If no error is found it will complete the diagnostics and end the program.
  • To exit diagnostics at any time just press and hold the start button till the program is cancelled.
    GENE
  • Nov 05, 2011 | Whirlpool 24 in. ADG7540 Built-in...
    How do you get the Codes? for GU1500XTL Dishwasher. Only buttons that work are: Anti Baterial, Pots n Pans, Delay Start, Air Dry, and Cancel. We normally use NORMAL. Need Codes and Wiring Diag. Thanks Walt
    I am having the same issue. Did you find a solutions? Looks like websites I've searched talk about resetting the controls by hitting either high temp wash -> airdry -> high temp wash -> air dry OR saniwash -> air dry -> saniwash -> air dry. I'll have to try that tonight.
    Oct 20, 2011 | Whirlpool 24 in. GU1500XTLS Stainless...
    Whirlpool cabero, f-1 error code
    Press "Cancel" once .. it will clear the error code. Try unplugging the machine for 5 min and plug it back in . Press Start. If the F1 code is still there it means it's an electronic problem and you will need a Whirlpool technician with a specialized machine to diagnose it
    Mar 15, 2011 | Whirlpool Washing Machines
    Whirlpool cabrio washing machine
    FL error code generally means 'flood condition' which is telling you the machine is overfilling with water with water.
    Try pressing STOP/CANCEL to clear the display.
    If the condition persists the water fill valve or sensor may be faulty and may need replacement.
    May 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Kenmore elite calypso codes a C1 and quite working
    Maybe "CL" From User Manual:
    “CA” or “CL” (Current Limit)
    Is the washer overloaded?
    Press STOP/CANCEL to clear the display.
    Jul 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    Have code CA
    yep overloaded remove some clothes and consult owners manual for proper load select stop/cancel to clear code if that doesnt work unplug unit for 1 min
    Jan 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
    Dishwashers Logo
    132 people viewed this question
    Top Dishwashers Experts
    Marvin
    Marvin
