Question about Philips 42PF9630A 42 in. Plasma Television
Philips ambilight 42inch plasma
Our Philips ambilight plasma tv is 2.5 years old only. What could be causing the tv menu to pop out every 3 minutes? It just happened suddenly.
  • Anonymous Feb 13, 2009
    me too ...did this fix your problem? mine is a 50'' with the same issues.
  • EUSEBIO AVENDANO Feb 13, 2009
    WHEN I TRY TO TURN ON THE TV THE LIGHTS ARE ON FOR 1 OR 2 SECONDS THEN THEY GO OFF
  • 8,596 Answers
You can fix this yourself with a software upgrade - get the upgrade from Philips website - go to www.usasupport.philips.com, enter your model number, click on the verison of your model ending in /37, and click on "Software & Drivers"; click on the link that says "Firmware Upgrade - Software". Instructions are on the same page - make sure you only transfer the .upg file, not the entire zip file to a portable memory stick.
Posted on Jun 09, 2008
Ambilight isn't working when I press ambilight on the remote control. TV is about 5 years old
Have you tried turning it on in the menu options. Navagate thru the menu there is a setting for on or off on the Ambilights.
Jun 08, 2011 | Philips Ambilight 2 52 in. Flat-Panel LCD...
I have had my Philips Flat screen Plasma 42inch TV for about 4 years now and all of a sudden the TV screen will not come on all the tv is showing is the green light flickering and the sound comes through...
Yes, this is caused by a capacitor problem, take the tv apart and on the main PSU board the faulty capacitors will be evident by their bulged appearance. Andrew Eve
Sep 22, 2010 | Philips 42PF7220A 42 in. Plasma Television
Hi! I have a philips 42inch auto search prob
yes,you will need to do an upgrade.call philips
to get the website.you will need to buy a
computer upgrade stick and download the
upgrade onto this stick.there is a port on the
side of the tv to plug in the stick after you get
the info from there website.
Aug 08, 2009 | Philips 42PFP5332D 42 in. Plasma...
I have a philips 42PF9641D/10 and the ambilight on the left side will not come on (lcd tv) any ideas? On turning on the TV both ambilights came on then the left side went off after about a minute!
probably you got a processing unit problem, which makes your tv stopping recognizing the screen information .
you should try resetting all factory default settings, if this doesn't work, you will have to take the TV to an assistance center .
Jul 30, 2009 | Philips 42PF9631D 42 in. Plasma Television
I have green and red "speckles" that are very distracting within the dark/black areas of the picture. I upgraded software with Philips. No help. Nearest Philips repair is almost an hour away. TV is a...
Hi Mikshanks,
I had the same problem with my TV. It was a horizontal problem with different shades of color, and black spots. I replaced my Upper & Lower Y-buffer boards. Your Y-sus board should be okay since it still powers on the screen. You should replace the Y-buffers Upper & Lower, and it should work. I hope this helps.
best regards,
Tyler
Apr 16, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Menu keeps showing on my TV
Your tv needs a software upgrade. This is usually done by a qulified service technician.
Nov 26, 2008 | Philips 50FD9955 50 in. HDTV-Ready Plasma...
Philips Ambilight
most likely its the audio amplifier board where your having the problems
Jun 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Menu pop up
You may try to check the eeprom circuits. First check their power input line, is it stable or not? Even the power supply line to eeprom ic have a little change/not stable, then you need to suspect the voltage line have some thing not stable, please check fileter cap and regulation ic first. Any more info on plasma tv info you can go to this site to get the tips, http://www.fastrepairguide.com
Sep 06, 2007 | Philips 50PF9630A 50 in. Plasma Television
Philips 42PF9630A 42 in. Plasma Television Logo
564 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
